Notices
 Old 08-04-2012, 04:55 PM   #1
ztnedman1's Avatar
Posts: 172   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
Default My intake valves on Genpu with 72k miles
30k I did both OCC and EGR delete. For the most part I have seafoamed every(every other) oil change since the EGR and OCC.
Around 20k switched from penn plat to penn ultra.
Valves have never seen daylight or cleaning prior to this.
Not half bad IMO. I was expecting way worse. These were the worst couple, a couple didnt even have the ball of gunk on the stem.
2010 Red MS3/ Corksport SRI+TIP/ NATOR Downpipe + CS Racepipe (Catless FTW)/ AP+(E30)selftuned/ KMD v3 HPFP/ S.S brake lines + ATF superblue/ stoptech brakes/ JBM EGR delete/ SWAS disconnect/ JBM 80 RMM+80PMM/ Mudflaps/ itv22/ Rx8 wheels with Yoko S.drive245/40/18 (no rubbing issues)
ztnedman1 is offline   Reply With Quote
The Following 2 Users Say Thank You to ztnedman1 For This Useful Post:
m249saw (08-04-2012), Mase (08-05-2012)
 Old 08-04-2012, 04:57 PM   #2
Firemedic/Arms Dealer
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
Groaned at 7 Times in 6 Posts
Where do you get the Ultra?
Looks good, I really need to install an OCC
Sent telepathetically to my Razr Maxx
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is online now   Reply With Quote
 Old 08-04-2012, 05:29 PM   #3
ztnedman1's Avatar
My local autozone's carry the normal Penn ultra which I used to use. I just order the Euro version off amazon.
The Following User Says Thank You to ztnedman1 For This Useful Post:
 Old 08-05-2012, 12:18 PM   #4
m249saw's Avatar
Going to the 5w-40?
 Old 08-05-2012, 01:27 PM   #5
Scammer Hunter
Raider's Avatar
Posts: 14,937   (View Stats)
Groans: 449
Still pretty nasty! I take it you cleaned them, eh?
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is online now   Reply With Quote
 Old 08-05-2012, 01:45 PM   #6
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,539   (View Stats)
Groans: 68
Groaned at 91 Times in 65 Posts
Not totally bad for that mileage, there was on here with 30k that was a lot worse than that
 Old 08-05-2012, 01:51 PM   #7
KennyLogging
Mchart's Avatar
Posts: 793   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 53
It's too bad we don't have a gunk database. I know some oils will leave more deposits then others. Supposedly the M1 0w-40 / 5w-40 TDT doesn't leave as much buildup in DI applications.
IMO thats really not that bad for 70k miles. I have no idea how bad mine looks, but I plan on selling the car in a couple of years and it'll have 60k miles on it by then so I don't really care.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is online now   Reply With Quote
 Old 08-05-2012, 03:34 PM   #8
crankshaft's Avatar
Posts: 173   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
I'm probably gonna get brownie bashed for this.
Is the intake buildup really that much of a problem on these cars?
Is it a result of mods you do, or is the buildup an issue for unmodified cars?
What does Mazda have to say about it?
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 08-05-2012, 03:35 PM   #9
8.5MS3's Avatar
Posts: 3,721   (View Stats)
Groans: 296
Groaned at 34 Times in 33 Posts
design flaw
JBR 3.5" Intake, GTX3071r, Cobb IWG Blockoff, Cobb FMIC, Cobb BPV, DNP EWG Manifold, Tial 38mm Wastegate, Cobb DP, Cobb CBE, Cobb STS, Cobb SW, Cobb AP, 3 Bar MAP, GS EBCS, PnP Intake Manifold, CPE HPFP, CPE Safe Seals, CPE DH Mount, JBR BSD, PTP Windage Tray, MSD DH, SURE TIG's, MD OCC, EGR Delete, HTP Battery Box, JBR Trilogy 88 duro Mounts, JBR Shift Knob w/ Kritz Kock Rings, SeriouSpeed Slick Shift, Hotchkis Swaybars, Topspeed LCA Bushings, SPC Rear Camber links, Corksport Camber Plates, H&R Coilovers, Ford Tranny Juice, RA Mudflaps, 30% Tint, Corksport Interior LED Kit, Sonic Tuning 3k HID Fogs, Smoked Side Markers, SU Shifter Bushings, PG Towplate, Hawk HPS Pads, Centric High Carbon Rotors, DO Stage 2 Meth kit - 50/50 Mix D07, Custom Falcon Ceramic Clutch
322whp/361wtq - K04 #3
In a box: TWM Full Replacement, PCV Vacuum pump, Koyo Radiator, Perm PCV Kit
 Old 08-05-2012, 03:43 PM   #10
ztnedman1's Avatar
Originally Posted by m249saw View Post
Going to the 5w-40?
No still with 5-30. I tried 5-40 rotella but noticed more partial knock with no other obvious benefits so went back.
Yes, engine seems smoother at lower rpm/air speeds. Throttle response seems better too.
Recommend to EVERYONE!
Last edited by ztnedman1; 08-05-2012 at 03:43 PM. Reason: MSF Database - Automerged Doublepost
Cleaning the Intake Valves 802MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 42 06-17-2011 08:40 AM
Wow! 1900 miles and valves are caked vatordoc Gen2 MS3 General Discussion 41 04-25-2011 08:04 PM
intake valves with 82k miles, no catch can mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 10 04-08-2011 07:55 AM
Are Your Intake Valves All Guncked Up? SpdFreak MazdaSpeed 6 - Engine, Transmission & Driveline 131 07-31-2010 07:24 AM
Page generated in 0.32560 seconds with 27 queries
