 Old 03-28-2012, 07:36 AM   #1
KrishyC's Avatar
Posts: 3   (View Stats)
KrishyC will become famous soon enough
Default Not Hitting Boost?
Hey Guys,
Pretty new to the forum just looking for some ideas. I have a 2010 MS3 with CSRI Corksport TIH, Boost Tubes, Magnaflow Exhaust and Cobb AP. When I get on the gas im only hitting 12 or 13 pounds of boost any ideas?
Thanks Guys
KrishyC is offline   Reply With Quote
 Old 03-28-2012, 08:00 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
1. What map are you running on the AP? (OTS)?
2. Check and make sure everything that flows air in the engine bay is tight!
3. Posting a log would help!
4. Make sure you are actually pressing the throttle all the way down...
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline   Reply With Quote
The Following User Says Thank You to leon78 For This Useful Post:
rfinkle2 (03-28-2012)
 Old 03-28-2012, 08:09 AM   #3
KrishyC's Avatar
1) I am Running Stage 1 Corksport SRI 93 TIH
2) I have checked that but I will check that again.
3) I will try and get some logs later on today.
4) I don't think that's an issue lol
5) would it be possible i damaged the boost control solenoid when installing the TIH would that cause low boost?
 Old 03-28-2012, 10:44 AM   #4
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Well you have the car in front of you. Look to see if the nipples are broken off. Posting a log will get you a definet answer. And to save you some time in case you dont know: 3rd or 4th gear start at 2500 rpm slam foot down untill 6500. Good luck.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
 Old 03-28-2012, 12:25 PM   #5
KrishyC's Avatar
You were correct hose from intercooler to motor came off. Hitting 20 pounds no problem now! Thank You!
The Following User Says Thank You to KrishyC For This Useful Post:
leon78 (03-28-2012)
 Old 03-28-2012, 03:59 PM   #6
rherold9's Avatar
Posts: 135   (View Stats)
rherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the worldrherold9 is the leader of the world
Groaned at 38 Times in 16 Posts
Why is there no FP on this list of mods!
rherold9 is offline   Reply With Quote
 Old 03-28-2012, 08:57 PM   #7
CJM
CJM's Avatar
Posts: 231   (View Stats)
CJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the world
Groaned at 5 Times in 2 Posts
Whoa, you're hitting 20 pounds on an OTS Stage 1 map?
You should probably lower your WGDC values... a lot.
2010 LSM Speed3
Twinscroll .82 A/R GT3071 | Boost Junkyz Mani | 44mm TiAL MV-R
CXRacing/RPM Piping + TR8 | HTP 3.5" Intake | AT Internals | Forge V1
Premier Auto Modified ATP Long DP | JBR RSB | Other Miscellaneous Shit
Tuned by Me
CJM is offline   Reply With Quote
 Old 03-28-2012, 09:06 PM   #8
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
In before blown rod or blown head gasket. I told you guys, with just intake mods, anything over 17psi just creates heat and not power. Log log log. Look at BATs vs MAF airflow, You have yourself there a Borg-Warner flame thrower. Until you get exhaust side freed up (Magnaflow exhaust does not count, sorry) leave the boost targets at 16.5psi or less! An occasional spike to 18 or even 19 psi is ok but on stage1 you should never see 20psi or more even during a boost spike. I personally wouldn't even log that car until you bring the boost targets to 16.5psi or less and wgdc to no more then 80% !!!
2012 Black Mica MazdaSpeed3
Street creds:
 Old 03-28-2012, 09:06 PM   #9
Police - Grammarhead
Vansquish's Avatar
Groans: 1,909
^^ THIS!!!!
Unless you've changed your commanded boost levels, the OTS Stage 1 maps shouldn't go above 17.5lbs I don't think. If you're running 20lbs of boost, then you're asking to grenade your motor, as you don't have the supporting mods to make that level of boost safe.
Stage 2... Not hitting full boost 2010Speed3 2010 MS3 - Troubleshoot/Diagnostics 27 06-14-2018 07:47 PM
OTS Map Not Hitting Boost Targets kahunab14 MazdaSpeed 3/6 - ECU Computer Tuning 53 02-18-2012 10:30 AM
Not hitting boost targets again (AP).. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 28 08-01-2011 05:35 PM
HELP!!!!Not Hitting full boost anymore!!!! dadon1985 2010 MS3 - Troubleshoot/Diagnostics 22 04-10-2011 09:19 PM
Not hitting full boost Post pwned 2010 MS3 - Turbo Induction 10 11-28-2010 01:22 PM
Page generated in 0.29470 seconds with 26 queries
