 Old 01-28-2012, 08:18 PM   #1
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
Default Need HELP,
I have to replace the two studs and two nuts that is going to the transmissions, I broke the thread during the TMM install, you can see the studs on the step 14 here:
http://jamesbaroneracing.com/support...structions.pdf
Any help would be appreciate, thanks in advance.
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline   Reply With Quote
 Old 01-28-2012, 08:25 PM   #2
bigriver's Avatar
Posts: 1,123   (View Stats)
Someone had the helicoils replaced since the studs came right out. I cant recall who it was but it was right around the time the jbr tmm came out.
If anything, give Jamie a call or email.
 Old 01-28-2012, 08:39 PM   #3
speeed's Avatar
Was skeurton, I think, already get help from Jaimie, I fix the transmission thread with helicoils, but now just want to replace the OEM studs and nuts....
2012 LSM MS3
 Old 01-28-2012, 09:22 PM   #4
bigriver's Avatar
oh, ok. read this from my phone so i didn't see you needed the part numbers.
Other than a dealer, I only know that Racing Beat has the Mazda part diagrams and OEM part numbers. I only saw the trans bracket on the diagram on Mazda online parts store, but not the bolts.
The Following User Says Thank You to bigriver For This Useful Post:
speeed (01-28-2012)
 Old 01-28-2012, 10:34 PM   #5
speeed's Avatar
@phate do you have the number part?
2012 LSM MS3
 Old 01-29-2012, 12:39 AM   #6
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The stud, itself, doesn't look to have a unique part# from the "mountings" section:
Let me know if you need the part#'s for any of the shown pieces. The numbers on the diagram correspond to a standard mazda part#, but I have to look that up. Too many beers in right now to be any more useful. Shoot me a PM or just mention me again, lol.
Edit, this might be helpful:
-06 MS6
-Corn fed 07 MS3 - Sold
atvfreek (01-29-2012), speeed (01-29-2012)
 Old 01-29-2012, 05:59 AM   #7
speeed's Avatar
@phate i think the numbers snould be
9YA90-1213
Thanks.
2012 LSM MS3
 Old 01-29-2012, 06:32 AM   #8
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
So the studs did wind up being stripped damn. Maybe a better way is to put bolts in with lock washers instead
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
 Old 01-29-2012, 09:58 AM   #9
Eth Fiend
phate's Avatar
9YA90-1213
Thanks.
Oddly, I can't find that part # reference. You should be able to show that to a dealer and get those for a couple dollars, though.
-06 MS6
Page generated in 0.29975 seconds with 22 queries
