![]() | | #1 | ![]() |
![]() Join Date: Jul 2014 Location: South Bend, IN
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score I'm planning out and budgeting my build im gonna tackle next summer, and after a ton of searching, I have a general idea of what i want to do, but would love to get some critiques, just in case ive been reading some outdated info or im just outright wrong. Right now i have a 2010 genpu with CS intake and apparently old TIP since it looks alot smaller than the 3" intake pipe, autotech internals, M2 catless downpipe, Autolite xp5263 gapped to .26, v3 AP and JBR 80 duro RMM. I'm looking to make 450-500whp with some room to grow if i want to. *Parts im planning on for turbo -GTX3076r with EWG hotside bundle from edge -90* elbow for dumptube -ETS TMIC -Bosch 3 bar MAP I'm also planning on building the bottom end a bit: -Manley H-beam rods -CP pistons -Edge engine stage 1 build kit with OEM rod and main bearings, main and head studs and cometic headgasket I also figure since i'll have the head off anyway, i should replace the timing chain, water and oil pump. While im doing that should i look at getting the crank balanced? Anything else i should get machined? I know one of the first things to get hit on is possibly choosing to go with a TMIC. I keep reading that on the genpu's that a FMIC isnt as necessary because of the functioning hood scoop, but i also see everyone default to "if you're going BT, go FMIC", but havent seen any real definitive reason why...can the TMIC not hold up to the extra boost? I know they have more heatsoak, but from what ive read they also have better response, so am i completely off base with going TMIC? Ive also noticed in a build thread it looked as if the M2 DP can crack at the weld at the flange, so i may need to replace that in the long run. Ive also noticed alot of people saying they need extra fueling at more boost, and i'll be honest, this is the one part i havent done alot of research on yet (working on it now), will a 5th port be necessary at this range? I'm planning on running e85 as i have it easily available. Are there any other bits and pieces im missing that are needed? Any tips from the guys who have been down this road already? It seems like alot of people were replacing the oil and coolant lines with some custom pieces for the turbo's, is that necessary with the GTX series bundle? Appreciate the help, i wana get this done, and do it right. I'd really rather now join the prestigious brotherhood of ZZB, so i'm taking the time now to get everything set straight in my plans so i dont completely fuck it up.
__________________ 2010 Red Mica Speed 3/ Autotech HPFP Internals/ M2 Catless DP/ V3 AP/ Corksport SRI and TIP/ 1 Step Colder Plugs .026 gapped Last edited by Ragnarok0mega; 08-28-2014 at 10:42 PM. Reason: Because i'm an idiot and cant spell |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
Groans: 24
Groaned at 166 Times in 32 Posts
| Not Ranked : 0 score What's a GTZ ? lol You didn't state your power goals...a 3076 is a fairly hefty turbo and it can definitely get you into aux fueling territory.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
(Thread Starter) | Not Ranked : 0 score somma bitch, i knew i was gonna fuck something up lol I'm looking for 450-500whp for the time being, but want to have some room to grow if i wana go more....from what ive seen the 3071 is good for people looking at the 450whp, but i havent seen much on them going beyond that so it just seemed like the 3076 would be the next step lol
__________________ 2010 Red Mica Speed 3/ Autotech HPFP Internals/ M2 Catless DP/ V3 AP/ Corksport SRI and TIP/ 1 Step Colder Plugs .026 gapped |
![]() | | #4 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score You probably want a clutch capable of holding that power with some longevity, and you'll definitely need more fuel. I've seen meth kits get people to 500whp, but you may want to go 5th port for the convenience and particularly if you want more power in the future.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following User Says Thank You to JgamB For This Useful Post: | Ragnarok0mega (08-30-2014) |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2013 Location: New England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
| Not Ranked : 0 score You'll want a bigger intake to add to your list. You'll definitely want meth too. And having the car fully mounted will also help. Don't forget to budget the tune as well. Murica'
__________________ Freektune (300 whp/ 349 wtq) Cobb Accessport/Autotech HPFP Internals/ HTP 3 Inch Intake/ Cobb Downpipe/ ETS TMIC/ Corksport Short Throw Shifter + Bushings/ JBR RSB/ JBR 88 RMM |
| The Following 2 Users Say Thank You to Frenchy11 For This Useful Post: | foodtime (08-30-2014), Ragnarok0mega (08-30-2014) |
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've seen some horror stories with meth, plus I'm not even sure where I could get methanol at lol, so I'm kinda leaning towards 5th port right now, and yeah a new clutch was part of the plan too, dunno why I didn't put it in the list... Trying to get everything done in one shot so I don't have to pull anything apart again later... Because I like to be lazy if I can... Tune definitely needs to happen, I've been self tuning with the k04 which has been pretty ok... But with Aux fuel and the bigger turbo and such, I definitely want someone who really knows what their doing to get all my engines ducks in a row haha.. Just gotta decide who Any input about the TMIC as far as usability with it being a genpu?
![]() | | #7 | ![]() |
| Not Ranked : 0 score I like the concept / simplicity of TMIC + meth, but if you're going 5th port, I don't know if that combination is symbiotic for BATs.
![]() | | #8 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score Sounds like you want to read my build thread. I am a hair shy of 500hp on a 3076 with just a DO10 meth nozzle. Mr.Speedy3's Up and Coming Build Then @Matrix311 has a 3071 with 463hp, same setup almost. Please welcome the newest member of the ZZB Big Turbo Club!
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
| The Following 2 Users Say Thank You to mr.speedy3 For This Useful Post: | JgamB (08-29-2014), Ragnarok0mega (08-30-2014) |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks man! Definitely some great reads and some good inspiration! When do you start seeing boost come on? I know even the gtx version of the 3076 has a considerable amount of lag vs our spool happy k04's and honestly I think that's a good thing to keep the stress off the engine at low RPM's and would probably help with wheelspin, but just curious as to when you're seeing it start to pick up. I'm definitely thinking our builds are gonna be really similar except I think I'm going to go 5th port over meth... It seems like a safer method and i like the simplicity in not needing to have to fill two separate tanks with different fuels. If anyone has experience with having run both set ups I'd love to know what your thoughts were between the two. While looking up parts for the engine build a buddy of mine who's building a gen Juan with a pte6266 said to look up speedperf6rmanc3 and said they could either build my block if I send it in or send me a block they built already. Any thoughts on going this route? Seems like a good choice being that I really don't want to have a huge amount of downtime (planning to take off about 2-3 days max to get it all done) and I'm not entirely sure how much time it would take to have a shop machine my block.
| The Following User Says Thank You to Ragnarok0mega For This Useful Post: | mr.speedy3 (08-30-2014) |
![]() | | #10 | ![]() |
With the 3076, I am 20psi by 4800. Full boost somewhere around 5200 I'd guess. Full is 28psi. However, if you get head work done (porting) the gtx3076r can spool to 20psi by 3k lol. I wish I did that. tapatalkin
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | |
![]() | | #11 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score Topmount and meth can work. I haven't seen anyone get the 5th/6th port to fit between the tmic and intake manifold. Fmic may be required to go that route.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() | | #12 | ![]() |
![]() Join Date: Nov 2010 Location: Smiths Station, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 816
Groaned at 46 Times in 21 Posts
| Not Ranked : 0 score 1. Buy a beater 2. Build a motor 3. Buy bt and supporting mods 4. E tune. Enjoy |
| The Following User Says Thank You to bigspender For This Useful Post: | mr.speedy3 (09-01-2014) |
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the replies guys! I'm actually thinking about doing the precision 5858 bundle from edge after doing some more research (and talking with my buddy about his precision build)... I'm definitely gonna have to start thinking about an fmic... Was really hoping to avoid that so I wouldn't have to cute my crash bar up haha
![]() | | #14 | ![]() |
| Not Ranked : 0 score You can get some front mount kits with an after market crash bar so you don't have to cut yours. Murica'
| Drop-in build, opinions (seriously) | mczimer | Mazdaspeed3/6 General Discussion | 99 | 02-01-2013 10:18 AM |
| First Build/Mod Plans..Opinions!? | flany13 | Mazdaspeed3/6 General Discussion | 16 | 02-03-2012 01:52 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
