  • 1 Post By Db09ms3
 Old 09-11-2019, 03:27 PM   #1
tripppleP's Avatar
Posts: 97   (View Stats)
tripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to behold
Groaned at 10 Times in 7 Posts
Default My next step?
I'm not really sure what to do next or what to read about next.
You can see what I added to my car in the signature. I have sourced a used CS catted TBE and want to toss that in in the future. I am also planning a TMIC or FMIC when I find a decent used one around locally.
I am not sure what would be the next step. Im going to read up on BCS next. I'm waiting to add the exhaust, and intercooler prior to getting a real tune. For now the OTS map is working well for me.
Any suggestions where I should direct my research and money?
2010 Black MazdaSpeed 3
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
JBR solid shift bushing
DM short shift plate
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
tripppleP is offline   Reply With Quote
 Old 09-11-2019, 03:51 PM   #2
Bertospeed3's Avatar
Posts: 148   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
do you have a goal?
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
The Following User Says Thank You to Bertospeed3 For This Useful Post:
tripppleP (09-12-2019)
 Old 09-11-2019, 03:57 PM   #3
Db09ms3's Avatar
Posts: 530   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 103
Peeps dig the ethanol, try that after you bolt everything on and get frisky with the E-tune. Don't know what else to tell you
danb likes this.
Stockish
 Old 09-11-2019, 06:57 PM   #4
tripppleP's Avatar
Originally Posted by Bertospeed3 View Post
do you have a goal?
No I don't. I really don't know a ton of car guys so I can't say I want my car ____ many HP. I don't know what my goal should be. I guess I kind of learn about a new part and try and buy it and put it in the car and whatever happens happens.
I actually and very happy with where the car is at now. But I enjoy the process of learning, working on the car and then being proud of the outcome.
Thanks for your input. I'll put that on my reading list. It this the "meth" people are talking about?
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
Last edited by tripppleP; 09-11-2019 at 06:57 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-11-2019, 08:49 PM   #5
Police - Grammarhead
Vansquish's Avatar
Groans: 1,909
Ethanol = the "E" in E85 or E35, or E15, etc.
Methanol = Meth
 Old 09-11-2019, 09:40 PM   #6
MSMS3's Avatar
Posts: 2,793   (View Stats)
Groans: 157
Install the catted DP and get a good custom tune. It will take some revisions to optimize it. Working with a custom e-tuner takes patience and time. Tune for 93 octane if available.
Stop then and enjoy for a while. You may be happy right there. You will have maxed out the K04 at that point, anyway at about 300-310 whp if done right. Maybe explore a tune for ethanol for 15-20 more whp.
Intercooler does not add power, it just keeps you from losing power due to heat soak and hit weather. A FMIC will increase turbo lag and spool time due to longer piping. It’s a trade off. I never found the benefit justified the extra length between intake and turbo.
I’d slow down at that point and get to know the car. Oh, yes, that’s what I did.
Any step by step guides to upgrading MS3 tripppleP Gen2 MS3 General Discussion 16 05-27-2019 06:32 AM
GM expands Maven 'step by step' toward competition with Uber, Lyft Haltech Automotive News 0 08-17-2017 06:30 AM
Step by Step Brake Job from Grassroots Motorsports FUB4R3D MazdaSpeed 3 - How-To's 36 06-14-2014 03:08 PM
Step by step fuel internals install vid... boosted_out 2010 MS3 - Fuel, Nitrous & Water Injection 60 05-03-2012 10:11 AM
Cut It Out: Toyota's recalled pedal modification remedy detailed step-by-step Haltech Automotive News 0 12-18-2009 12:10 PM
Page generated in 0.27589 seconds with 24 queries
