 Old 09-24-2014, 02:07 PM   #1
rdjr74's Avatar
Posts: 119   (View Stats)
rdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud ofrdjr74 has much to be proud of
Default Removing entire overhead dome light area (not just the lighting assembly)
For the life of me I can not find a DIY for this for my 2012 ms3. I've found it for others but not my car specifically. Yeah I tried Google without success several times. Appreciate the help or a link, something. Thx!
2012 MS3 Silver Metallic - Hypertech - JBR stage 2 Intake
rdjr74 is offline   Reply With Quote
 Old 09-24-2014, 05:34 PM   #2
JPele21's Avatar
Posts: 125   (View Stats)
JPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond reputeJPele21 has a reputation beyond repute
To clarify, you are looking for a how to remove the fabric headliner?
CS Rear Swaybar | CS Short Shift Plate | CS Shifter Bushings | CS RMM | CS Transmission Mount Insert | CS PMM | Forged Recirculate Valve | CS & JBR Silicone Hoses | Cobb AP | Koni FSDs | AutoTech HPFP Internals | CS TIP/SRI | CP-E TMIC | Hella SuperTones | CS Test Pipe |
CS OCC | CS CF Hood Scoop | Stratified Flash Tune V2.10
- 2011 Black Mica Tech Package (15,500 miles)
JPele21 is offline   Reply With Quote
 Old 09-24-2014, 05:48 PM   #3
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
ALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the world
Groaned at 8 Times in 3 Posts
Remove the light covers and there are screws behind it. (I think)
Then work it out. It's a tight fit up there and the dome lamp assms are a tight fit.
2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30
ALPINEST4RS is offline   Reply With Quote
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
rdjr74 (09-25-2014)
 Old 09-25-2014, 06:08 AM   #4
rdjr74's Avatar
Dome light assembly area. Above the dash.
On the pu's there are clips that hold that area in. The area you are referencing actually comes out in one piece, that was the easy part. Removing the rest I have no idea.
Last edited by rdjr74; 09-25-2014 at 06:08 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-25-2014, 06:11 AM   #5
So disassembling the whole piece? If so, I have a document.
 Old 09-25-2014, 07:42 AM   #6
rdjr74's Avatar
That'd be great. I'll take a look and see if it works for me. How can I get this document? I can PM you my email?.... thx!
 Old 09-25-2014, 08:25 AM   #7
I lied, I looked at the MS3 documents. They have removal/installation, inspection, and bulb replacement.
Its for a 6 they have a teardown.
 Old 09-25-2014, 10:39 AM   #8
rdjr74's Avatar
I wonder if it is the same or close to how it comes out. I'd still like to take a look.
 Old 09-25-2014, 11:17 AM   #9
dark_matter's Avatar
Posts: 193   (View Stats)
dark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond repute
Donate and you will have access to the service manuals.
Sparkling Graphite Metallic E90 330i 6speed ZSP
RIP: くろ ひめ BlackMica SPEED3
dark_matter is offline   Reply With Quote
 Old 09-25-2014, 11:18 AM   #10
Alright, let me make sure we are on the same page. What are you trying to do?
Dome light won't go back in! oOfactoryOo Interior 5 12-28-2013 06:08 PM
Corksport LED dome light not working Mazdaspeed3KHP CorkSport 11 06-11-2013 09:41 AM
Re-attaching dome light housing PUGENE 2010 MS3 - Car Audio & Electronics 4 06-16-2012 05:38 AM
LED Dome Light LatinKraze MazdaSpeed 3/6 - Car Audio & Electronics 15 07-27-2011 03:39 PM
Page generated in 0.30915 seconds with 23 queries
