Like Tree6Likes
 Old 09-01-2015, 09:58 AM   #41
speedfreak44's Avatar
Posts: 1,391   (View Stats)
speedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the worldspeedfreak44 is the leader of the world
So for us to get an exact pressure drop number we would need to do the test in a vacuum chamber? This would rule out any drop in temps correct? Not that I could do that
The line up:
2013 G37 loaded...not stock for long
2013 MS3...stock to midturbo back to stock (traded)
2009 Nissan Frontier LE loaded...big stereo system (traded)
2009 Cadillac CTS sport package...stock (blown and traded piece of shit)
1994 Integra RS built all motor (sold)
1990 Civic EF nitrous turbo motor swapped beast (sold)
1987 Dodge pick up...jacked up (sold)
speedfreak44 is offline   Reply With Quote
 Old 09-01-2015, 10:14 AM   #42
Yatta's Avatar
Posts: 1,862   (View Stats)
a comparative irrespective of temperature will still give you some good data, if you really want to gauge what the IC restriction is, measuring pressure in, temperature in and pressure out, temperature out will allow you to figure out how much pressure drop is due to decrease in charge air temp and how much is due to internal restrictions.
The Following 2 Users Say Thank You to Yatta For This Useful Post:
xfeejayx (09-01-2015), zenit (09-01-2015)
 Old 09-01-2015, 10:54 AM   #43
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
PV=nRT
I hugged rfinkle2
The Following 3 Users Say Thank You to Easter Bunny For This Useful Post:
MS3Shadow (09-01-2015), xfeejayx (09-01-2015), zenit (09-01-2015)
 Old 09-01-2015, 04:25 PM   #44
PV=nRT
While we are doing formulas....
engineering > me
me = healthcare field
The line up:
The Following User Says Thank You to speedfreak44 For This Useful Post:
WetzMS3 (09-03-2015)
 Old 09-01-2015, 04:30 PM   #45
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
someone big turbo with an aftermarket tmic just run two logs one stock one aftermarket
like to see what those logs would look like.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 09-01-2015, 06:05 PM   #46
Voltwings's Avatar
Posts: 3,713   (View Stats)
Its been years, so this is somewhat useless, but i had my GT3071 go through the stock TMIC and my ETS.
14 psi spring would only hit ~10 psi on stock intercooler, would run ~14-15 on the ETS. No boost leaks.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 5 Users Say Thank You to Voltwings For This Useful Post:
mxlplx71 (09-01-2015), speedfreak44 (09-02-2015), WetzMS3 (09-03-2015), xfeejayx (09-02-2015), zenit (09-01-2015)
 Old 09-02-2015, 08:21 PM   #47
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
K04, lost 2 psi going from ets 3.5" to stock.
Same boost tune, so I imagine boost error comp increased wgdc to try to make up the difference.
-Wetz
QFT
 Old 09-02-2015, 08:26 PM   #48
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Did you both hit similar MAF voltages?
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
 Old 09-02-2015, 09:04 PM   #49
Voltwings's Avatar
Again, YEARS ago, i dont have any of that data any more.
Past:
-Sold-
-Sold-
Current:
The Following User Says Thank You to Voltwings For This Useful Post:
SarcasticOne (09-03-2015)
 Old 09-03-2015, 06:10 AM   #50
xfeejayx's Avatar
Groans: 78
Same, been a while. I'd except MAF was higher with the ETS.
Somewhat relevant discovery last night. I've been running the cp-e tmic without a shroud (Mounting hole threads were iffy, and the shroud sits on the welds. Also didn't think it'd make a huge difference)
Long story short, Tuna noticed high BATs, I put the shroud on, BATs went down 30-40F.
Without the shroud, it just never recovered from heat soak. Spraying with water also reversed the heatsoak almost immediately. Good to know for AX. Spray bottle ordered.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
 Old 09-03-2015, 06:51 AM   #51
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Installing a washer nozzle in top rear of the scoop works well to combat heat soak
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 09-03-2015, 07:04 AM   #52
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I would really like to see some data. Would you guys be interested in seeing differences between the stocker and my CP-E TMIC at all if I threw the stocker back on and took it out for a spin on the same night with the same tune? My current tune commands 100% WGDC in the top end, so any differences should be pretty obvious because my K04 is going balls to the wall up there. Thank god for methanol. Shouldn’t need to really change anything else in the tune honestly based on my limited experience.
That's a good idea in theory, but the SCCA at least does not allow active cooling systems. I was told I would not be allowed to autocross with such a system (been there, done that) in place.
2007 Mazdaspeed3 GT
The Following User Says Thank You to MD1032 For This Useful Post:
 Old 09-03-2015, 07:59 AM   #53
In an ms6 i got 10g/s more across all rpms and 20 degree cooler bat's with a minimal increase in boost pressure on the same map, same road, about a half hour inbetween the pulls.
(Going from stock to cpe with shroud)
 Old 09-03-2015, 08:30 AM   #54
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
@Awal, do you happen to have any before/after logs for your CS tmic you could contribute? OCD builds benefit everyone
crap, why can I never remember how to tag
"I apologize for nothing!" - Hedonismbot
Last edited by aromig; 09-03-2015 at 08:30 AM. Reason: MSF Database - Automerged Doublepost
aromig is offline   Reply With Quote
The Following User Says Thank You to aromig For This Useful Post:
Awal (09-03-2015)
 Old 09-03-2015, 08:38 AM   #55
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
@aromig;
it's like this @Awal;
you forgot the ; after the username
aromig likes this.
The Following 2 Users Say Thank You to MS3Shadow For This Useful Post:
aromig (09-03-2015), Awal (09-03-2015)
 Old 09-03-2015, 02:13 PM   #56
aromig's Avatar
Originally Posted by MS3Shadow View Post
@aromig;
Got it, thanks. Love the avatar btw.
 Old 09-03-2015, 04:06 PM   #57
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
Right. But you can do water injection anywhere in the air tract intake to exhaust in the street prepared class and do passive cooling in grid.
Easter Bunny (09-03-2015)
 Old 09-03-2015, 05:37 PM   #58
When I swapped to my OEM tmic my g/s barely changed. 5 max so I think it is a null value.
My cooling on many many logs showed the stock tmic outperforming the ets constantly.
Someone do a quick swap of intercoolers to see some logged outcomes. Do logs same day probably 3 total of each intercooler and do an average comparison.
The line up:
 Old 09-03-2015, 06:25 PM   #59
MD1032's Avatar
Groans: 143
Yeah I was pretty close to getting a squirt bottle until I switched to a methanol mix. I'm telling you, there is nothing, nothing that beats just throwing some alcohol in the tank, assuming your goal is to eliminate knock.
OK, that's great. Why don't you post up the data for us? I'm really having a hard time believing your experience is so different from everyone else's. I'm inclined to try this on my own car to satisfy my own curiosity about the performance of my stock intercooler versus my CP-E TMIC on my car under my conditions, but not as a supplement to existing threads here on MSF that contain data showing that the aftermarket ones cool better. If you haven't read this thread, it's a good read.
Corksport / ETS / CP-E TMIC before/after logs - got 'em, post 'em
2007 Mazdaspeed3 GT
 Old 09-03-2015, 06:25 PM   #60
Raider is mah Homie
Groans: 2,978
@dale_gribble; did a pretty good comparo sometime ago.
I hugged rfinkle2
aromig (09-03-2015), speedfreak44 (09-03-2015), WetzMS3 (09-04-2015)
 Old 09-03-2015, 06:56 PM   #61
sheston's Avatar
Posts: 1,847   (View Stats)
I started by using the washer pump to spray washer fluid on my stock TMIC. That seems to work ok, but everyone knew something was up when I sat at the light and my windshield wipers were going. Had to fix that by wiring up a switch.
Next I tried a 1000 cfm low profile fan mounted to the top of the TMIC. Can't say that did anything, but if anyone would like it, I've still got it.
I agree with @MD1032; in tank meth will kill any knock. I get better protection with 2 gallons per tank that I did with 4.5 gallons of E85 per tank.
Of course, the only real way to go is spraying Meth. This will not only get rid of knock, but give more hp as well
The Following User Says Thank You to sheston For This Useful Post:
mxlplx71 (09-03-2015)
 Old 09-03-2015, 07:05 PM   #62
@MD1032; I couldn't post them because I do not have them labeled to be able to find them in the mix of my other 60 or so logs. I doubt they would respond but my logs were sent to stratified for comparison and even they couldn't give me an answer as to why my tune didn't lose power or gain power swapping between the two. I wish I did label them however but I wasn't expecting to ever have a thread like this going. Maybe by some off chance my ets was screwed up. Either way I will be experimenting with the cpe within the month
I read dales write up it was.very informative
The line up:
 Old 09-03-2015, 09:27 PM   #63
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
I only have after TMIC/SRI/TIP on original turbo during the peak of summer, and I now have before on new K04 @ 17350 kms (warranty) from a few weeks ago. My engine is still stocked out at the moment, and Mazda is about to decide on whether to also replace my cats/inspect my O2 sensors (they are still smoking after ingesting 3.5l of oil), so I'm just waiting to hear back before I continue my mod-a-thon (engine-wise anyways).
Once Mazda says yay or neh on the additional work I will do a bunch more logs in stock form, (because it's already 15* Celsius cooler than a month ago, and 20* than all my logs pre K04 failure), install my CS TMIC and do a bunch more logging, then the 3.5" will go on and more logs will follow, then finallllllly, the CS catless TBE will go on and more logs will ensue. Then I'll be custom tuned by Stratified in person and more logs will come, WMI, 3bar/EBC turn up the boost and many more logs.
So yeah, I will provide all these logs as soon as I can, it's one of the silver linings from the K04 blowing on me, it gives me a chance to see what exactly each bolt on gives me. I didn't get my AP until I had already installed my TMIC, so I had no baselines, and I didn't start data-logging until after the SRI, but this time I have a chance to do it over again.
Another silver lining is that Mazda replaced the 1 10 mm heatshield bolt that stripped on me when I first attempted the TBE install, and they cracked all the turbo/DP/etc bolts/studs replacing the turbo.. I would have thought they would have cracked the primary o2 sensor as well but they must have just unplugged it when they dropped the exhaust. If they replace the cat, or cats they'll have to crack them though.
I was actually going to install the TBE the day after my K04 blew, kinda glad it happened before than after, as stocking out the exhaust would have been a bigger hassle.
TL;DR
Not right now, but as soon as possible I will post them here for you fine folks.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
The Following User Says Thank You to Awal For This Useful Post:
aromig (09-04-2015)
 Old 09-03-2015, 09:49 PM   #64
Awal's Avatar
for shits and giggles, you turbo nerds may be able to gleam some info from my Pu with CS TMIC/3.5"SRI/TIP on original K04 vs my car with stock TMIC/airbox on the new K04.
The 1st two logs are with the CS gear on orig K04, very conservative tune, 2nd two are stock with new K04 on Stage 0 (Cobb's approximation of the OEM map). Yes, I know the new logs are crazy rich.
I will provide better back to back logs of stock vs CS TMIC as soon as I can. If there any other values you'd like to see for this comparison please let me know and I'll make sure I log them.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
aromig (09-04-2015)
 Old 09-04-2015, 12:06 AM   #65
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Just noticed this in the recent threads section. Cp-e has made some great white papers on intercoolers. Here's the one for their TMIC. It's all true for any aftermarket unit but the math is cool to see as well as seeing the difference graphically.
http://cp-e.com/tech/MZRTMIC.pdf
zenit likes this.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 7 Users Say Thank You to Mazdazilla6 For This Useful Post:
aromig (09-04-2015), Awal (09-04-2015), mxlplx71 (09-04-2015), Nliiitend1 (09-09-2015), speedfreak44 (09-04-2015), WetzMS3 (09-04-2015), zenit (09-04-2015)
 Old 09-04-2015, 04:53 AM   #66
To me cpe is stating exactly what we have observed in this thread and discussed. The only part I am not sure I agree with is the "power gain" dyno graph. Again once my cpe tmic is here I will be doing my own testing. That and awal should post up his Cs findings.
@Awal; I would go fully bolted and get a good tune down then swap the tmics back to back so they are the weakest link in the setup (excluding the k04).
The line up:
aromig (09-04-2015)
 Old 09-04-2015, 06:35 AM   #67
Voltwings's Avatar
How exactly was this test done? Depending on the order of intercoolers your numbers could be skewed, since the BATs are measured in the intake manifold and that will always heat soak, regardless of intercooler.
Unless you are starting with a 100% cold car each time, its a bit null. That makes same day testing a bit tricky, but its a factor that cant really be ignored.
Past:
-Sold-
-Sold-
Current:
The Following 2 Users Say Thank You to Voltwings For This Useful Post:
MD1032 (09-04-2015), MS3Shadow (09-04-2015)
 Old 09-04-2015, 09:44 AM   #68
It was same day about 3 hours apart. Ets was done cold car OEM done about 3 hours later.
The line up:
 Old 09-04-2015, 10:37 PM   #69
Awal's Avatar
I will do exactly that once I'm fully bolted and tuned (pre WMI). The TMIC swap takes about 10 mins tops so it's not a big deal, and if I can help provide real world data on the TMIC debate I'm all for it.
I chose the Corksport TMIC because it can still be run with the stock shroud, and I like things looking stock AF. But it some of the points made earlier about how it sheds heat soak a bit faster due to less mass makes sense. Also, for this engine, at this point, I'm trying to keep things as easy as possible to stock out just in case warranty issues popped up, and from all I've read and researched (especially if I go WMI) on the K04 and even a LBT (CS/BNRv3) a TMIC is sufficient for under 400whp.
When I get a fully built motor + BigBoyTurbo I'll be stepping up to a FMIC, until then a good TMIC and meth is fine for my needs.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
aromig (09-05-2015)
 Old 09-05-2015, 06:38 AM   #70
MD1032's Avatar
Groans: 143
What is so damn hard about going into your sent mail folder @speedfreak44; and posting those logs here? Way too much speculation and not enough actual data in this thread.
Admittedly, I'm part of the problem. But I won't have time to test until I get back from vacation this extended weekend. In the meantime I have been thinking about how to do this. Here is my proposed test method:
1) Heat soak equipped intercooler until BAT=170°F
2) Begin logging. Drive in a consistent loop at a consistent speed to remove heatsoak. Measure time it takes to remove heatsoak.
3) Perform three 3rd gear WOT pulls, measuring the time it takes to remove heatsoak in between each pull. Stop logging (yes, logs will be very long indeed).
4) Perform in duplicate for each intercooler and bracket in singlet with originally installed intercooler to confirm original results.
2007 Mazdaspeed3 GT
The Following 2 Users Say Thank You to MD1032 For This Useful Post:
Awal (09-05-2015), Easter Bunny (09-05-2015)
 Old 09-05-2015, 07:01 AM   #71
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
You could use the extended Bernoulli's equation to get a K value for the OEM TMIC. The K value would actually represent the system between the MAF sensor and the MAP sensor, but assuming you keep everything the same, a change in the k value would be as a result of swapping the intercooler.
This equation assumes inviscid flow, which is a reasonable assumption.
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following 2 Users Say Thank You to mize13 For This Useful Post:
Mazdazilla6 (09-05-2015), phate (09-05-2015)
 Old 09-15-2015, 12:55 PM   #72
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
I tried to read up on Bernoulli's equation and inviscid flow. Although fluid dynamics seemed intriguing I can't wrap my head around the equations. Anyway, i did think " I'll be damned"
https://www.youtube.com/watch?v=T2cIGYpFA68
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 09-15-2015, 01:13 PM   #73
mize13's Avatar
Bernoulli's is a simplification of the conservation of energy along a fluid streamline, in which energy can only be stored in three forms: pressure, velocity, and potential energy (delta z).
Extended Bernoulli's just tacks on frictional losses, system losses from pipes, bends, entrances, exits, etc., and pumping head.
So if point 1 is say the MAF sensor, and point 2 is the MAP sensor then, neglecting any changes in potential energy, we have:
P_1 (Pressure at MAF ~ close to atmospheric, probably a hair less)
ro_1 (Density at MAF)
P_2 (Measured at MAP)
ro_2 (Density at MAP)
V_1 (velocity at MAF sensor)
V_2 (might have to be approximated in throttle body)
z_1 = z_2 = 0
f = some value, small
L = Length of system
H_pump is the tricky part. Basically need to know pumping head, which we can't really find unless we are measuring the pressure in the compressor outlet.
With all of these values you can get a k value for the entire system.
God, there is a lot of potential error in this method. But be cool to try.
TunedbyNishan
 Old 09-15-2015, 06:18 PM   #74
We wont be getting my cpe vs stock comparison. Decided to go fmic. I may be inclined to grab logs of that swap but that is a large difference vs just a top mount swap
The line up:
 Old 09-15-2015, 06:22 PM   #75
MD1032's Avatar
Groans: 143
I'll still be doing mine when time allows. Life is busy unfortunately.
Sent from my A0001 using Tapatalk
2007 Mazdaspeed3 GT
MS3Shadow (09-16-2015), speedfreak44 (09-15-2015)
 Old 09-15-2015, 07:28 PM   #76
I feel you. I work 12 days straight followed by 2 days off then another 12 days straight etc etc
The line up:
 Old 09-16-2015, 09:44 PM   #77
mize13's Avatar
I'll see if I can take my stocker to the university and throw it on the flow bench. The one we have at NC State was given to us by IBM, and they are very nice and well designed. I could develop an impedance curve for the TMIC. Only thing I'm worried about is not being able to get enough air moving through it. I'll have to check how much air it can flow.
TunedbyNishan
mxlplx71 (09-17-2015), zenit (09-17-2015)
TMIC ducting / engine bay pressure Voltwings 2010 MS3 - Turbo Induction 57 07-06-2017 07:05 PM
TMIC Pressure Drop and Cooling (3" vs 3.25") cletusb MazdaSpeed 3/6 - Turbo Induction 8 02-19-2011 07:17 AM
What's the best way to drop the differential? MATT DAMOND MazdaSpeed 6 - Engine, Transmission & Driveline 19 05-04-2009 03:04 PM
Page generated in 0.58610 seconds with 37 queries
