-   -   No Love from ST Fanboys (http://www.mazdaspeedforums.org/forum/f544/no-love-st-fanboys-114941/)
themytb 05-30-2012 04:32 PM
I think going after yota's share would be suicide for mazda, Toyota has a rep for boring but dependable cars. Mazda has a much more driver oriented rep. Not that mazda has bad quality or sells only sports cars, not extremely one sided. It's the old performance/quality/affordable---- pick 2 saying.
If mazda tries to switch to the boring side completely, they loose all the people who want a drivers car-- and it will take a long time to become peoples first choice in the practical/dependable game over Toyota.
I may be completely off. Just my 2 cents. I really hope Mazda stays true to their roots in the future.
86AmishMs3 05-30-2012 05:46 PM
"There seems to be a general misunderstanding over there about the torque vectoring control and electronic compensation for torque steer. They are not the same, brakes will not be applied to reduce torque steer, and the engine will not be limited in the first 2 gears, as the MS3 does.
I'm really looking forward to being able to compare more than numbers here, and have more than estimates. Hopefully, the afpcus ST is out this August.
Page 12 over there.
Hahhaa they keep speaking of torque vectoring. It has no lsd, sounds like no power compensation in lower gears.....how are you going to prevent torque steer for the limp wristed. Gonna sweet talk it? Whisper sweet nothings in the car's ears?
Sorry brakes are going to be used. Only plausible action with open diff. Thats what torque vectoring is. Have these retards not read their own reviews?
Standsideways 05-30-2012 06:03 PM
5 New Hatchbacks We Want to Drive - Ford Focus ST - Popular Mechanics
these guys say the ford uses the brakes
Darth_Nuruodo 05-30-2012 06:35 PM
Electronic power assist steering tightens up and holds the wheel for you so you don't hurt your puny chicken wrists. I want a sport fwd's solution to torque steer to be a light
on the dash that lights up "Don't be beetch." And that's it.
fredricktsang 05-30-2012 06:36 PM
By braking the unloaded tire/wheel on the drive wheels it can force the load to go to the loaded tire. This in essence is what some people call the poor mans lsd. I can't say it's effectiveness in all conditions vs a physical lsd but under conditions where one drive wheel becomes unloaded and looses grip, it definitely can help. I'm sure they also do something similar to our dsc where they brake the inside wheel to help the car "rotate". I just signed up for the focus st event, look forward to it!
OverBoosted 05-30-2012 06:40 PM
I believe that ford claims their electronic power steering system will stop the torque steer. Not the torque vectoring, which is for wheelspin. I'm not sure how that will work, seems like it wouldn't be strong enough to stop it with the torque the engine will produce.
I guess time will tell though.
Here is a quote from a car and driver review,
—In between is electric power assist, which is the heart of the car’s torque-steer-compensation system. When the system senses an imbalance of torque to the front wheels, it reduces the steering assist in the direction the steering wheel would normally be yanked. The result, we’re told, is similar to that of theRevo Knuckle—strut from the—previous Focus RS—(a 300-hp Focus also never seen stateside) but without the extra cost and weight of  the advanced strut design.
Also, the torque vectoring system CANNOT be turned off.
Tapatalked
Crarrs 05-30-2012 07:13 PM
Originally Posted by Lex (Post 1436778)
Nothing worse than people comparing cars on paper.
Limited slip Watson? Unnecessary!
The biggest fail argument in the thread regarding their torque vectoring vs. LSD:
Originally Posted by ButtDyno
I ask again, do you really think this will be better than a mechanical diff?
Originally Posted by MacAttack
In some ways yes, in other ways no. On one hand, it's cheaper, on the other hand I think it will put a bit of extra wear on the brakes. Although, one could argue that because it allows drivers to brake less in the turns, that it'll actually save brakes.
Yeah....entering the corner 0.2 mph quicker is going to totally offset the fact that the brakes are being applied while accelerating through corner exit. One page earlier this jackass claimed his comparison's bias didn't make him a fan boy. That seems like total bullshit the marketing department came up with. "Torque vectoring: Now with longer-life brake components!"
BigRedSpecial 05-30-2012 07:24 PM
Serious question here... with our LSD the wheels will try to stay more-or-less equally powered assuming an equal surface... say the dragstrip. With their electronic substitute, when the brakes slow the powered wheel, wouldn't the sudden shock load greatly increase the probability of the other wheel breaking traction?
I know the system will then respond to that and have millisecond response, but still seems like a clusterfuck to me.
86AmishMs3 05-30-2012 07:25 PM
Mechanical >>>>> Electrical, in every performance aspect.
86AmishMs3 05-30-2012 07:33 PM
Usually all these delays are what makes electrical systems such a nuissance...since there are slight delays they always err on the safe side.
Hence why i disconnected the steering wheel angle sensor as well as others...it's intrusive and hard to predict. Mechanical is not hard to predict and the driver learns and compensates.
Dumyz 05-30-2012 07:59 PM
Curious what our members will have to say after driving the ST's... Hopefully I can give a FYFN call out.
OverBoosted 05-30-2012 09:12 PM
Depending on when they hit the dealerships, I might be working at a ford store again so I will definitely report back.
Tapatalk ed
Lex 05-30-2012 09:21 PM
AT high speeds the ELSD will not be as harsh but at low speeds it will be cumbersome. The CSRT-4 has an ELSD and that car sucked ... well for several reasons ... going around corners. It's already bad enough this thing is FWD, people looking for true performance will drop in a mechanical LSD.
08cosmic3 05-30-2012 09:53 PM
I can't wait to run into one on the street and shatter their confidence. Anyone over at the Focus forum live near Bowling Green Ky then look for a Cosmic Blue gen 1 around town. Tuned by the man above.
Neverlift 05-30-2012 09:56 PM
I decide how the car corners... not some fucking mad scientist in the computer/braking system.
The only thing I would need a computer for is to compensate for my impatience and little man syndrome so I could finally get some decent mpg's.
Cujo 06-10-2012 01:43 PM
FYSTN
johnnyspeed6 06-10-2012 02:12 PM
Ecoboost 2.0 comes factory with forged rod and crank = Win. Wife has one in the 2012 escape and its a freakin great motor in that heavy bastard ..
MS3 > Rod smasher
FYDISIN
tddvrrn 06-10-2012 02:16 PM
i believes our rods are forged. just not very well, i guess..
Lex 06-10-2012 02:21 PM
MS3 > Rod smasher
FYDISIN
Lol this again. Wait until they start blowing in performance applications as well.
Our crank is forged so are our rods (powder forged).
The Ecoboost is just an advancement of the DISI. Don't expect it to hold 400hp without a shortened lifespan.
johnnyspeed6 06-10-2012 04:45 PM
True dat ..
CaptObvious75 06-11-2012 11:14 AM
June 10 2012 First drive review:
2013 Ford Focus ST First Drive
"Countersteer isn't uncommon when driving the Focus ST hard. Try that in your Mazdaspeed 3"
"But even in hatchback form, the 2013 Ford Focus ST is going to give the current Mazdaspeed 3 the battle of its lifetime. Not many cars in this class have had both the handling and the horsepower to match Mazda's potent five-door until now."
Still can't see how this will be better track- wise than our cars, but it def seems to be more hardcore then the GTI. Nice ride from my unbiased opinion, and i'd take this over the GTI if I were choosing between the two.
Dr. Speed 06-11-2012 12:26 PM
Yeah, the lack of a REAL LSD is a deal-breaker IMO...
Darth_Nuruodo 06-11-2012 12:47 PM
Since everyone's expecting this to have a stronger aftermarket out the door than we do even today, my money's on that will be one of the first big parts available for this car. I'm actually glad there's another hot hatch out there to run with us, get some more attention on the market, hopefully we benefit from this too.
Bubba Ho-Tep 06-11-2012 07:00 PM
Competition is good for the consumer....us. :)
Lex 06-11-2012 07:27 PM
If the ST takes off, I will probably be tuning them as well.
xb2ms3 06-11-2012 08:24 PM
Nothing wrong with a little healthy competition.
They're raising the bar pretty high with the interior on the ST.
Those ST wheels dont look too shabby 18x8.5...wonder what the offset is on those.
Specs look good on the car but doesn't look like its gonna dethrone the king of sushi rolls. Not in stock form.
Darth_Nuruodo 06-11-2012 08:39 PM
Cobalt SS?
Dumyz 07-22-2012 02:55 PM
Has anyone here gotten in the drivers seat yet??? A few of their performance academy classes have already been completed!
New York's: June 30th
D.C.'s: July 14th
Boston: Yesterday, July 21st
Tokay444 07-22-2012 03:15 PM
The interior is AMAZING.
But that's something VAGs say.
GunGuru727 07-22-2012 04:23 PM
D.C.'s: July 14th
Me:)
Go to my NATOR thread.
I will be posting a video of me beating it soon.
kashbringer 07-22-2012 04:23 PM
It'll be good competition that for sure.. It'll always be a focus though! Less horsepower and torque from the factory and no LSD... /yawn
breakfstincluded 07-22-2012 04:45 PM
When DSPORT chose the MS3 as FWD King for 2012...
"We tested the MAZDASPEED3 on MD Automotive’s Dynojet 248Cdynamometer to validate these claims. Our dynamometer testingindicated 244.36 horsepower and 270 lb-ft torque (at the wheels) whichcalculates to 287.5 flywheel horsepower and 317.65 lb-ft torque. The testplatform actually produced 24.5 horsepower and 37.65 lb-ft torque morethan Mazda’s specifications, indicating that the MAZDASPEED3 more than delivers the goods."
Top Choice FWD 2012 - MAZDASPEED3: Threepeat for the SPEED3 — | DSPORT Magazine #108
Pope 07-26-2012 05:28 AM
70 percent of those people who are getting one will be payed for from the parents because there all emo teenagers, ill be looking forward to adding a FYFN sticker and smokin some bitches.
PS. Their proffessional? what part of talking shit about the other rides and stating there car is far superior when it hasnt hit the streets yet proffessional?. They say were the children? i LOL in their faces.
Tokay444 07-26-2012 06:16 AM
If anything we're the forefathers.
Tokay444 07-26-2012 07:31 AM
Originally Posted by Tokay444 (Post 1528136)
Lol. That efr is a baby.
There is no way it's gonna flow 440hp's worth of air.
I'll put this over here too since I know those fegs are reading it.
Tokay444 07-26-2012 07:38 AM
Hahahaha.
Turbofold!!!!!
SRTie4k 07-26-2012 07:47 AM
I really hate it when people say stupid shit like this. Who cares what the base car is? The SRT-4 was always "just a neon", the SS/TC was "just a cobalt", the Evo is "just a lancer", the STI is "just an impreza"...and the MS3 is "just a 3".
Who gives a fuck what the car is based on? Does that make it any less potent an adversary if it is tuned well, and performs well? Each and every one of those cars were rated best in class at one point or another.
Take your head out of your ass and quit with the fanboy bullshit. A good, solid, purpose-built car that ups the ante and competes in the market is a good thing - it forces other manufacturers to up their game as well, and the only ones that win in the end is us - the consumers.
CaptObvious75 07-26-2012 07:57 AM
Amen brotha
Sent from my Atrix
zmarko 07-26-2012 08:09 AM
I agree. I think another hatch with a large following will help us all in the long run.
Interesting. I think the interior is absolutely dreadful.
kashbringer 07-26-2012 08:35 AM
I give a shit because the focus is an ugly ass base platform... Always has been. No fanboy shit here, fuck I almost bought a wrx then went over and got my ms3. No matter what the numbers the car will always just be an ugly focus to me. As I said it'll be good competition for us all but I would not buy it. You very well can't say you would buy a car you thought was ugly as fuck.
Page generated in 0.21165 seconds with 11 queries
