Like Tree3Likes
 Old 07-31-2012, 12:36 PM   #1
doctavus's Avatar
Posts: 1,728   (View Stats)
doctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the world
Groaned at 29 Times in 23 Posts
Default Mold smell part 2
Still having the funky smell coming from my vents when i first turn the a/c on.
This is a pretty strong smell. Dealer has performed the coil cleaning and replaced the cabin filters, lasted a little while.
I have sprayed lysol into the cowl and that would help for a few days.
I looked at products and some that I think would work great are the foams that coat the entire coils.
Has anyone used a product that you spray into the vents or the cowl that worked good?
doctavus is offline   Reply With Quote
 Old 07-31-2012, 01:00 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Bleach
 Old 07-31-2012, 01:04 PM   #3
crankshaft's Avatar
Posts: 576   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Not yet knowing much detail about the MS3, here are some general ideas:
Is the car still under warranty? - make them fix it....
I've tried some tricks with old cars...but never with a new one.
Always run the AC on recirc so you won't be cooling the moist outside air. I'm assuming you live in a moist climate to have this issue in the first place.
I have also done the Lysol trick with good results - but I've only done it with AC on max (recirc), and I shot the lysol under the glovebox where that car sucked air in.
Make sure the evaporator drain is not clogged.
Traded in: 2012 MS3, CWP
2019 Dodge Charger Scat Pack
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 07-31-2012, 01:06 PM   #4
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
klima klear from 1z and isopure by carpro
tddvrrn (10-06-2012)
 Old 07-31-2012, 01:07 PM   #5
Domino81's Avatar
Posts: 5,081   (View Stats)
You need 2 things to have mold: Something organic and moisture. Have you cleaned out your cabin air filter lately? There's not much in those vents that's organic.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 07-31-2012, 01:15 PM   #6
doctavus's Avatar
Yeah sorry, re-run of history.
Car has been into dealership 3 times, 1st time they performed a coil cleaning and a chemical to inhibit mold growth. This helped for several weeks. Happened again, they replaced the pollen filters. This helped for awhile again.
It came back, I took it back as they were going to have a regional mazda engineer come look at it. Well he never made it out because the tech could not smell it.
I call them today and the service manager said we can't do anything anymore regarding it and to contact Mazda Customer Care. So I will start treating it myself.
The drain works fine btw. I prefer a spray to spray into the air intake ducts and see if that doesn't work for awhile.
Car is a 2012 with 6k miles now. Started at roughly 1k miles.
 Old 07-31-2012, 01:19 PM   #7
Domino81's Avatar
Tell them to give you another. That's bullshit.
 Old 07-31-2012, 01:22 PM   #8
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Originally Posted by helmetfail View Post
Bleach
Funny, but really, bleach is terrible for getting rid of mold.
Bleach actually leaves a residue after it dries that new mold spores will use for food.
Vinegar makes it almost impossible for mold to grow.
this forum serves 2 purposes
The Following 3 Users Say Thank You to Dash08 For This Useful Post:
helmetface (07-31-2012), Neverlift (08-04-2012), Worbit (08-04-2012)
 Old 07-31-2012, 01:24 PM   #9
helmetface's Avatar
Groans: 219
Vinegar, I meant vinegar.
fortressofcomfort likes this.
The Following 7 Users Say Thank You to helmetface For This Useful Post:
Dash08 (07-31-2012), fortressofcomfort (10-06-2012), Macncheese (08-04-2012), Mizzle (08-02-2012), tddvrrn (10-06-2012), Worbit (08-04-2012), xI Leveler Ix (08-02-2012)
 Old 07-31-2012, 01:24 PM   #10
Domino81's Avatar
They remediate mold on homes with dry ice... lol
 Old 07-31-2012, 01:27 PM   #11
Posts: 7,290   (View Stats)
Silly question, is the evap draining well? (read as...is there a puddle of water under your car while parked and the a/c on)
Nator is what it does.
 Old 07-31-2012, 01:29 PM   #12
crankshaft's Avatar
In FL, we have a lemon law.
If they can't fix it in 3 shots, they replace the car.
Research similar laws in your state.
The Following User Says Thank You to crankshaft For This Useful Post:
Worbit (08-04-2012)
 Old 07-31-2012, 02:28 PM   #13
Zoomspeed's Avatar
Posts: 370   (View Stats)
Zoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the world
Carquest auto parts sells a product that's made to spray the ac vent Carmax the dealership use it all the time on the card they sell
Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC
Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails
E85
Zoomspeed is offline   Reply With Quote
 Old 07-31-2012, 02:29 PM   #14
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
Groaned at 4 Times in 2 Posts
Wow.. That sucks. My boss swears by a product we use all the time at the airport.. I really can't remember the name atm.. I'll check it out when I go in tomorrow morning.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
 Old 07-31-2012, 02:37 PM   #15
doctavus's Avatar
Yeah it drains fine, or so it seems, was checked out fine and I have the puddles under the car.
I just called Mazda customer service and received a file #. This is my first brand new car, never had that problem before and I have had some older cars.
 Old 07-31-2012, 02:45 PM   #16
cbspd3flip's Avatar
Posts: 1,279   (View Stats)
cbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the world
Groans: 405
Groaned at 19 Times in 16 Posts
The whole point of this is he shouldn't have to do anything. His car is practically brand new yet. Make the dealer fix that shit or tell them to give you another car.
Domino81 likes this.
cbspd3flip is offline   Reply With Quote
The Following User Says Thank You to cbspd3flip For This Useful Post:
Domino81 (07-31-2012)
 Old 08-01-2012, 01:41 PM   #17
doctavus's Avatar
Well basically they said fuck off.
Mazda Customer Care said you can take it to a different dealer but they said this happens to other makes and models and it's a characteristic of these cars.
I am going to try controlling it myself or find something else. Nothing like buying your first brand new car and having to deal with this shit.
 Old 08-01-2012, 03:30 PM   #18
robor007's Avatar
Posts: 13   (View Stats)
robor007 will become famous soon enoughrobor007 will become famous soon enough
I've heard Ozium recommended for controlling the AC vent smell.
robor007 is offline   Reply With Quote
 Old 08-01-2012, 03:41 PM   #19
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
The dealership i work at uses a machine. What they do is remove the cabin filter, turn the ac on recirc./ high/mid temp, and place this fogger on the floor running for 15 minutes. It eliminates all odors and mold from the vent system and interior. They even have a two step process for smokers. I used it when i first got my pu cuz it smelled rank with the blower on. Worked great.
Ryguy is offline   Reply With Quote
 Old 08-01-2012, 04:25 PM   #20
doctavus's Avatar
If only I was closer
 Old 08-01-2012, 08:15 PM   #21
wholigan's Avatar
Posts: 4   (View Stats)
wholigan will become famous soon enough
i used this 1Z Einszett Klima-Cleaner Air Conditioner Treatment
and after i used this Dakota Odor Bomb Car Odor Eliminator, odor remover, air freshener as a bomb
it worked great i live in mobile al and have 100000000 percent humidity. its been a while and smell hasnt come back but the air freshener bomb is pretty potant!!!
wholigan is offline   Reply With Quote
The Following User Says Thank You to wholigan For This Useful Post:
Worbit (08-04-2012)
 Old 08-01-2012, 08:19 PM   #22
There is always 539 lightning!
 Old 08-01-2012, 08:54 PM   #23
doctavus's Avatar
Yeah that Einszett, I forgot the name of that, I will order that.
Maybe the bomb too!
When you used the Kilma did you spray it in the center vents or did you spray it through the cowl?
 Old 08-01-2012, 08:55 PM   #24
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Groans: 106
this is BS what you are being told man. This is not normal characteristic of this car, keep bitching you know the squeaky wheels gets the oil. I would demand them that you want this fix or you will start looking into lemon laws. Me being a mazda tech we have yet to have this issue. With Mitsubishi endeavor we did have this issue and it was due to the drain tube clogging and the system getting backed up and leaving water in the floor board and then mold develops under the carpet. So just keep complaining if you have to go to another dealership if there is one near you and tell them what you have been through, trust me they want that warranty money. There is a tsb for a mildew odor smell in the ac system but it is only for vehicles up to 2009.
go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle
suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55
motherfnmonsta is offline   Reply With Quote
 Old 08-01-2012, 09:02 PM   #25
doctavus's Avatar
I told Mazda Customer Care about possibly going through the Lemon Law procedure, she didn't choke one bit.
The thing is right now is the fact that when I take it to the dealership they can't smell it, I just need to take it to them during the day when it's really bad (while I'm at work). So basically they think I'm full of shit.
I'm kinda tired of this right now honestly. Probably take it to a new dealership on Saturday to have them smell it and go from there.
 Old 08-01-2012, 09:15 PM   #26
darkcherry's Avatar
Posts: 930   (View Stats)
darkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the world
I use a foam spray at work it is called foamy clean. It is rinseless all you have to do is spray on evaporator, let it sit and it will remove any debris, deodorizes, non toxic and leaves a pleasant smell. Nothing harsh. Works good for what i use it for. Hope this helps.
mods:
Do wmi 50/50, freek tune 306hp/350tq.
blitz bov, cpe hpfp, tmic, excel nano sri, tip, blue duro rmm, 3" ss catted dp, 3" ss cs cat back exhaust, Cobb AP, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, msd dh, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , winter=stock wheels w/winter tires / summer=18x8 adr hyp black wheels w/bfg force kdw, eibach sportline springs. Soon to come: bt, slotted rotors, cf fi hood
darkcherry is offline   Reply With Quote
 Old 08-01-2012, 09:27 PM   #27
darkcherry's Avatar
I use a foam spray at work it is called foamy cleanuploadfromtaptalk1343878035263.jpg. It is rinseless all you have to do is spray on evaporator, let it sit and it will remove any debris, deodorizes, non toxic and leaves a pleasant smell. Nothing harsh. Works good for what i use it for. Hope this helps.
mods:
 Old 08-01-2012, 09:29 PM   #28
England15j's Avatar
Posts: 1,910   (View Stats)
England15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the world
i have the same issue with mine but it only produces a smell after running the ac on re-circulation then turn the re-circulation off, don't know if that's normal but I've lived with it any info on the exact location of the drain valve would be nice i cant seem to find it its not that descriptive in the Mazda tech manual PDF
Blacked Out 2010 Black Mica MazdaSpeed 3
Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel,
eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles,
England15j is offline   Reply With Quote
 Old 08-02-2012, 08:05 PM   #29
wholigan's Avatar
Maybe the bomb too!
i sprayed it in the center vent then removed cabin air filter and spayed in there.
 Old 08-02-2012, 08:17 PM   #30
radioflyer's Avatar
Posts: 729   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groans: 28
Groaned at 22 Times in 12 Posts
There is a product I picked up at autozone for my last car and it worked very very well. It was mostly alcohol in an aerosol can.
You applied it by turning the vents on full blast with recirculate off and spray it out side the car where the exterior vent is in between the windshield washers.
Worked great for about a year and had to do it again. I was perfectly happy for 6 bucks.
-2007 MS3 - Sold
-2015 BMW m235i - Painfully stock and incredibly comfortable.
radioflyer is offline   Reply With Quote
 Old 08-02-2012, 08:39 PM   #31
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Where is the drain, vent located
 Old 08-02-2012, 08:57 PM   #32
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Wait wait wait.
Mazda Customer Care is a fucking joke. They said they wouldn't help me with my broken shifter because of a transmission mount . . .
Having said that, lemon law. If they can't fix it, they have to take it back. Don't feel bad about fucking Mazda's couch on this one because mold makes people sick. Chances are it's growing in the ducting or something else if you can't get rid of the smell.
My window AC had gelatinous globs of moldy grossness in it when I finally took it apart after cleaning it over and over. It was growing on metal, plastic & Styrofoam.
It will never ever ever get better until your dash is sitting on a garage floor and someone's using a toothbrush... so they either do that or give you another car.
The Following User Says Thank You to Mizzle For This Useful Post:
radioflyer (08-02-2012)
 Old 08-03-2012, 06:48 PM   #33
doctavus's Avatar
Got in touch with a consumer lawyer that specializes in Lemon Laws in my state.
He is going to review my case and let me know.
Fuck Mazda and their bullshit.
Sucks because I love this car, fast and comfortable for price. We'll see what happens.
crankshaft likes this.
The Following User Says Thank You to doctavus For This Useful Post:
Worbit (08-04-2012)
 Old 08-03-2012, 11:04 PM   #34
Droopzy's Avatar
Posts: 23   (View Stats)
Droopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant futureDroopzy has a brilliant future
Well before you get involved in all of that I would at least give a shot yourself. The product we use and have performed this service for this exact complaint at my shop is called Frigi-Fresh by BG Chemicals. That is the more basic one that you spray inside of the vehicle with the AC on recirculation and the blower motor on max for a few seconds. You spray it inside the recirc door then turn off the vehicle for 10-15 minutes with all doors closed so the sweat in the Evap casing with the product clean inside of the casing and the remaining in the vents. It has done WONDERS on some customers cars especially killing the 2am bowling alley ash tray smell.
The only down fall of it is they don't sell to public, even though I have seen some of there products at parts stores. But they do have a shop locator at the bottom so you might be able to find a shop and see if you can buy a can from them or have them do the service. Just make sure you say Frigi-Fresh not Frigi-Clean because the proper way to do the foams is to drill into the evap casing an inject it that way... And thats just a pain in the ass for everyone.
Here is a link to the product its like mid way down the page.BG Products, Inc.
Hope this helps and best of luck!
Droopzy is offline   Reply With Quote
 Old 08-03-2012, 11:55 PM   #35
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
FUCK doing it hisself! This car has 6k miles on it! Mazda better fix everything or give him a new car. The car has a warranty for a reason.
OP, take a day off of work or drive straight to the Mazda dealership when you get that smell. Quit beating around the bush. Fuck all that mess, If you want the car fixed your gonna have to be a prick about it.
Spoofmastafly is offline   Reply With Quote
The Following User Says Thank You to Spoofmastafly For This Useful Post:
Mizzle (08-04-2012)
 Old 08-04-2012, 02:30 AM   #36
jeopardy98's Avatar
Posts: 1,920   (View Stats)
Groans: 112
I'm in for results because my car has been doing this since 3K miles. The smell is god awful.
jeopardy98 is offline   Reply With Quote
 Old 08-04-2012, 09:47 AM   #37
Ur moms boyfriend
Yea mine has been doing this since day 1. I never really care too much as i might use the AC 2 or 3 times a year
 Old 08-04-2012, 10:04 AM   #38
Worbit's Avatar
Posts: 2,552   (View Stats)
Groans: 142
In before dead rat is found inside the engine bay
(also in for results)
Zoom-Zoom-Coons on 05/10/16
BUILT BY CORKSPORT
The Following User Says Thank You to Worbit For This Useful Post:
GunGuru727 (10-07-2012)
 Old 08-04-2012, 10:38 AM   #39
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
I make sure I turn the A/C off with the fan still on before I reach my destination. Since explaining this to my GF, she doesn't have mildewy-smells anymore.
Past Mazdas & Speeds
 Old 08-04-2012, 01:21 PM   #40
Droopzy's Avatar
Woah now no need to get all brotastic on me now. OP mentioned trying to do it himself so I was giving a suggestion... That hurt my e-feelings
The Following 2 Users Say Thank You to Droopzy For This Useful Post:
Spoofmastafly (08-04-2012), Worbit (08-04-2012)
Mold in PG cluster. Demi MazdaSpeed 3 - How-To's 13 04-21-2013 07:29 PM
Still have mold/mildew smell doctavus Gen2 MS3 General Discussion 47 05-22-2012 09:50 PM
Caterham to break out of the Seven mold with all-new model Haltech Automotive News 0 12-13-2010 02:20 PM
Kathy Griffin Breaks the Mold Haltech Celeberty Smut 0 07-04-2009 11:50 PM
Page generated in 0.57372 seconds with 44 queries
