 Old 07-30-2013, 08:44 PM   #1
poisonouschimp's Avatar
Posts: 59   (View Stats)
poisonouschimp has a spectacular aura aboutpoisonouschimp has a spectacular aura aboutpoisonouschimp has a spectacular aura about
Default More POWEr!
I keep hearing that our engines can only handle like 400 hp then we start bending rods. Could you just upgrade the rods and then turn up the power a little more? Do you even really need to worry about a bent rod on the k04? I have full bolt ons 3" turbo back exhaust, sri, tip, fmic, ap, fuel internals. I really want to run e85 too in the future. Don't really want to upgrade the stock turbo though.
poisonouschimp is offline
The Following 7 Users Say NO Thank You to poisonouschimp For This Un-useful Post:
captain slow (07-30-2013), cbspd3flip (07-31-2013), El_Diablo (07-31-2013), Hush (07-30-2013), maisonvi (07-31-2013), Raider (07-31-2013), Vansquish (07-30-2013)
 Old 07-30-2013, 08:47 PM   #2
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
o no k04 makes your engine invincible, run a shit ton of timing and 13 AFR, might as well run 29 psi making the k04 a proverbial flamethrower you will NEVER get a bent rod, promise
TRex is offline
The Following User Says Thank You to TRex For This Useful Post:
alphasaur (07-31-2013)
 Old 07-30-2013, 08:49 PM   #3
Ok then, my main questing is still stands though. Could you upgrade your rods then and be safe?
The Following User Says NO Thank You to poisonouschimp For This Un-useful Post:
Vansquish (07-31-2013)
 Old 07-30-2013, 08:54 PM   #4
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Yes but you're not going to make 400 on the ko4
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline
 Old 07-30-2013, 08:55 PM   #5
So then you would not need to upgrade the rods if you were to stick with the k04? I just want a reliable high hp tune to run on 91 octane, possibly e85 in the future.
 Old 07-30-2013, 09:05 PM   #6
captain slow's Avatar
Posts: 5,559   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 398
Groaned at 50 Times in 34 Posts
It's the torque that gets you not hp.
The best things for these engines is torque down low. You wanna peak at like 2000 rpm. Helps with launches and won't affect the rods.
2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!!
2014 5.0 Gotta Have It Green w/Track Pack
captain slow is offline
 Old 07-30-2013, 09:07 PM   #7
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
^^ what he said
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline
 Old 07-30-2013, 09:26 PM   #8
hitmeagaintubesock's Avatar
Posts: 257   (View Stats)
hitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the world
Don't change the rods get the mazdaspeed rod braces...they double sided sticky tape to the side of the rods and strengthen them stronger than wolverine from x men's skeleton....
2014 Ford mustang gt: k&n drop in filter, heart throb muffler deletes, sr performance front and rear sway bars, bmr lower control arms, h&r springs, bmr adjustable pan hard bar, bmr upper control arm, barton short shifter and two post bracket.
2012 speed3: gone but not forgotten
86 Porsche 944 turbo. Sold will be missed
88 dodge ram: 4 inch rough country lift, 35 1250 bfg mud terrain km2, ex fuel injected 318, edelbrock intake, edelbrock carb, mopar performance headers, 340 mopar petformance purple shaft cam, flowmaster single chamber mufflers with true duals
2011 ford fusion awd v6 kid hauler
hitmeagaintubesock is offline
 Old 07-30-2013, 09:33 PM   #9
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
*sniff* *sniff*
my troll senses are tingling...
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline
 Old 07-31-2013, 11:55 AM   #10
I guess basically what I am asking is if I upgrade my rods then could I tell a turner to tune more agressive than someone who didnt upgrade them, thus making more power.
 Old 07-31-2013, 12:05 PM   #11
doctavus's Avatar
Posts: 1,728   (View Stats)
doctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the world
Groaned at 29 Times in 23 Posts
/thread
doctavus is offline
 Old 07-31-2013, 02:30 PM   #12
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Groans: 106
Get a hold of dante he can give you a aggressive tune and help you reach your 400 hp goal
go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle
suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55
motherfnmonsta is offline
The Following 3 Users Say Thank You to motherfnmonsta For This Useful Post:
Playaj (08-01-2013), Sid3wayS (07-31-2013), socaltouch13 (08-03-2013)
 Old 07-31-2013, 07:17 PM   #13
What is the limiting factor at 400 hp then once you tune for lower torque? Why not 500 hp? If I upgrade the rods then could I keep going up in power is my main question...What is the next limiting factor to add more power?
Limits for more power
1. Fuel internals so engine does not blow up
2. Rods?
3. ???
 Old 07-31-2013, 08:36 PM   #14
Groans: 106
2. Rods?
3. ???
and a tune by @dantes5823 just shoot him a pm he will be more then glad to lead you down to the correct path
The Following User Says Thank You to motherfnmonsta For This Useful Post:
h0ckeyman (08-27-2013)
 Old 07-31-2013, 08:55 PM   #15
Why does his profile says he is banned?
 Old 07-31-2013, 09:00 PM   #16
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
Because you can't be bothered to read for yourself.
Vansquish is offline
 Old 07-31-2013, 09:01 PM   #17
ABloodBrother's Avatar
Posts: 2,009   (View Stats)
ABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the world
Groaned at 17 Times in 13 Posts
Thank you for the good laugh good sir
ABloodBrother is offline
 Old 07-31-2013, 09:03 PM   #18
doctavus's Avatar
You just made my night!
Cheers to you sir.
doctavus is offline
 Old 07-31-2013, 09:05 PM   #19
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
Because he was a shit tuner. Made engine go boom !
What you said in your original post has been discussed again and again and again.
If you want a little respect and good answer here:
1. Use the search button.
2. Find info, read stickies.
3. Donate.
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline
The Following User Says Thank You to julienjj For This Useful Post:
motherfnmonsta (07-31-2013)
 Old 07-31-2013, 09:13 PM   #20
Groans: 106
as julien said he is a shit tuner, if you would actually search you will find the correct answers, but if you come on here asking questions that has been asked a billion times you are going to get sarcastic remarks,wrong answers, and lot's of flaming.
So I suggest to just stop posting, donate please, and read all the links in your welcome email from @Raider
 Old 07-31-2013, 09:43 PM   #21
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
No post. More read.
Raider is offline
Video: Bike Magazine loses pedal power in favor of Porsche power Haltech Automotive News 0 09-22-2011 01:20 PM
Rumormill: Ford's Power Stroke diesel getting power increase to beat GM Duramax Haltech Automotive News 0 03-24-2010 07:20 AM
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Antec Neo Power 500 ATX12V 500W Power Supply 100Vac to 240Vac $69.99 Free Shipping Haltech Hot Deals Section 0 04-01-2008 09:41 PM
Page generated in 0.40592 seconds with 32 queries
