 Old 04-06-2017, 09:23 AM   #1
mking8696's Avatar
Posts: 1   (View Stats)
mking8696 is an unknown quantity at this point
Default Motor issues
Hello all, I have a few issues going on and don't know where to go from here. My OBD2 informed me that cylinder 4 had a misfire and so I go in and check the spark plug and it still sparked however when I pull the plug it had oil on it, what should I look at from here. Why is there oil burning and after driving for about 20 minutes the low oil light came one.
mking8696 is offline   Reply With Quote
 Old 04-06-2017, 09:49 AM   #2
unionmade06's Avatar
Posts: 2   (View Stats)
unionmade06 is an unknown quantity at this point
I have same issue and its 2010 3
Compression test then leak down test after....
Sent from my 5056N using Tapatalk
unionmade06 is offline   Reply With Quote
 Old 04-06-2017, 10:26 AM   #3
mituc's Avatar
Posts: 3,388   (View Stats)
Groans: 106
Oil on the spark plug means oil in the cylinder. So check compression and leak down for rings and valves/valve seals and guides.
2008 Cosmic Blue Mazda 3MPS
Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PSS 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend ENduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit
JBR Tru-3" + CS CAI Box, SU TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071, CS 3.5BAR, Guardian Angel, CoolingMist WMI
StratiVersaTuned FTW
Stock for now
Versatuned
 Old 04-21-2017, 08:46 AM   #4
tmillner's Avatar
Posts: 610   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
When was the last time you checked your oil? What exhaust mods do you have
Sent from my SM-G935P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 04-21-2017, 03:31 PM   #5
Thor Hammer's Avatar
Posts: 1,297   (View Stats)
Groans: 102
Your low oil light came on and you did what next?
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
Report: German motor authority issues report on contested refrigerant, everyone claims victory Haltech Automotive News 0 08-12-2013 07:10 AM
unwanted motor issues semperboost MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-16-2009 06:54 PM
motor mount issues phailerider MazdaSpeed 3 - Engine, Transmission & Driveline 24 04-20-2008 02:55 PM
Page generated in 0.27408 seconds with 24 queries
