 Old 09-10-2018, 07:56 PM   #1
Boostlee21's Avatar
Posts: 4   (View Stats)
Boostlee21 is an unknown quantity at this point
Default One step colder plugs
I'm currently in the process of starting my build after finally buying all of my aftermarket parts, my goal is to achieve the most power possible on the Ko4 turbo, but I'm unsure if I need to buy a one step closer plug or not and if I do which brand is highly recommended NGK or Denso, and lastly can some provided a part number so I know exactly what to buy if I need to buy a set.
Boostlee21 is offline   Reply With Quote
 Old 09-11-2018, 04:53 AM   #2
Mothra's Avatar
Posts: 1   (View Stats)
Mothra is an unknown quantity at this point
NGK 6510 is the one step colder plugs
Mothra is offline   Reply With Quote
 Old 09-11-2018, 06:49 AM   #3
Fstrnyou's Avatar
Posts: 2,383   (View Stats)
Groans: 24
I use Denso ITV22 for 1 step colder. But I've heard NGK is the way to go.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-11-2018, 10:39 AM   #4
Bertospeed3's Avatar
Posts: 110   (View Stats)
Bertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud of
I'm on NGK 6510 gapped to .028. Running smooth as hell. Got them from RockAuto for like $5 a piece.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
 Old 09-11-2018, 01:41 PM   #5
MSMS3's Avatar
Posts: 2,507   (View Stats)
Groans: 141
NGK 6510. They come with a huge gap and must be closed up to .026-.028".
I doubt they are needed even at "full bolted" K04 power levels, but I run them because of the 3" catless dp/rp I am running. I might even get a couple horsepower more at stock heat range, but they to give me little insurance against knock, since my tune has about 18 degrees of timing advance and I am not seeing any knock retard correction (pulling timing) on my logs.
Generally you want the hottest plugs that don't cause timing to be pulled on your tune, but the coldest plugs that don't foul, especially in daily driving.
For our car with maxed out K04 and mods on pump gas (about 300-310 whp) you are right on the line for heat range between stock and one step colder.
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Thor Hammer (09-11-2018), zxhoya (02-13-2019)
Do I need step colder plugs? drenkel 2010 MS3 - Engine, Transmission & Driveline 1 07-13-2010 12:43 PM
1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 12-13-2008 03:17 PM
Page generated in 0.26369 seconds with 24 queries
