![]() | | #41 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score
Downshifting on an incline is actually better because you're not boosting to make power to lug up the hill. Higher RPM without boost is better than lower RPM and full boost. The nice thing about using the computer is that just because the numbers are off doesn't mean it's not accurate when comparing one gear to another. It's generally reporting higher numbers than what you're really getting, but you can still use it as a base for efficiency. | |
![]() | | #42 | ![]() |
![]() Join Date: Oct 2011 Location: El Paso
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score You guys do realize that not only does driving habits go into play when looking at mpg, just Think about the difference in air pressure, barometric pressure and altitude should mind boggle you alone. Sea level air is richer, need more fuel to accommodate, ca should get worse then Colorado. Then if you factor in elevation changes, driving habits, mods and the science of how they work. I just mind fucked myself. Oh and 30 mpg dd
__________________ 2010 Dodge Ram 1500 6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5 |
![]() | | #43 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
Groans: 261
Right, I'm thinkin of if you're on a slight incline and you're getting on 1st from a stop, if you can afford to up shift at 2.2K, but if it was really that drastic an incline you'd just wait a few more rpm. But that's good to know... I'll be on a good incline at 3000rpm and always contemplate upshifting and ending up cruising around 2500 or so, or if that's just uneeded strain to be in higher gear.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. | |
![]() | | #44 | ![]() |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score the best mileage i have had is long interstate trips. didn't matter about on ramps and my need to get to 70 as soon as i could, i was getting 30-31 mpg (calculated @ pump), even loaded down with a couple hundred pounds of crap when i moved. when i was living in FL, with a 20-25 min commute in the morning at 65-75 mph, with a little bit of "city" driving i was getting and average of 26 or so, sometimes higher, sometimes lower. I have yet to do the math up here in CO, but i'm sure its going to go down due to living close to work driving through residential areas.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" Last edited by Mortose; 02-12-2012 at 06:27 PM. |
![]() | | #45 | ![]() |
![]() Join Date: Dec 2011 Location: Holland, Michigan, United States
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score I was really surprised that I was getting 25mpg (calculated) with mised driving since the window sticks only says 25MPG on highway. I've had a lot of cars and none of them have been close to the window stick mpg, except the MS3.
__________________ 2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed, Ksport Coilovers, SPC camber arms... 13.5@106 |
![]() | | #46 | ![]() |
Groans: 324
| Not Ranked : 0 score Must've changed from the Gen1 then since my sticker says 31 iirc |
![]() | | #47 | ![]() |
![]() Join Date: Jan 2010 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,948
| Not Ranked : 0 score I don't think the window sticker listed it that high, but I honestly don't remember. Only time I ever get 30 is on long trips with alot of air in the tires. I seem to average 23-24 most days (calculated at pump) and that's mixed cruising and destroying my local on ramps and occasional highway pulls and stop and go. |
![]() | | #48 | ![]() |
Groans: 261
| Not Ranked : 0 score Just pulled out my window sticker haha it says 18 city 26 highway. which matches mpgfacts.com for 2008 at least I've yet to drive a tank on mostly highway miles. Mixed driving for me is 26 though, assuming I don't have to defend myself from some jackass on I-5 isn't trying to cut me off.
![]() | | #49 | ![]() |
![]() Join Date: Mar 2011 Location: Shawnee, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,101
Groans: 48
| Not Ranked : 0 score Was the speed in the uhaul? The most I have ever got was 26.4 driving like my 87 YO grandma. Speeds are for fun hybrids are for milege, fill her up and drive her hard.
__________________ AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM |
![]() | | #50 | ![]() |
![]() Join Date: Feb 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Groans: 46
| Not Ranked : 0 score LOL 2008.5 MS3 and I get 16 MPG on a good fillup. City driving only in Miami.
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted |
![]() | | #51 | ![]() |
![]() Join Date: Nov 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
| Not Ranked : 0 score I once got 33 on my way back from Tahoe, but it was all down hill driving. Most of the time I get 21-22 with 75% hwy driving...this I attribute to crap California gas as I don't really have my foot into it. If I drive hard the mileage doesn't seem to change all that much though. My RX-8 was like this as well...baby it and get 20 or beat it down and get 18. I think gas quality plays a factor as I used to have a PT Cruiser GT that I used for commuting long distance several days a week. Every now and then I'd get what I considered to be a good batch of gas from Chevron. My MPGs would shoot up and I'd get 300+ miles to a tank rather than the usual 240...same trip mind you. |
![]() | | #52 | ![]() |
Groans: 324
| Not Ranked : 0 score |
| The Following 3 Users Say Thank You to Mizzle For This Useful Post: |
![]() | | #53 | ![]() |
![]() Join Date: May 2010 Location: GoldsBoro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 280
Groans: 106
Groaned at 53 Times in 41 Posts
![]() | | #54 | ![]() |
Groans: 261
| Not Ranked : 0 score Wow I've never paid attention to those numbers in my life! we have enough numbers to make a cat and whisker plot now lol geeze, that makes me feel bad, I want to get a calculated 31mpg tank now haha time for an impromptu road trip to bonneville
![]() | | #55 | ![]() |
![]() Join Date: Nov 2010 Location: Houston Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,763
Groans: 190
Groaned at 60 Times in 43 Posts
| Not Ranked : 0 score I get 13mpg believe it or not from the e85, it's absolute shit. I have a 50/50 tune I run most of the time which instantly goes back up to around 18mpg bc im not traveling far, but when I do it goes up to 22. ~Sent from my GNexus running Cm9 ~
__________________ ~2011 Liquid Silver MS3~ ---->> ZZB ![]() TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #56 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score I get about 14 mpg now that I drive in the city all the time. e85 mix ftw! |
| The Following User Says Thank You to wolly6973 For This Useful Post: | SWAY (02-14-2012) |
![]() | | #57 | ![]() |
![]() Join Date: Feb 2012 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score You guys saying e85 - don't you mean e15? For what its worth, owners manual says never to put in anything past e10. |
![]() | | #58 | ![]() |
Groans: 386
| Not Ranked : 0 score My wife also tells me not to put it in her ass... |
| The Following 5 Users Say Thank You to wolly6973 For This Useful Post: | breakfstincluded (02-14-2012), Easter Bunny (02-14-2012), Mizzle (02-14-2012), SWAY (02-14-2012), _riskibus_MS3 (02-14-2012) |
![]() | | #59 | ![]() |
Groans: 190
__________________ ~2011 Liquid Silver MS3~ ---->> ZZB ![]() TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN | |
| The Following 3 Users Say Thank You to SWAY For This Useful Post: |
![]() | | #60 | ![]() |
Groans: 386
| Not Ranked : 0 score Read this whole thread as well. E85 Discussion - HPFP lubrication and Flow issues And check out the other threads here... E85 - Mazdaspeed Forums Last edited by wolly6973; 02-14-2012 at 08:36 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #61 | ![]() |
| Not Ranked : 0 score I have been learned. |
| The Following User Says Thank You to Capricious For This Useful Post: | SWAY (02-14-2012) |
![]() | | #62 | ![]() |
![]() | | #63 | ![]() |
![]() Join Date: Apr 2010 Location: Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 639
Groans: 46
| Not Ranked : 0 score I get around 22/23 for around my area (city and highway, but lots of stop and go in my neighborhood), but closer to 27 when I go on long trips. Then again, if I gave a shit about gas mileage, I wouldn't be sitting in this car.
__________________ 2010 MS3 Black Mica -JBR RSB, JBR Boost Tubes and BPV hose, JBR 80a RMM, CP-e Nano SRI, 6000K HIDs [SIGPIC][/SIGPIC] |
