Like Tree2Likes
  • 1 Post By BMC
  • 1 Post By BMC
 Old 09-06-2017, 06:59 PM   #1
BMC
BMC's Avatar
Posts: 160   (View Stats)
BMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond repute
Default Need help with fuel pressure drop ... again
If anyone has thoughts on this I'd appreciate hearing them ( for background info, see thread " Fuel Pressure Woes"). In brief, I had intermittent fuel-pressure-drop-problems earlier this year. After a fair bit of trouble-shooting, including replacing the fuel rail sensor with no luck, I sent the internals back to Autotech who put them on the flow bench and found them to be in need of replacement. They were kind enough to do this under warranty (and very quickly). It corrected the issue and I ran the shit out of my car all summer and had a great time.
That said, I started it the other day and by the end of my driveway, it had stalled. There had been no problems at all for 2-3 months. I was able to start it again several minutes later and got it back up the drive. I've attached a couple of logs.
I was crying the blues to a mechanic friend about how much of a bother the trouble shooting process is, when he suggested that I could eliminate the spill valve as the culprit by simply unplugging it and starting the car. He believes that if pressure builds and holds, then the spill valve is likely where the problem lies and not with the pump housing or internals. He believes the pressure will release at the max allowable through a release mechanism built into the pump. I am hesitant to try this as I don't understand the mechanics of the fuel pump and what it might do without the feedback it gets from the ECU. As always any thoughts would be appreciated. Thanks in advance.
Black 2013 w/tech - initial installs - all COBB; FMIC, Accessport V3, SF Cold Airbox, Short Ram Intake, Turbo Inlet Hose, 3" SS Downpipe, 3" SS Cat-back Exhaust, Rear Motor Mount, XLE BPV, Polyurethane Exhaust Hangers. Autotech Fuel Pump Internals, Greddy catch can, Freektune,
Most recent installs/swaps; BNR S4 , HTP 3" intake kit, , TIG intake to head, CPE EGR delete, Swift lowering springs, rear camber arms, CPE 75 duro driver and passenger mounts, ProMeth Tank, Aquamist HFS-4 V-3 w/m injection kit (to combat our absolutely garbage, 91 octane), (.8 & 1.0 jets), vent gauge pod, Nitto NT05s
370whp 380 torque on dynojet (with Aquamist, while running 2 gal. in-tank-meth) (more whp and torque since psi up a lb. or two but no dynojet update yet)
BMC is offline   Reply With Quote
 Old 09-13-2017, 09:38 AM   #2
BMC
BMC's Avatar
I like to close off my threads. Couldn't see the problem after pump disassembly/inspection and everything else seemed to be in order so I got a new pump. Problem solved. Expensive but with no feedback a week after posting (like did I offend the entire forum), options were limited. I know wahhh wahhh wahhh.
Bexar likes this.
The Following User Says Thank You to BMC For This Useful Post:
manu (09-17-2017)
 Old 09-13-2017, 09:45 AM   #3
Bexar's Avatar
Posts: 190   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Maybe people genuinely didn't know of any solutions to your problem ?
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off
Bexar is offline   Reply With Quote
The Following User Says Thank You to Bexar For This Useful Post:
BMC (09-13-2017)
 Old 09-13-2017, 10:28 AM   #4
BMC
BMC's Avatar
You're probably right. This forum has been very helpful over the years. Guess I'm just used to guys here jumping in with answers/suggestions. Plus, now that I've stopped sulking, it occurs to me that two huge centers are in the midst of dealing with the aftermath of some seriously f#cked up weather.
Bexar likes this.
Fuel pressure drop derek13p 2010 MS3 - ECU Computer Tuning 32 05-27-2013 10:24 PM
Logs showing 1 point of fuel pressure drop into the 100s breakfasteatre MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 12-09-2012 06:18 PM
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-03-2012 12:12 AM
Fuel Pressure Drop/Cut Burton MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-31-2012 07:43 PM
Fuel Pressure Drop after load of 2 dpolseno41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-17-2012 07:37 PM
Page generated in 0.26552 seconds with 22 queries
