Like Tree31Likes
 Old 10-21-2014, 12:20 PM   #121
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Lol.
"Exclusivity" - CP-enis
Demodded.
The Seals
chaser27 (10-21-2014), Mauro_Penguin (10-21-2014)
 Old 10-21-2014, 04:00 PM   #122
Yousuf's Avatar
Posts: 1,398   (View Stats)
Yousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the world
Groans: 128
LOL!!!!
Lol.
Haha you always roasting on jbr
Mod-bug's back...
Yousuf is offline   Reply With Quote
 Old 10-21-2014, 05:36 PM   #123
Tokay444's Avatar
Groans: 793
Because his shit sucks.
Demodded.
The Seals
 Old 10-23-2014, 06:53 AM   #124
JTMS3's Avatar
Posts: 2,306   (View Stats)
JTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the world
Groaned at 21 Times in 15 Posts
@ImGryssLOL; did you put the whole setup on the car before tightening it all down?
If not just loosen and readjust the piping and you should be okay. As for the CB, reverse the brackets as people have said and that should be AG as well.
Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah
4/15/12 dynojet results: 305whp / 355 tq
JTMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to JTMS3 For This Useful Post:
chaser27 (10-23-2014), Mauro_Penguin (10-23-2014)
 Old 10-23-2014, 10:24 PM   #125
ImGryssLOL's Avatar
Posts: 783   (View Stats)
ImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the world
yes, I put everything in and wiggled it together before I tightened anything. I was able to get the kit "Installed" in no time at all then spent a few hours trying to get it to fit correctly.
So update. I went back in and moved the "L" hangers from left to right. Little to no improvement.
And that is just for the piping, no fixing the fact that the crash bar doesn't line up at all to the upper rad supports and the hood latch support.
I contacted treadstone last week. Spoke to someone who told me he was going to talk to someone above him and have them call me back asap. Haven't heard back yet... (I talked to them last Friday.
2013 CWP W/ Tech" LS/VTEC swap running 9's
ImGryssLOL is offline   Reply With Quote
 Old 10-24-2014, 09:46 AM   #126
ImGryssLOL's Avatar
Called them this morning to see what was going on.
Had to start over from square one, had to reexplain everything, how I installed it, what doesn't fit, resend pictures. I asked who I talked to what happened to everything from last Friday when I called. No notes, no nothing. So whoever I talked to was just throwing out some lip service and hoping I would not call back I guess...
The Following User Says Thank You to ImGryssLOL For This Useful Post:
Mauro_Penguin (10-24-2014)
 Old 10-24-2014, 12:38 PM   #127
Tokay444's Avatar
Groans: 793
Yessir we want to have this work with the TR6-TR8-TR10 so all three options will be available.
Regards,
Tony Rodriguez /Sales & Marketing Supervisor
Demodded.
The Seals
 Old 10-24-2014, 02:03 PM   #128
aznvng's Avatar
Posts: 435   (View Stats)
aznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the worldaznvng is the leader of the world
I can say from the tr6 perspective that it fits. issues arise is from the way the upper hot pipe hits the a/c compressor line, so i pushed it slightly out of the way to attach the coupler to the lower hot pipe.
For tr6 users on the genpu, you have to mount the core with the inlets up top. if you mount the other way around the connecting pipes will not be able to reach to the cores inlets.
The cold pipe side is not as big of an issue but you will have to muscle it in underneath all the vacuum lines to connect to the throttle body. The recirc line for the bpv will have to be trimmed about an inch in order it to sit with the bpv without choking the line.
To properly mount the tr6 underneath the crash bar you will want to use @RPM; tr6 brackets for the genpu. Reason is because its the only efficient way of connecting the core to the air dams that you will have to remove. unless you can guinea pig some mounting option to the crashbar but the way the core sits the inlets will be in the way. i don't have pictures at the moment but hope this helps. Other than that it fits and works well BATS are well 30 degrees cooler than my old tmic setup.
2013 Mazdaspeed 3 - stock as fuck
aznvng is offline   Reply With Quote
 Old 10-24-2014, 03:10 PM   #129
ImGryssLOL's Avatar
Do you have any crashbar fitment issues?
Do you have pics of your bar on with no bumper?
 Old 10-24-2014, 04:16 PM   #130
chaser27's Avatar
Posts: 1,276   (View Stats)
chaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the world
Groans: 42
Groaned at 16 Times in 12 Posts
Originally Posted by RPM View Post
I just read that thread and called Treadstone. They said they've only shipped two kits. They said they were aware of issues with one of them. This customer received a prototype crash bar because he didn't want to wait for the production run. The issue was that the holes for the brackets didn't line up because they were off by a half an inch and Treadstone assured me that this was resolved prior to the production run. Everyone that's a part of this group buy will receive production pieces.
Quoting from a different thread, but it looks like you have a prototype crashbar anyway, since you told them you couldn't wait.
So we will get a better one
Coming at ya with all 297/359
POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP
ECU: self-tuned
HANDLING: JBR RSB (Middle Setting)
RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc.
RADAR: Passport Escort 9500ci
chaser27 is offline   Reply With Quote
The Following 3 Users Say Thank You to chaser27 For This Useful Post:
ImGryssLOL (10-24-2014), Mauro_Penguin (10-28-2014), Tokay444 (10-24-2014)
 Old 10-24-2014, 04:25 PM   #131
ImGryssLOL's Avatar
You would think they would tell me this.
I was told I would get a steel one instead of aluminium. Not a prototype that didn't fit.
chaser27 (10-24-2014)
 Old 10-27-2014, 09:19 PM   #132
RusianKid's Avatar
Posts: 353   (View Stats)
RusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the world
I was actually going to buy that prototype kit, but decided not to. I believe there were only 2 prototype kits: yours and Mx52star's.
They told me the same thing "steel bar...fits perfect...no modifications"
Hopefully they will straighten you out...
"RACING IS AN ADDICTION CURED ONLY BY POVERTY"
RusianKid is offline   Reply With Quote
 Old 10-28-2014, 04:03 AM   #133
Tokay444's Avatar
Groans: 793
Open the holes.
Add washers.
Demodded.
The Seals
 Old 10-28-2014, 10:53 AM   #134
ImGryssLOL's Avatar
Open the holes.
Add washers.
Fuck that, paid 900$.
If I bought some chinese knock off hobo shit fuck yeah I'll figure out how to make it work. But I paid for a complete working kit, that isn't what I received
 Old 10-28-2014, 11:00 AM   #135
chaser27's Avatar
Groans: 42
Damn. I'm glad I waited for the group buy :troll:
ECU: self-tuned
 Old 10-29-2014, 09:36 AM   #136
ImGryssLOL's Avatar
So I called monday morning, spoke with someone who said Tony would be calling me back asap to get something resolved... Never got a call back.
Call Tuesday morning and ask for Tony, He says comminucating through email is easier and he will email me back asap. No response by end of day...
Not sure where to go from here. LOL
 Old 10-29-2014, 09:55 AM   #137
jeopardy98's Avatar
Posts: 1,920   (View Stats)
Groans: 112
Well I certainly hope we have better luck with the group buy kits. I'll reserve judgement for now. Sounds like you need to be a little more assertive at this point.
jeopardy98 is offline   Reply With Quote
 Old 10-29-2014, 11:43 AM   #138
RusianKid's Avatar
I dealt with Tony when I was trying to buy the prototype kit.
He was doing the same to me, I just called him every day to remind him.
He is probably the reason I did not end up purchasing the kit, and now have a bad feeling about Treadstone all together.
Remember; The Squeaky Wheel gets the Grease!
Good luck...Keep us updated, this will show everyone their customer service
 Old 10-29-2014, 12:31 PM   #139
ImGryssLOL's Avatar
So as it stands now I think there is some posotive resolution, I will keep everyone posted once it happens. Don't want to jinx myself.
But I think they we are going to meet in the middle and they are going to do the right thing.
chaser27 (11-01-2014)
 Old 10-31-2014, 03:56 PM   #140
ShadowHunter117's Avatar
Posts: 55   (View Stats)
ShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to behold
Thanks for all the updates on your install. I hope things turn out well. This kit looks like a very good deal and I am tempted to get it as soon as I have the money. I currently have a TR6 core with CX Racing piping, but I could have got a full kit with crash bar like they are offering for close to the same price if it had been around sooner. Including the built in meth bung is a very nice touch too!
ShadowHunter117 is offline   Reply With Quote
 Old 10-31-2014, 04:29 PM   #141
keychain12's Avatar
Posts: 239   (View Stats)
keychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the world
Still think a cx racing kit + tr8/tr6 + DM throttle body meth spacer is a better option for most.
Modify crash bar can cause insurance to reject your potential claim :/
ATP GTX2867r | CP-e 3" catted TBE | HTP 3.0" Full inlet & intake | CX Racing piping w/ Treadstone TR8 FMI | HPFP | EGR Delete | Grimmspeed EBC | Forge V2 BPV | Thermal Intake Gasket | NGK Plugs | 3.0 bar Map | Devils Own WMI w/ d07 Nozzle | Cobb AP
Dynojet Dyno:
92 pump gas tune: 326whp & 320tq
24psi tune w/ WMI: 349whp & 351tq
26psi tune w/ WMI: 360whp & 364tq
XXR 531 18x8.5 [+35mm] | Dunlop Sport 225/40 | Cobb Springs | JBR Rear camber arms | JBR 80 RMM | Hotchkis front & rear SB| SS brake lines | Corksport CC | MSD Dashhawk |Custom Stealth Sub Box by user: JTMS3
keychain12 is offline   Reply With Quote
 Old 10-31-2014, 04:34 PM   #142
Didn't know that about the crash bar and insurance. Any users here had issues because of it? I have some time to think about it, so I may just go with the piping kit only in the end, or whatever piping kit JBR ever ends up coming out with.
2011 Black Mica MS3
Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned
Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3
Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank
 Old 11-07-2014, 11:53 AM   #143
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
neganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the world
Groans: 49
The methanol bung plug totally seized up in mine resulting in me having to drill it out and re-tap the hole as a 7/16ths. Don't use that aluminum plug, go purchase a bolt that fits.
neganox is offline   Reply With Quote
The Following 5 Users Say Thank You to neganox For This Useful Post:
chaser27 (11-07-2014), Easter Bunny (11-08-2014), ImGryssLOL (11-07-2014), jeopardy98 (11-08-2014), Mauro_Penguin (11-07-2014)
 Old 11-07-2014, 02:25 PM   #144
ImGryssLOL's Avatar
Mine was real crunchy and I was worried about leaks, with some liquid teflon tape it sealed nicely
The Following 3 Users Say Thank You to ImGryssLOL For This Useful Post:
jeopardy98 (11-07-2014), Mauro_Penguin (11-07-2014), neganox (11-07-2014)
 Old 11-07-2014, 02:41 PM   #145
Feline Führer
neganox's Avatar
Groans: 49
Mine was more like... "oh this is tough.. oh there it goes.. ahhh fuck."
The Following 2 Users Say Thank You to neganox For This Useful Post:
chaser27 (11-07-2014), Mauro_Penguin (11-07-2014)
 Old 11-07-2014, 02:42 PM   #146
jeopardy98's Avatar
Groans: 112
Mine was the same. Only threaded half way. Totally cross threaded. I'm hoping Teflon tape will cure it.
 Old 11-07-2014, 02:47 PM   #147
keychain12's Avatar
This kit is getting worse by the post
Dynojet Dyno:
The Following 2 Users Say Thank You to keychain12 For This Useful Post:
Easter Bunny (11-08-2014), faeker (11-07-2014)
 Old 11-07-2014, 02:58 PM   #148
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Yeaaah, makes you wonder how much Rd they put into every part instead of just piping.
Mods: stock
 Old 11-07-2014, 02:59 PM   #149
jeopardy98's Avatar
Groans: 112
Well I won't tell you about my coupler they are having to replace then.
The Following 2 Users Say Thank You to jeopardy98 For This Useful Post:
 Old 11-07-2014, 03:03 PM   #150
ImGryssLOL's Avatar
Is it the turbo to hotpipe coupler?
Mine is the same size to turbo as it is to hotpipe, I ordered a tapered one from turbo hoses that would actually fit correctly
 Old 11-07-2014, 03:05 PM   #151
jeopardy98's Avatar
Groans: 112
You should have called them. No mine was cut by hand with a pair of scissors it appears. The owner said some 16 year old kid was cutting them. He is sending me a replacement.
The Following User Says Thank You to jeopardy98 For This Useful Post:
 Old 11-07-2014, 03:47 PM   #152
chaser27's Avatar
Groans: 42
My meth bung plug stripped at the Allen key after maybe three threads. I had two layers of Teflon tape on there and took some vise grips to try and get it out. Was stripping the outside, so I just said fuck it and let it in. It's not going anywhere. My turbo to coupler pipe was also cut by hand but it seals so no cares
ECU: self-tuned
 Old 11-07-2014, 03:54 PM   #153
RusianKid's Avatar
well...
CXracing piping with a TR6 is starting to sound pretty good
The Following User Says Thank You to RusianKid For This Useful Post:
keychain12 (11-07-2014)
 Old 11-07-2014, 04:01 PM   #154
chaser27's Avatar
Groans: 42
Oh and I talked to my Allstate agent specifically about the front crash bar replacement and they assured me it wouldn't be an issue. I'll admit I was not impressed with the Treadstone kit after the meth bung plug stripped and the one coupler is a Bitch to get to if you don't have the car raised. The pipes weren't perfectly parallel there, but after taking it out and being able to hold 2 more psi at 6k on a k04. I am more than happy
ECU: self-tuned
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
Easter Bunny (11-08-2014), Mauro_Penguin (11-07-2014)
 Old 11-07-2014, 07:00 PM   #155
Feline Führer
neganox's Avatar
Groans: 49
I'll be installing my kit tomorrow with a DM plat . Hopefully no fitting issues.
 Old 11-07-2014, 08:16 PM   #156
jeopardy98's Avatar
Groans: 112
I'm a little miffed about this kit and the customer service. I'll update once it is resolved.
 Old 11-07-2014, 08:32 PM   #157
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Wait you took the kit off and it cause that big of a presure drop?
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 11-07-2014, 09:56 PM   #158
Mx52star's Avatar
Posts: 262   (View Stats)
Mx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the worldMx52star is the leader of the world
All I can do is encourage you to contact TRE, if you have an issues they will fix it! The owner and managers are great people and will help you solve any issue you have.
My kit which is the orginal is holding up great, my meth bung is perfect, crash bar fits perfect, and piping fits perfect. Fit n' Finish and efficeny should be TRE's middle name, so please be patient as they solve these intial hic-ups. Because I promise you they will make it right and you will love the kit on your speed!
MODS: Baller under glow bro
Mx52star is offline   Reply With Quote
 Old 11-07-2014, 11:41 PM   #159
jeopardy98's Avatar
Groans: 112
Well the owner is the one that I'm having the issue with. And some guy named Victor. Hopefully they will fix it though.
 Old 11-08-2014, 07:09 AM   #160
chaser27's Avatar
Groans: 42
Sorry I should have made that more clear. After I took my car out with the new kit and was clearly able to flow more air after 2 revisions, I was sold. When I was installing it. I was hesitant.
ECU: self-tuned
The Following User Says NO Thank You to chaser27 For This Un-useful Post:
RusianKid (11-09-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/new-treadstone-front-mount-intercooler-kit-177170/
Treadstone Performance Mazda Speed 3 Intercooler Kit | Treadstone Performance INC. This thread Refback 09-15-2014 06:14 PM
Do Yourself FMIC w/treadstone fmic I Love Brownies MazdaSpeed 3 - How-To's 140 02-13-2013 09:18 AM
Page generated in 0.57501 seconds with 34 queries
