![]() | | #281 | ![]() |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
Groaned at 16 Times in 12 Posts
| Not Ranked : 0 score
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
![]() | | #282 | ![]() |
![]() Join Date: Jan 2012 Location: Prince George, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,068
Groans: 112
| Not Ranked : 0 score Any update on whether the offset coupler solves the fitment issue on the poor connection behind the radiator?
__________________ Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed. [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to jeopardy98 For This Useful Post: | chaser27 (12-01-2014) |
![]() | | #283 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score I'm planning on trying to get this installed this Thursday using the extra couplers I purchased. Will report back.
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | jeopardy98 (12-01-2014) |
![]() | | #284 | ![]() |
![]() Join Date: Jul 2013 Location: Merritt Island, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score The hump coupler really didn't help a lot. All it really did was allow a bit more flexibility at that joint.
__________________ MODS: Baller under glow bro |
| The Following User Says Thank You to Mx52star For This Useful Post: | jeopardy98 (12-01-2014) |
![]() | | #285 | ![]() |
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score |
![]() | | #286 | ![]() |
| Not Ranked : 0 score I got a 30-degree and two hump couplers.
![]() | | #287 | ![]() |
| Not Ranked : 0 score Got the TR6 and Treadstone piping on last night. Using the 30* coupler to join the two hot pipes and one hump coupler on the cold side of the IC I was able to get satisfactory connections everywhere. Here are my notes: FMIC mounting: ============ The inlet/outlet of the TR6 sits about half an inch lower than than they do on the TR8 when installed with the Treadstone crashbar based on the pictures I've seen and comparing them to how mine installed. Getting them higher is limited by the OEM crashbar as the top of my TR6 is basically hitting the bottom of the OEM crashbar as installed, so you can go ahead snug up the mounts as high as you can get them right at the start. Cold side piping: ============ I started working from the cold side, connecting the reducing coupler to the TB and getting it clamped, which was a bit of a PITA. I ended up undoing the t-bolt clamp completely and then fighting to get it back together and tightening it in its final resting place. Next I inserted the cold pipe into the coupler and placed the clamp (again by undoing it completely and putting it back together in place), but left it loose. You'll want to make sure that the clamps are placed in such as way that the bolts don't interfere with, or have a chance of rubbing, the TB coolant lines. Down at the FMIC, the cold pipe does not line up so some muscle and the hump coupler were used to make the connection. With the cold pipe clamp at the TB loose enough to have some play, but not loose enough to come out of the coupler, I was able to pull the pipe down to line up with the IC outlet. I highly recommend slipping the coupler all the way onto the cold pipe and then sliding off and over the IC outlet when it is lined up as the distance between the pipe and outlet is small, making it difficult to attach the coupler to one and then slide the other in, if that makes sense. The hump coupler provided some extra play here (and helps make a better connection IMHO), but I think it would be possible to just use the coupler from the kit. Originally I installed the t-bolt clamps with the bolt at the bottom facing the front of the car. This caused a problem getting the bumper back on because the bolt was hitting. I flipped the clamps over with the bolt at the top, facing forward and it posed no issues with the bumper. At this point I tightened all clamps on the cold side. Hot side piping: ============ The 30* coupler made all the difference in the world here and I would recommend everyone to get one before attempting this install; perhaps Treadstone or @RPM; might even consider adding one to the kit, at least for the TR6, although I believe it will benefit even the TR8 customers getting the pipes to "align" for a good connection. I started by attaching the 30* coupler to the end of the upper hot pipe and clamping it loosely. This took some trial and error to get the angle of the coupler to where I wanted it for connecting to the lower hot pipe. Once I got that coupler oriented properly I loosely attached the hot pipe to the turbo and placed the bolt on the stud for the pipe mount location to keep it from popping off. * I used the washer and rubber grommet from the TMIC underneath of the hot pipe mount, but it was not obvious that I should; I think it is better this way. From under the car, I used a ratcheting wrench to snug up the clamp on the top hot pipe. The extra length of the 30* coupler provided plenty of adjustability to get the lower hot pipe aligned and connected to the IC and it presented no issues at all. Again, at the IC, place the bolts of the clamps at the top facing forward. Total time for install was about 4 hours, but I took my time, had to readjust the clamps at the TB before attaching the coolant lines and I had to remove and install the bumper one extra time to reorient the clamps at the IC. Hopefully my errors will save someone else some time. TL;DR :: At a bare minimum get a 30* coupler for the upper to lower hot pipe connection.
| The Following 10 Users Say Thank You to Mike@Stratified For This Useful Post: | chaser27 (12-05-2014), Easter Bunny (12-05-2014), jeopardy98 (12-05-2014), JgamB (12-05-2014), kidlifecrisis (12-05-2014), Lex (12-10-2014), Mauro_Penguin (12-05-2014), Mx52star (12-05-2014), RPM (12-05-2014), stanley0910 (12-05-2014) |
![]() | | #288 | ![]() |
Groans: 112
| Not Ranked : 0 score Thank you immensely for that!
| The Following User Says Thank You to jeopardy98 For This Useful Post: | Mike@Stratified (12-05-2014) |
![]() | | #289 | ![]() |
![]() Join Date: Dec 2014
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Looks decent. Will defiantly keep this kit in mind |
![]() | | #290 | ![]() |
![]() Join Date: Jan 2014 Location: Manchester CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 694
| Not Ranked : 0 score I'm still waiting on my replacement pipe... weeks now |
![]() | | #291 | ![]() |
![]() Join Date: Nov 2012 Location: Hayward, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score HAS IT BEEN TWO WEEKS YET? OH MAN I CRACK MYSELF UP
__________________ 2013 CWP W/ Tech" LS/VTEC swap running 9's |
| The Following User Says Thank You to ImGryssLOL For This Useful Post: | Mauro_Penguin (12-07-2014) |
![]() | | #292 | ![]() |
| Not Ranked : 0 score Oh, I forgot to mention, I used the tap they sent and that all worked out. Sent while Stratified.
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | Mauro_Penguin (12-07-2014) |
![]() | | #293 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
| Not Ranked : 0 score You never got it? You should have PM me. I'll call them tomorrow. |
| The Following User Says Thank You to RPM For This Useful Post: | Mauro_Penguin (12-07-2014) |
![]() | | #294 | ![]() |
![]() Join Date: Jan 2012 Location: Wood Dale IL
Rep Power: 0 ![]() ![]() Thanks: 1
| Not Ranked : 0 score Do you have a link to the right coupler?
![]() | | #295 | ![]() |
| Not Ranked : 0 score Not at the moment, but someone posted it in this thread somewhat recently. Sent while Stratified.
![]() | | #296 | ![]() |
| Not Ranked : 0 score | |
![]() | | #297 | ![]() |
| Not Ranked : 0 score I talked to Treadstone (Tony, and Jason, the owner) regarding the hot-pipe coupler issue and they have ordered a batch of 20-degree couplers that they will ship to anyone who has ordered a kit and requests one. They are having them custom-made, since 20-degree couplers aren't easy to come by, so it will probably be somewhere between 3-5 weeks before they have them in hand to ship out. If you want one, shoot me a PM with your order number and I'll put you on the list. |
| The Following 4 Users Say Thank You to RPM For This Useful Post: | Easter Bunny (12-10-2014), Jeremy M (12-10-2014), kidlifecrisis (12-10-2014), Mauro_Penguin (12-10-2014) |
![]() | | #298 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Thought I give you guys a bit of info on my setup. I ordered up the TR8L and I already had the cobb FMIC setup. The TR8L you have to drill new holes to accomodate the larger version of the TR8 (takes like 5mins). 20141210_142124_Richtone(HDR).jpg The passenger side I drilled about 5/8" to the left: 20141210_140219.jpg The driver side I drilled about 2" to the right: 20141210_142135_Richtone(HDR).jpg With the cobb piping, they have a bracket that bolts down where the TMIC would be so it provides little movement to adjust (at the same time it prevents the hot pipe moving around while driving) hot pipe bracket.jpg All buttoned up, I would say it's offset to the driver side maybe 1" but I don't notice it. 20141211_080311.jpg I wanna give props to JBR and RPM with helping my order. Both were great with communicating and will have my business as long as they provide the great customer service! |
![]() | | #299 | ![]() |
| Not Ranked : 0 score Now that all has been figured out with the kit and I assume the modifications have been made on your kits, how is everyone liking the kit? I am in love with my kit.
![]() | | #300 | ![]() |
| Not Ranked : 0 score @pdc001; The tr8l is for low boost applications not high boost like our cars run. It will still get the job done just not as efficiently.
| The Following 2 Users Say Thank You to Mx52star For This Useful Post: | ASHMS3 (01-18-2015), Easter Bunny (01-24-2015) |
![]() | | #301 | ![]() |
Groans: 112
| Not Ranked : 0 score Any update on the couplers?
![]() | | #302 | ![]() |
| Not Ranked : 0 score Mine worked with the straight coupler with zero issues, but I will admit, the 20 degree coupler makes it a lot easier to install and gives a little more flexibility.
| The Following User Says Thank You to Mx52star For This Useful Post: | Mauro_Penguin (01-19-2015) |
![]() | | #303 | ![]() |
| The Following User Says Thank You to dockinstation For This Useful Post: | chaser27 (01-20-2015) |
![]() | | #304 | ![]() |
| Not Ranked : 0 score Couplers are on the way to the 4 guys who requested them. |
| The Following 4 Users Say Thank You to RPM For This Useful Post: | chaser27 (01-28-2015), Easter Bunny (02-04-2015), jeopardy98 (01-29-2015), Mauro_Penguin (01-28-2015) |
![]() | | #305 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score Just keep in mind that RPM has been doing a pretty good job cleaning up the mess created by Treadstone. Kudo's to them for putting you guys first.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
| The Following 7 Users Say Thank You to faeker For This Useful Post: | chaser27 (01-29-2015), Cheapspeed (01-30-2015), Easter Bunny (02-04-2015), jeopardy98 (01-31-2015), JgamB (01-30-2015), Mauro_Penguin (01-29-2015), smoogs12 (01-29-2015) |
![]() | | #306 | ![]() |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Are the newer kits having issues as well or was this just the first batch? |
![]() | | #307 | ![]() |
| Sanctioned MSF Peddler ![]() Join Date: Nov 2014
Rep Power: 146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
It is equally as frustrating for us as well. RPM is also a customer in this situation. Forgive me if I misinterpreted what you said.
__________________ --- www.theRPMstore.com --- ![]() Need a COBB AccessPort and/or Autotech internals? We offer the best pricing on these parts! Shoot us a PM! NEED FINANCING? We've got you covered with TWO unique options! Click for details! Turbo upgrade bundles now available for BNR AND ATP turbos. Save up to $225! Email Pat@therpmstore.com | |
| The Following 4 Users Say Thank You to Pat@RPM For This Useful Post: | dockinstation (02-02-2015), jeopardy98 (01-31-2015), Mauro_Penguin (01-30-2015), trancehead (01-30-2015) |
![]() | | #308 | ![]() |
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Mike@Stratified; 01-30-2015 at 06:27 AM. | |
![]() | | #309 | ![]() |
Groans: 42
| Not Ranked : 0 score Not that i've heard of, but I'm more than happy with @RPM; customer service. They have gone above and beyond what is expected of them. The only other thing I'm considering changing with my kit it to switch to their special worm clamps with the spring and thread protector thing since I'm not a fan of T-bolts.
| The Following 5 Users Say Thank You to chaser27 For This Useful Post: | dockinstation (02-02-2015), JgamB (01-30-2015), Mauro_Penguin (01-30-2015), Pat@RPM (01-30-2015), smoogs12 (01-30-2015) |
![]() | | #310 | ![]() |
| Not Ranked : 0 score Treadstone never offered anything other than sending out taps, bungs, and couplers to people. I know you tested the 30-degree coupler, which ultimately led to them ordering the 20-degree couplers, so I'd be happy to offer you a GC or discount on anything you need. |
| The Following 3 Users Say Thank You to RPM For This Useful Post: |
![]() | | #311 | ![]() |
![]() Join Date: Dec 2013 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 60
Groaned at 27 Times in 15 Posts
| Not Ranked : 0 score I was going to order this kit tuesday but now I am scared lol. I cant have my daily driver down.
__________________ 2011 Speed3 Tech- GTX3071 EWG Ceramic Coated hotside - ATP DUMP - TIAL 38MM External Wastegate - HTP 3.5" Full intake - COBB DownPipe - 3 Bar Map w/ FastBits Adapter - Grimmspeed EBCS - Forge V2 - JBR Battery Tray - 51r Battery - Matt Damond VTA OCC - Matt Damond Full EGR Delete - Denso Step Colder Plugs - Treadstone TR6 - CX Piping Modded for gen2 - JBR SSP/Solid Bushings/Heavy Knob - JBR RMM - SURE TMM - SURE PMM - AutoTech Internals - AP v2 Tuned BY NISHAN - Sonic Tuning S3 Coilovers - SPC Camber Arms - TSW Intelagos Rotary Forged - Conti Extreme DW - StopTech Pads - SouthBend Stg 2 Endurance - FUTURE MODS Built Bottom End - 5th Port - Meth - Exhaust Manifold - CatBack Exhaust - Slicks |
![]() | | #312 | ![]() |
| Not Ranked : 0 score No need to worry. They have corrected the issues. Those being the meth bung and the new silicone.
| The Following User Says Thank You to Pat@RPM For This Useful Post: | Mauro_Penguin (02-02-2015) |
![]() | | #313 | ![]() |
| Not Ranked : 0 score So no fitment issues with the crash bar or other pipes not lining up? If so I am in. I am installing a ewg gtx3071 and dont need any headaches.
| The Following User Says Thank You to itzjustme407 For This Useful Post: | Pat@RPM (02-01-2015) |
![]() | | #314 | ![]() |
__________________ --- www.theRPMstore.com --- ![]() Need a COBB AccessPort and/or Autotech internals? We offer the best pricing on these parts! Shoot us a PM! NEED FINANCING? We've got you covered with TWO unique options! Click for details! Turbo upgrade bundles now available for BNR AND ATP turbos. Save up to $225! Email Pat@therpmstore.com | ||
![]() | | #315 | ![]() |
| Not Ranked : 0 score Ok so I will purchase through you since I am sure you have all the updated kits. Besides the fact that your price beats everyone elses advertised. Thanks for the help.
![]() | | #316 | ![]() |
| Not Ranked : 0 score You'll definitely get the latest kit with all of the issues addressed. At this point, there should be no more issues with this kit. |
| The Following User Says Thank You to RPM For This Useful Post: | Mauro_Penguin (02-02-2015) |
![]() | | #317 | ![]() |
| The Following 4 Users Say Thank You to kidlifecrisis For This Useful Post: |
![]() | | #318 | ![]() |
| Not Ranked : 0 score I am glad you were able to get it all installed and it is working well! I am still unsure how it fit so well the first time for me. I had the first ever kit too. But I am glad everyone is starting to get the issues either fixed or figure out.
![]() | | #319 | ![]() |
| Not Ranked : 0 score SEeing that picture made me question whether I tightened those clamps after I took the picture. I did not. Fixed that in office attire in the parking lot before driving home lol. |
| The Following 5 Users Say Thank You to kidlifecrisis For This Useful Post: | chaser27 (04-13-2015), dockinstation (04-13-2015), jack_hammer (04-14-2015), jeopardy98 (04-13-2015), MD1032 (04-14-2015) |
![]() | | #320 | ![]() |
![]() Join Date: Oct 2013 Location: Saint Simons Island, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score Just so everyone knows. I just got one in yesterday and the crash bar still doesn't fit. Wish i just bought the piping and core and got the jbr crash.
__________________ Slow for now... Cobb ApV3///Cobb SRI+TIP///JBR Solid Shift Bushings///JBR 88 RMM///JBR SSP/// JBR Shift Knob///Cobb EBCM///MSR 045 18x8 +35///Nitto Nt05 235/40/18///CS Batt Box///CS Catted DP///ITV22's///Autotech Internals///TR8 FMIC///Koni FSD's/// CS springs Freek Tuning Meow |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/new-treadstone-front-mount-intercooler-kit-177170/ | ||||
| Treadstone Performance Mazda Speed 3 Intercooler Kit | Treadstone Performance INC. | This thread | Refback | 09-15-2014 06:14 PM | |
| Do Yourself FMIC w/treadstone fmic | I Love Brownies | MazdaSpeed 3 - How-To's | 140 | 02-13-2013 09:18 AM |
