Relocated ecu question So i always had rubbing issues since i installed my corksport intake. Today i decided to move my ecu and clean my engine bay a little. I ve seen people placing it on top of the fuse box. So i went ahead and did that, i opened a hole and bolted the ecu to the cover. Now im wondering what if when its raining some water gets there and goes through it and messes up the fuses? Should i put some sealant? Or not really neccesary? |
http://images.tapatalk-cdn.com/15/08...840719ee94.jpghttp://images.tapatalk-cdn.com/15/08...1023225273.jpg Sent from my LG-D852 using Tapatalk |
You could get a battery relocation battery box from corksport or a battery tray w/ 51R battery and put it in the existing box. Sent from my HTC M9 |
3 Attachment(s) I modified my stock battery box and am pretty happy with it. I cut a hole in the side and mounted the ecu in the stock location but the back plate is in the battery box. Gives the ecu room so it does not touch the intake and does not touch the battery either. There may be better solutions but this worked for me. Edited to add - I would definetly seal the holes. A lot of people use velcro when they mount the ecu to the fuse box. This way they can get to the fuses easier and do not add extra holes in the fuse box. |
http://i898.photobucket.com/albums/a...pslhbqpbxu.jpg http://i898.photobucket.com/albums/a...psacl1d59a.jpg |
| All times are GMT -7. The time now is 02:18 AM. |
