-   -   Problems with new BOV (http://www.mazdaspeedforums.org/forum/f544/problems-new-bov-130171/)
CtrlAlt1337 11-13-2012 03:14 PM
Hey guys I recently got a turbosmart dual port BOV and and since then my car would start to bog in lower gears. i found out that the air straightener fell out of my CS SRI. i then super glued it back in and ill occasionally still get the bogging. so i made some logs then vdyno. its my first time so im super new to the proglem. i also miss third alot could that be the bov preventing me from getting it in there when i launch?
Dizzy Turbo 11-13-2012 03:25 PM
Not sure about your problem, but I'm preeeeetty sure a bov won't effect your shifting. For that problem try a rmm or shifter bushings.
moomooz12 11-13-2012 03:47 PM
Clean and lube the dual port. Then adjust the hardness/softness setting to see what your car likes best.
Stangcobra 11-13-2012 03:50 PM
Your shifting is going to feel different than full bypass and you'll afterfire a lot more.
Your other issues are unrelated
p057 11-13-2012 04:09 PM
We did have an issue originally tuning this BPV, turning it resulted in little change, and it went from fluttering heavily to barely holding boost.
However, looking at your log I'm more worried about your AFR, wtf is it doing fluctuating that way? looks about as curvy as a pube.
any tuners want to chip in and help explain that? I believe he's running stage 1 OTS map from cobb
NavySailorMS3 11-13-2012 04:24 PM
The great and powerful Dom said it the best "Granny shiftin' not double clutchin' like you should"
uncorked11 11-13-2012 04:28 PM
I'm more worried about the gay amputee porn, brazilian fart fetish, and strap on accessories tabs. But yea AFRs look wack.
3Gee Tee 11-13-2012 04:38 PM
Damn, it took 7 posts? I just lost $5 lol.
uncorked11 11-13-2012 04:47 PM
I thought the same!
Page generated in 0.17840 seconds with 11 queries
