 Old 02-14-2018, 10:10 AM   #1
Jeff23spl's Avatar
Posts: 1,698   (View Stats)
Default My gen1 just burned and need advices if i should get a gen2
Hello
This morning my 2007 ms3 just catch fire and get totaled...the car was built and small BT. i need advides if i should just get a new shell for another first gen or get a second gen or even a 6 for more tractions but more problems ?
I know i post in the second gen forum so i may get positive answer to get one but my wonders is about the longer ratio gear, more electronics to mess with a tune and the black/red kind of interrior color...My first gen was also a good sleeper when a second gen let peoples know with the hood scoop that there is something under....
I was happy with my gen one after about 10 years, i was looking to change my gt2871 for a gtx3071 but this happened before i ordered it...I ask advices because i'm very slow to choose stuff, It took me a year to decide for a new turbo...
So just tell me about what do you think or if someone switched from a first gen to a second...etc...
At some point i was looking at 335Xi for a next car in few years but it can be the time too....
Is the second gen easier on the wheel arch to install slick on the front ?
It is a sad day for me so any advice is welcome.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-14-2018, 10:46 AM   #2
Thor Hammer's Avatar
Posts: 1,788   (View Stats)
Groans: 203
How did your clutch get hot enough to catch fire? Bummer man.
 Old 02-14-2018, 10:47 AM   #3
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
I want to see pics.
I would go with a gen1 as it's cheaper and I don't like gen2 body style.
Hopefully your car was insured.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
The Following User Says Thank You to stockms3 For This Useful Post:
Db09ms3 (02-14-2018)
 Old 02-14-2018, 10:51 AM   #4
Db09ms3's Avatar
Posts: 287   (View Stats)
Groans: 66
I 2nd the genwin. Get an '09, the interior trim looks nicer than my buddy's '07. Gloss black and white gauge needles, mmmmmmmm
 Old 02-14-2018, 12:08 PM   #5
Jeff23spl's Avatar
don't see where i talk about my clutch ????
Actually i'm not sure what it was. I will check tomorrow but when i opened the hood, there was fire on the firewall and oil everywhere. The floor on the passenger side just below the transmission stick was also in fire.
My 4awg for my sub pass there below the carpet but i have a 80A fuse at the battery....
I was expecting at first, it came from the turbo because it happened 1-2 minutes after a heavy pull entering the highway...a Leak that catch fire splashing on the cherry hot turbo casting??? Or the oil just splashed after an oil line burned after something else made the fire....
I hope my insurrance won't bother me because of mecanic mods....The fmic and w/m is easy to see...
Wife drive 2010 CX7
 Old 02-14-2018, 12:18 PM   #6
Spectrix's Avatar
Posts: 312   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
Just some food for thought - do you really wish to build the same car over again? If you're planning on a 335 in the future, building another Speed is an expensive stopover.
Sorry to hear about your car catching alight.
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
 Old 02-14-2018, 12:33 PM   #7
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Here you guy, buy this guys car, fellow Canadian...
How much is my car worth?
 Old 02-14-2018, 12:40 PM   #8
Jeff23spl's Avatar
thanks for the offer but i'm completly on the other side of the country, i will check for something local...
Wife drive 2010 CX7
 Old 02-14-2018, 12:46 PM   #9
Jeff23spl's Avatar
this is a part of my questions....why redo it....a good answer would be: because i know the speed pretty well and it would be easy to redo it but skip the mistake i may have made.
But it would just be a repeat.....
What stop me from bm is the range of money to build it compared to a speed. And the knowledge level seem a bit more limited than what we have here. I already joined some forum and peoples talk more about the cost of repairs at the dealership than about build thread and mods....The potential of the inline 6 for a recent car is tempting too....
Wife drive 2010 CX7
 Old 02-14-2018, 01:36 PM   #10
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Really sorry to hear that. Take off what you can before insurance comes.
Genjaun 4 lyfe if you get another speed. But after 10 years I'd think you'd be tired of the car.
Depending on what you can afford, check out the newer golf gti/r and the focus st. Good 4cyl hatches that can make great power when tuned/BT. Also sleepers
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
 Old 02-14-2018, 02:42 PM   #11
Groans: 203
My bad. I misread your post! Sorry that happened man.
 Old 02-14-2018, 04:50 PM   #12
Jeff23spl's Avatar
by the way is there a way to unmarry my ap if the wiring is burned or i have to pay cobb ?
Wife drive 2010 CX7
 Old 02-14-2018, 05:22 PM   #13
kTaLgsTo's Avatar
I am not sure, but I do know some other tuner companies can be used with an off board.
It's a home made job, you take the wiring going to your PCM and plug it into your PCM, give it desired power, hook up an OBD port and plug in the scanner. This obviously takes some wiring knowledge and what not, but can be used to unbrick PCM's and to unmarry tuners such as an AP.
It's the hard way, but probably cheaper than paying cobb if there isn't another way...
 Old 02-15-2018, 08:34 AM   #14
KiwiFlavor's Avatar
Posts: 2,443   (View Stats)
Drive down here to NH and buy my gen2!
But sorry to hear about your car
2012 NASA Spaceship Gray MS3
 Old 02-15-2018, 03:35 PM   #15
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,899   (View Stats)
Groans: 540
@Jeff23spl; did you run over a bucket?
94 M
06 MS6
 Old 02-16-2018, 10:33 AM   #16
Jeff23spl's Avatar
Not sure exactly what do you mean but I didn't run over anything special. (Do you mean a fuel bucket ? )
i'm not sure of the origin of the fire yet. Maybe the insurance will tell me....
Wife drive 2010 CX7
 Old 02-16-2018, 09:09 PM   #17
Pu Manchu's Avatar
Groans: 540
sometimes you run over a bucket and it breaks your oil line and burns your car.
sorry for your loss.
94 M
06 MS6
 Old 02-16-2018, 10:48 PM   #18
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
I second buying a piece of pu. Longer gears ftw. And smexier.
2010 black mica speed3
Soon:built motor
gen1 fsb fit on gen2? darkstar5440 Cobb Tuning 5 12-20-2013 07:38 AM
Gen1 TP on Gen2 MS3 DISIindahead 2010 MS3 - Engine, Transmission & Driveline 4 05-31-2010 08:41 PM
Are gen1 and gen2 cp-e rmm the same? speedster3 2010 MS3 - Engine, Transmission & Driveline 3 04-09-2010 02:46 AM
Page generated in 0.65170 seconds with 29 queries
