-   -   Plug Change (http://www.mazdaspeedforums.org/forum/f544/plug-change-182276/)
marco427 01-03-2015 07:46 AM
Plug Change
Couple of questions: how many miles on the OEM plugs before I should replace? Also, how much of a pain the ass is it to pull the intercooler to get to the plugs? The factory manual calls for removing just about everything but the fuel tank, which seems like overkill.
smoogs12 01-03-2015 07:52 AM
Pulling the intercooler should only take about 5 minutes. Thats really the only thing that you need to remove.
marco427 01-03-2015 07:59 AM
The factory workshop manual wants the battery, tray, etc, to come out first. BTW, thanks for the input.
Code Monkey 01-03-2015 08:16 AM
Must be looking at a Porsche workshop manual.....
Orangatang 01-03-2015 08:38 AM
Just remove tmic and your good. Remove 3 nuts and a few hose clamps.
AshFromCan 01-03-2015 04:36 PM
No pain in no asses. The intercooler comes right off. Put the manual down and just look at it.
ASHMS3 01-04-2015 11:50 AM
How else would the dealership charge you 3 hours of labor for plus? Seriously though one you really look at it you will see its easy as hell.
Using bad grammar from my cell phone.
littleloogy 01-04-2015 12:26 PM
20,000 on these stockers, they still work great. NGK makes a great long lasting plug. http://tapatalk.imageshack.com/v2/15...55c4d5af64.jpg
MD1032 01-06-2015 03:48 PM
60k miles. It's in the maintenance schedule in the owner's manual like every other car out there. If you see 120k in there, you're in the wrong section, that's for non-Mazdaspeed models. I don't know why ours only last half as long, but why question the manufacturer on things this cheap?
The NGK part number is SILTR6A-7G for OE replacement. If you add significantly more power, you must use a colder plug and change them more often...this and more can be found using the magical "search" feature...
itzjustme407 01-07-2015 12:26 AM
My dealer told me 100k. I changed them around 55-60k and the car felt smoother.
PapaBruno 01-07-2015 11:38 PM
I'm planning on swapping out my original plugs out for the NGK one step colder plugs in the next month when I hit 30K mi.
Just make sure they are gapped properly. I've never changed plugs before, but I'm sure it won't be that difficult. Helps that I already have an FMIC. [emoji6]
makjur 01-08-2015 04:35 AM
http://www.edgeautosport.com/manufac...plug-set-of-4/
Once your tuned for stage 2 Cobb recommends you change them every 15k miles
If your stock or stage 1 I don't think there is a point in going lower then stock temp
marco427 03-01-2015 08:44 AM
Plug change completed. The original plugs looked like shit at 66000 miles, and the gaps had opened up to .035" plus. My only problem was dropping a socket and extension onto the undertray, but my creative woman rigged up a magnet on a string to retrieve it (I hate working under cars). Thanks for the encouragement all.
boostedminime 03-01-2015 09:15 AM
SOUNDS LIKE I NEED NEW PLUGS
Orangatang 03-01-2015 11:35 AM
If the under tray is there and I drop a tool, screw, or socket onto it i just bounce the tray up and down till it falls off the back side of the tray.
boostedminime 03-01-2015 11:41 AM
I do the same get under and hit the tray a few times
Page generated in 0.17796 seconds with 11 queries
