Like Tree2Likes
 Old 02-12-2012, 05:00 PM   #41
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Originally Posted by breakfstincluded View Post
If the engine isn't shuddering / lugging then all is good with shifting so low?
I'm guessing it doesn't apply if you're on any sort of incline?
I'll notice the mpg computer give me unexpected numbers comparing 5th and 6th as well
Pretty much. I mean, you wanna wind it out now and then to keep everything moving correctly, but otherwise I put around b/c I'm poor.
Downshifting on an incline is actually better because you're not boosting to make power to lug up the hill. Higher RPM without boost is better than lower RPM and full boost.
The nice thing about using the computer is that just because the numbers are off doesn't mean it's not accurate when comparing one gear to another. It's generally reporting higher numbers than what you're really getting, but you can still use it as a base for efficiency.
 Old 02-12-2012, 05:06 PM   #42
deek's Avatar
Posts: 687   (View Stats)
deek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the world
You guys do realize that not only does driving habits go into play when looking at mpg, just Think about the difference in air pressure, barometric pressure and altitude should mind boggle you alone. Sea level air is richer, need more fuel to accommodate, ca should get worse then Colorado. Then if you factor in elevation changes, driving habits, mods and the science of how they work. I just mind fucked myself. Oh and 30 mpg dd
2010 Dodge Ram 1500
6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5
deek is offline   Reply With Quote
 Old 02-12-2012, 05:18 PM   #43
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
Right, I'm thinkin of if you're on a slight incline and you're getting on 1st from a stop, if you can afford to up shift at 2.2K, but if it was really that drastic an incline you'd just wait a few more rpm.
But that's good to know... I'll be on a good incline at 3000rpm and always contemplate upshifting and ending up cruising around 2500 or so, or if that's just uneeded strain to be in higher gear.
 Old 02-12-2012, 05:52 PM   #44
Mortose's Avatar
Posts: 2,441   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 39
the best mileage i have had is long interstate trips. didn't matter about on ramps and my need to get to 70 as soon as i could, i was getting 30-31 mpg (calculated @ pump), even loaded down with a couple hundred pounds of crap when i moved. when i was living in FL, with a 20-25 min commute in the morning at 65-75 mph, with a little bit of "city" driving i was getting and average of 26 or so, sometimes higher, sometimes lower. I have yet to do the math up here in CO, but i'm sure its going to go down due to living close to work driving through residential areas.
2008.5 Metropolitan Grey Mica: Sold
99 miata: sold
2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is offline   Reply With Quote
 Old 02-12-2012, 06:21 PM   #45
mswierse's Avatar
Posts: 313   (View Stats)
mswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the world
I was really surprised that I was getting 25mpg (calculated) with mised driving since the window sticks only says 25MPG on highway. I've had a lot of cars and none of them have been close to the window stick mpg, except the MS3.
2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed, Ksport Coilovers, SPC camber arms...
13.5@106
mswierse is offline   Reply With Quote
 Old 02-12-2012, 07:05 PM   #46
Mizzle's Avatar
Groans: 324
Must've changed from the Gen1 then since my sticker says 31 iirc
 Old 02-12-2012, 08:01 PM   #47
H3R3TIC's Avatar
Posts: 303   (View Stats)
H3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the world
I don't think the window sticker listed it that high, but I honestly don't remember. Only time I ever get 30 is on long trips with alot of air in the tires. I seem to average 23-24 most days (calculated at pump) and that's mixed cruising and destroying my local on ramps and occasional highway pulls and stop and go.
H3R3TIC is offline   Reply With Quote
 Old 02-12-2012, 08:21 PM   #48
Groans: 261
Just pulled out my window sticker haha
it says 18 city 26 highway. which matches mpgfacts.com for 2008 at least
I've yet to drive a tank on mostly highway miles.
Mixed driving for me is 26 though, assuming I don't have to defend myself from some jackass on I-5 isn't trying to cut me off.
 Old 02-12-2012, 09:03 PM   #49
Stingray69's Avatar
Posts: 1,197   (View Stats)
Groans: 48
Originally Posted by cesaros View Post
But its not. Idk how she did it.
Trip was all highway and at 55-60mph tops since I was driving a uhaul...fwiw.
Was the speed in the uhaul? The most I have ever got was 26.4 driving like my 87 YO grandma. Speeds are for fun hybrids are for milege, fill her up and drive her hard.
Stingray69 is offline   Reply With Quote
 Old 02-13-2012, 09:56 AM   #50
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
LOL 2008.5 MS3 and I get 16 MPG on a good fillup. City driving only in Miami.
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
 Old 02-13-2012, 11:21 AM   #51
Mazda Lover's Avatar
Posts: 110   (View Stats)
Mazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond reputeMazda Lover has a reputation beyond repute
I once got 33 on my way back from Tahoe, but it was all down hill driving.
Most of the time I get 21-22 with 75% hwy driving...this I attribute to crap California gas as I don't really have my foot into it.
If I drive hard the mileage doesn't seem to change all that much though. My RX-8 was like this as well...baby it and get 20 or beat it down and get 18.
I think gas quality plays a factor as I used to have a PT Cruiser GT that I used for commuting long distance several days a week. Every now and then I'd get what I considered to be a good batch of gas from Chevron. My MPGs would shoot up and I'd get 300+ miles to a tank rather than the usual 240...same trip mind you.
Mazda Lover is offline   Reply With Quote
 Old 02-13-2012, 06:55 PM   #52
Mizzle's Avatar
Groans: 324
JDR767 likes this.
The Following 3 Users Say Thank You to Mizzle For This Useful Post:
breakfstincluded (02-14-2012), Easter Bunny (02-14-2012), H3R3TIC (02-14-2012)
 Old 02-13-2012, 07:03 PM   #53
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
Originally Posted by Stingray69 View Post
Was the speed in the uhaul?.
really?....
cesaros is offline   Reply With Quote
 Old 02-14-2012, 02:46 AM   #54
Groans: 261
Wow I've never paid attention to those numbers in my life!
we have enough numbers to make a cat and whisker plot now lol
geeze, that makes me feel bad, I want to get a calculated 31mpg tank now haha
time for an impromptu road trip to bonneville
 Old 02-14-2012, 03:21 AM   #55
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
I get 13mpg believe it or not from the e85, it's absolute shit. I have a 50/50 tune I run most of the time which instantly goes back up to around 18mpg bc im not traveling far, but when I do it goes up to 22.
~Sent from my GNexus running Cm9 ~
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
 Old 02-14-2012, 07:16 AM   #56
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
I get about 14 mpg now that I drive in the city all the time.
e85 mix ftw!
The Following User Says Thank You to wolly6973 For This Useful Post:
SWAY (02-14-2012)
 Old 02-14-2012, 07:51 AM   #57
Capricious's Avatar
Posts: 49   (View Stats)
Capricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud ofCapricious has much to be proud of
You guys saying e85 - don't you mean e15? For what its worth, owners manual says never to put in anything past e10.
Capricious is offline   Reply With Quote
 Old 02-14-2012, 07:55 AM   #58
wolly6973's Avatar
Groans: 386
My wife also tells me not to put it in her ass...
The Following 5 Users Say Thank You to wolly6973 For This Useful Post:
breakfstincluded (02-14-2012), Easter Bunny (02-14-2012), Mizzle (02-14-2012), SWAY (02-14-2012), _riskibus_MS3 (02-14-2012)
 Old 02-14-2012, 08:17 AM   #59
SWAY's Avatar
Groans: 190
Newbs gonna newb, reread my sig homeboi. Owners manual is for big hairy vaginas, Msf is my manual.
The Following 3 Users Say Thank You to SWAY For This Useful Post:
Easter Bunny (02-14-2012), Mizzle (02-14-2012), wolly6973 (02-14-2012)
 Old 02-14-2012, 08:36 AM   #60
wolly6973's Avatar
Groans: 386
Read this whole thread as well.
E85 Discussion - HPFP lubrication and Flow issues
And check out the other threads here...
E85 - Mazdaspeed Forums
Last edited by wolly6973; 02-14-2012 at 08:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-14-2012, 11:11 AM   #61
Capricious's Avatar
I have been learned.
The Following User Says Thank You to Capricious For This Useful Post:
SWAY (02-14-2012)
 Old 02-14-2012, 12:26 PM   #62
H3R3TIC's Avatar
Hah. I stand corrected, never even noticed that range underneath.
 Old 02-14-2012, 12:50 PM   #63
adrager622's Avatar
Posts: 745   (View Stats)
adrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the world
Groans: 46
I get around 22/23 for around my area (city and highway, but lots of stop and go in my neighborhood), but closer to 27 when I go on long trips. Then again, if I gave a shit about gas mileage, I wouldn't be sitting in this car.
2010 MS3 Black Mica
-JBR RSB, JBR Boost Tubes and BPV hose, JBR 80a RMM, CP-e Nano SRI, 6000K HIDs
adrager622 is offline   Reply With Quote
Page generated in 0.43382 seconds with 32 queries
