Notices
Like Tree8Likes
 Old 07-26-2012, 11:44 PM   #81
SlickDevil's Avatar
Posts: 315   (View Stats)
SlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the world
Groaned at 21 Times in 11 Posts
Originally Posted by jdm_dudebro View Post
I have a 2012... Cobb intake. Turbo just replaced and they said it was bc intakes on 2012s are lethal to the operation of engine/turbo. They said never reinstall the intake.
They also claimed my front grill could have caused the turbo seals to die... I LOL'd
Now worried about advancing in my plans to mod my brand new car :S
I am in the same boat man. Not sure what to do at this point... Thinking about getting a diffrent car but really dont want to
2012 CWP | 15% Tint | White Led License Plate Lights | DDM HID 6K | 3K Yellow Fogs | White Ralley Armor Mudflaps | AT Internals |
SlickDevil is offline   Reply With Quote
 Old 07-26-2012, 11:45 PM   #82
SlickDevil's Avatar
Originally Posted by Worbit View Post
I'm confused, first you say you have the Corksport SRI and now its the Cobb?
As far as the internals go, you're fine. It only matters when you start adding big power upgrades like the DP/Test Pipe.
I had a cs intake and tip . That other guy had a cobb
 Old 08-15-2012, 04:23 PM   #83
SlickDevil's Avatar
Update the car is stock and still having.issues . The dealer is refusing to work on it.
 Old 08-15-2012, 05:19 PM   #84
doctavus's Avatar
Posts: 190   (View Stats)
doctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud ofdoctavus has much to be proud of
I would take it to a different dealer.
I tried reading through whole thread but my brain started misfiring at the conflicting information.
Do you or do you not have an Cobb Access Port?
doctavus is offline   Reply With Quote
 Old 08-15-2012, 05:58 PM   #85
SlickDevil's Avatar
I did. It is now off the car and still same.problem
 Old 08-15-2012, 06:21 PM   #86
doctavus's Avatar
Well was gonna ask for logs so these guru's can analyze it for you from their house.
 Old 08-15-2012, 09:23 PM   #87
SlickDevil's Avatar
Yeah sorry I dont have the ap anymore
 Old 08-15-2012, 09:39 PM   #88
doctavus's Avatar
You sound like you have given up with it.
What are you going to do with it?
 Old 08-16-2012, 08:55 AM   #89
daustin's Avatar
Posts: 1,355   (View Stats)
You did unmarry the AP from the car before you took the AP out, didn't you? Just checking because your MAF curve could still be for a different size MAF housing if you just had the stock airbox and whatnot thrown back on without basically flashing the car back to stock map.
Also your plugs could be improperly gapped. Have you tried pulling them just to check?
2012 Black Mica Mazdaspeed3 - 308hp/341tq
| AutoTech HPFP | Cobb AP | CP-e RMM/SRI/TIP/TMIC | H&R | JBR RSB/EGR/TIGs | SPC | TWM SSP/Full Replacement/M1 Abrams | UR CBE/TP |
2012 True Red Mazda2 - Daily
2006 Shimmering Sand Metallic Mazda3 - Wife's Daily
daustin is online now   Reply With Quote
 Old 08-16-2012, 07:22 PM   #90
SlickDevil's Avatar
Yeah need to check plugs and also yeah I did unmarry it
 Old 08-16-2012, 08:02 PM   #91
trf5000's Avatar
Posts: 1,960   (View Stats)
When can a nator mechanic take a look at it for you?
2010 MS3 VRM - Corn Fed PU
CS CBE, CS RP, CS DP, JBR 80/88 Duro Fully Mounted, TS BPV, CPE HPFP, CS SRI/TIP, CPE-FMIC, AP, NGK Iridiums, GS EBCS in 3 Port Int, JMF IM, Hypnotic Tuned, TWM Full Replacement, E4 Weighted Knob, Eibach Prokit, 18x8.5 Konig Milligrams Matte Black with Machined Undercut, 245/40 18 Fuzion ZRi
Best Run: 13.1 @ 109 1.9 60ft Atco
Slow build in progress
 Old 08-17-2012, 01:11 AM   #92
shaneski's Avatar
Posts: 36   (View Stats)
shaneski has disabled reputation
The intake you had on hasn't damaged the ECU harness has it? There's another thread in here recently that had similar symptons and had a damaged harness from a corksport intake.
shaneski is online now   Reply With Quote
 Old 08-20-2012, 04:37 AM   #93
SlickDevil's Avatar
What u mean by damaged harness
 Old 08-20-2012, 04:41 AM   #94
daustin's Avatar
The ECU wiring harness can be damaged by hose clamps for intakes if the connector is clocked over to the battery side. The wires for the ECU hang down in exactly that spot and if they see a lot of rubbing and vibration from the clamp, it can chew away at the wires and cause very unusual and intermittent issues. Most of which almost unexplainable.
 Old 08-20-2012, 06:05 AM   #95
I_Heart_Haters's Avatar
Posts: 1,423   (View Stats)
I_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the world
Groaned at 63 Times in 39 Posts
remember i told you this happened to me. i think i was the first one to bring it up/make a thread about it and then everyone followed behind me with their car doing the same thing.
it ended up being that the hose clamp that connects the elbow silicone part of the intake to the turbo inlet pipe rubbed up against a couple ecu wires, blowing fuses and shit.
call me if you need me to explain that again and where to check.
2011 Liquid Silver Mazdaspeed3 w/ Tech Package : Corksport SRI # Corksport TIP # Corksport DP # Corksport CBE # JBR RMM # OBX Test Pipe # Turbosmart 50/50 BOV # KMD HPFP # Cobb Stage 2 # 20%/35% Tint
# RX-8 Rims on 235/40/18 Hankook v12's
I_Heart_Haters is offline   Reply With Quote
 Old 08-20-2012, 07:01 AM   #96
tddvrrn's Avatar
Posts: 2,572   (View Stats)
Groans: 103
I_Heart_Haters
it's funny this happened. even as a total newb i saw the potential for damage when i was installing my SRI. i ended up bending the tail of the hose clamp to keep it well away from the wire harness..
ah well, i've done other stupid shit that other people thought was blatantly obvious not to do. good luck, OP. hope this is your problem.
 Old 03-27-2013, 09:21 PM   #97
jdm_dudebro's Avatar
Posts: 3   (View Stats)
jdm_dudebro is an unknown quantity at this point
cshunter I had 15,000ish, Now at 30 with a new turbo and no issues...hmmmm i hope it was just a freak occurrence.
jdm_dudebro is offline   Reply With Quote
 Old 03-29-2013, 04:07 PM   #98
Caveman4684's Avatar
Posts: 215   (View Stats)
Caveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the world
Groans: 47
Groaned at 56 Times in 18 Posts
Why would you ressurect an old shit thread?
2012 MS3 VR
COBB AP /// Autotech Internals /// CP-E Nano SRI /// CP-E TIP /// JBR Dogbone RMM /// JBR OCC Stage 2 /// RichTune
Caveman4684 is offline   Reply With Quote
Help with problems from '10 MS3 yz007 2010 MS3 - Troubleshoot/Diagnostics 14 05-23-2012 05:20 PM
VVT Problems mrmonk7663 CX-7 > Engine, Transmission & Driveline 6 04-01-2011 06:47 AM
VVT Problems mrmonk7663 CX-7 > Issues & Troubleshooting 3 01-17-2011 08:07 AM
Big Problems (MS6) phlselspd6 Mazdaspeed3/6 General Discussion 78 12-21-2010 09:32 PM
problems:( MS6Gfeh MazdaSpeed 6 - Engine, Transmission & Driveline 2 09-27-2009 02:12 PM
Page generated in 0.43542 seconds with 28 queries
