missing ECU data?? maybe?? help! I just got the accessport. I installed a safemode on my car and the accessport backed up my ecu data. After a few weeks I had a shop install a hpfp on my car. I let them use my accessport to install a new map after they put in the hpfp. Now when I connect my accessport to my accessport manager, click on filter, click on ECU Data I don't see anything there. Is this normal, or did the idiots at the shop erase my ECU data? |
You'll need to expose the ECU data in your AP's settings otherwise you won't see it in AP Manager |
Thanks so much. I can rest easy now. |
jesus christ....you needed a shop to flash a map for you... learn how to use your own shit. |
I didn't need the shop to flash it for me. I flashed a stage1 before I took it in for the hpfp upgrade. He wanted the AP to monitor AFR and pressure after the install. He told me he had to take out the ecu to get to the hpfp so he decided to reflash the stage1 that I already put on the car. I never asked him to do that. |
You have to expose the ECU data in your AP's settings. It is there just hidden. |
Thanks guys. I found the hidden ecu data. I think I'll try another shop next time. Most of the time I like to do my own work on my car, but in the case of the hpfp I didn't have the tools and was a bit nervous to do that one myself. Not sure why he had to take the ECU out. |
| All times are GMT -7. The time now is 01:48 AM. |
