 Old 04-11-2015, 12:22 PM   #1
csmaan12's Avatar
Posts: 325   (View Stats)
csmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond repute
Default The ole clutch vibration issue.
Okay so I've searched and read here on how to diagnose for bent rod, and I'll be leaving work early to do that today. Will measure rod height asap. Story is below.
My symptoms at the moment...while driving I can feel like a tap on the clutch pedal when I rest my foot on it, it does increase when I give more gas, but it completely disappears if I let go of the gas and let the car engine brake.
For example in 4th gear at 3k RPM, vibes are felt, if I let go of gas but still in gear no vibes at all. It almost matches the my exhaust note when I accelerate. At idle, very very slight vibrations are felt, but do not increase with revving the engine.
For comparison sake, I drove two other cars to see if there is any difference. On my friends 2013 gen coupe, absolutely smooth as butter. On my friends 2015 Mustang Ecoboost, feels similar to my clutch but not quite the same. Probably irrelevant to mention this since it's not another MS3 but figured I'd mention this anyway.
I'll mention the car runs quite well, I go WOT like once a day because I love how hard it pulls after I got the Stratified OTS+ tune. It feels great and as it should when you get on it. My only doubt is that if it had a bent rod, with the way I drive it, wouldn't it have vented the block a long time ago? I've had the car for just about one year now and im starting to get paranoid as hell.
Anyways thanks for reading, input welcome.
2011 Mazdaspeed3 Mod List:
FREEKTUNED
ETS TMIC
Autotech HPFP Internals
CS Stage II SRI + TIP
Tial QR
UR Catback
UR Catless Test Pipe
Damond RMM
Damond SSP
csmaan12 is offline   Reply With Quote
 Old 04-11-2015, 05:57 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
When I bent my rod (s), at idle, when I just touched the clutch petal, it felt like ABS pulsations, but as soon as I pressed it in some, that all went away. Did you do something to suspect you bent a rod? ie. WOT at 2k rpms or something?
If it is a bent rod, I was able to hear more "ticking" noise from the engine at idle as well.
Good luck
 Old 04-11-2015, 11:47 PM   #3
csmaan12's Avatar
Good luck
Ah doesn't quite feel like that at idle. If I press the clutch in all the way I can't feel anything.
I did end up measuring the pistons at TDC though. All looks to be okay. 3 people telling me all heights are the same vs. me being paranoid saying cylinder 4 was a teeny tiny bit low. We measured twice with same results every time so I'm calling it in favor of not bent. I really hope that I'm the wrong one here.
My main concerns are the random KR I get sometimes when I don't even boost, but in the 3k+ RPM range and register KR with just easing into it. Sometimes I don't get KR at all no matter how I drive. Its really weird. I've taken the car almost to red line in 4th gear and had 0.00 KR from 3k all the way to 6.3k.
Now I have to keep digging to figure out why my clutch is vibrating like it is because I really don't like that at all.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 04-12-2015, 08:34 AM   #4
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Does your gas or brake peddle vibrate too? all mine vibrate right now but it's been like that since i put different mounts on.
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 04-12-2015, 09:42 AM   #5
csmaan12's Avatar
Yes, sometimes I can feel it, sometimes I can't. Even if it does its a lot less compared to clutch.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 04-12-2015, 02:15 PM   #6
Colepidd55's Avatar
Yeah, sounds kinda like what I have. Do you have any knock at wot?
SOLD
2009 CWP Speed3
 Old 04-12-2015, 02:23 PM   #7
csmaan12's Avatar
Yes, but usually it's a very tiny amount lower in the RPM range. Usually end up seeing like 0.34-0.48, when I first get on it, but as it climbs higher in the RPM range there's virtually none.
I rarely see anything above 0.88. Sometimes I get 0 no matter what I do or how I drive, WOT or PT. Part throttle is a different story, but I guess it's common in 2010+.
I think I may have a leaky BPV or a boost leak somewhere, I just can't find it.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 04-12-2015, 03:08 PM   #8
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Dual mass flywheel...
timmcc02 is offline   Reply With Quote
 Old 04-12-2015, 05:06 PM   #9
rigor's Avatar
Posts: 2,399   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
you only feel it when you put light pressure on it, that is a bent rod i just bent 2-4 rods about a month ago, when i depressed the clutch i felt nothing
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
rigor is offline   Reply With Quote
 Old 04-12-2015, 05:31 PM   #10
csmaan12's Avatar
Do you mean more pressure than just resting foot on it? Like I mentioned, all rods measured out the same according to everyone BUT my paranoid eyes.
If it's the dual mass flywheel I'll be happy to replace that with a lightweight.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 04-12-2015, 05:59 PM   #11
rigor's Avatar
Groans: 40
ya just starting to put pressure on it
its not that hard to pull the pan and check
idk if the duel mass would do that, it kinda feels like someone is tapping on the bottom of your foot, depends how they bend though
mine were pretty close like barley different in height but i was comparing two bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
Easter Bunny (04-12-2015)
 Old 04-12-2015, 06:06 PM   #12
rigor's Avatar
Groans: 40
the way id do it is friday night pull car in, drop oil leave plug out overnight, sat morning pull pan, access situation. if all good put pan back up let sit till sunday afternoon, fill with oil / filter .
otherwise if you rush the seal it will leak!
it only takes 20 min tops to pull the pan good luck
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
Easter Bunny (04-12-2015), MD1032 (04-14-2015)
 Old 04-12-2015, 06:51 PM   #13
csmaan12's Avatar
Hmm okay I'll have to do it next weekend or next oil change then because I use my car a lot. Do I have to re-seal the oil pan with new gasket or can it be reused? I don't mind dropping it if it means that I will be 100% sure that I don't have a bent rod. I'll be doing a compression test too.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 04-12-2015, 07:51 PM   #14
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Its not a gasket. You have to use a sealant.
I hugged rfinkle2
csmaan12 (04-13-2015), smurugby12 (04-15-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/ole-clutch-vibration-issue-187069/
The ole clutch vibration issue. This thread Refback 08-28-2015 10:59 PM
Clutch Pedal Vibration (Dont think its a rod) VegasChef MazdaSpeed 3 - Engine, Transmission & Driveline 18 04-22-2013 06:55 PM
Clutch pedal vibration mariob215 MazdaSpeed 6 - Engine, Transmission & Driveline 13 03-17-2013 12:49 PM
Clutch Vibration in neutral? riderice MazdaSpeed 6 - Engine, Transmission & Driveline 22 12-25-2011 12:42 PM
clutch vibration? maybe? Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 6 08-14-2009 01:38 PM
Clutch pedal vibration Overboost3 MazdaSpeed 3 - Engine, Transmission & Driveline 59 04-13-2009 02:48 AM
Page generated in 0.34687 seconds with 25 queries
