Like Tree8Likes
 Old 11-17-2012, 09:10 PM   #41
leon78's Avatar
Posts: 2,595   (View Stats)
1982 toyota tercel...jk...already got that....lol
But a 2013 SHO is next on my list.
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline   Reply With Quote
 Old 11-18-2012, 08:12 AM   #42
jlsspeed4's Avatar
Posts: 66   (View Stats)
jlsspeed4 is a name known to alljlsspeed4 is a name known to alljlsspeed4 is a name known to alljlsspeed4 is a name known to alljlsspeed4 is a name known to alljlsspeed4 is a name known to all
Ohh, if I live in a warmer climate all year around, I'd def get a cbr/r6 and track it.
jlsspeed4 is offline   Reply With Quote
 Old 11-19-2012, 01:42 PM   #43
crankshaft's Avatar
Posts: 576   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Originally Posted by Keko View Post
Do you have a build thread or something for the Buick? I'm pretty curious whenever I see it
It's nothing spectacular really. It was my daily driver for 8 years and I kept it stock, upgrading stuff when parts failed. I took it to the track once when it was stock with a chip and fuel pressure regulator. It ran low 13's that day and badly needed traction/driver mod. I had an alcohol kit on it for a while. It was CRAZY, but it was old and I didn't repair it when the pump failed. At 230k miles the original engine stared a slight knock, so I parked it until I could get a decent build.
I had a moderate street strip build done 2 years ago. I have the standard stuff: roller cam and timing set, new pistons, ARP fasteners, ported factory heads, and a laundry list of little goods that I can't specifically recall - all the good stuff. Also accumulated during it's DD years: TA49 turbocharger, 42lb injectors and matching "modern" chip, PTS extreme shift kit, cold air kit, fuel pump and hotwire, etc.
I would expect that I should be in the 12's as-is, and pushing mid to low 12s with a new alcohol kit. I need to buy sticky tires. Full throttle is just a tire boiling extravaganza. It's fun for show, but not for go. Before I go doing that, I'm going to do some TLC: paint and some interior.
Traded in: 2012 MS3, CWP
2019 Dodge Charger Scat Pack
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
The Following User Says Thank You to crankshaft For This Useful Post:
MZRSPEED (11-19-2012)
Page generated in 0.32174 seconds with 22 queries
