Like Tree21Likes
 Old 05-26-2014, 09:02 PM   #41
bryancregger's Avatar
Posts: 205   (View Stats)
bryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant future
Originally Posted by 2zooms View Post
@bryancregger; that's not good to here, i've read a bunch of good reviews on them. I may try them when I need new rubber...
If you've heard good things then you should give them a try. Who knows maybe I just got a couple messed up tires. I was in the same boat.. read the reviews and got a good deal on them so I pulled the trigger.
As of now though I won't be buying another set. Let me know if you have better luck.
______________________
___________________________________
\\ 2010 MS3 \\ BNRS3 \\ Cobb SF Intake \\ CP-E TMIC \\ Corksport TIP \\ Cobb AP v2 \\ Autotech HPFP \\ ACT Clutch \\ JBR PMM and RMM \\ Corksport TMM Insert \\ JBR SSP \\ Corksport Catch Can \\ FREEKTUNED \\ Cobb 3 Port EBCS \\ Stoptech Slotted Rotors \\ JBR EGR Delete \\ 3 Bar MAP \\
bryancregger is offline   Reply With Quote
 Old 05-27-2014, 03:53 AM   #42
2zooms's Avatar
Posts: 743   (View Stats)
2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world2zooms is the leader of the world
If I were you I wouldn't get another set either. I'll let you know, but I am hoping to get through the fall on my current tires then put on my winter setup and not buy new tires until next spring.
2012 Black Mica Mazdaspeed3 - APv3 / COBB RMM / AT Internals / Corsksport Stage II SRI
2zooms is offline   Reply With Quote
 Old 05-27-2014, 05:55 PM   #43
PapaBruno's Avatar
Posts: 942   (View Stats)
PapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the world
I have 555's on right now and I'm less than impressed. Both rears bulged a sidewall in less than 5k miles and we're replaced under warranty. I guess they do stick pretty good but a tire that has a bulge or in my case is prone to getting them is now friend of mine.
To the OP I just got an OTS+ tun from Justin and it is the best 75 you can spend.. That dude is a magician.
Actually, I just paid for my e-tune. I am pretty damn excited! This will be my first tune. But I suppose that's obvious since I am posting in my own, self-proclaimed, brownie-esque thread.
Thanks for the heads up on the availability, @Justin@Freektune. Can't wait to see sort of electronic map wizardry you whip up for my Speed3.
2012 Crystal White Pearl MS3 - http://i.imgur.com/duln01Z.png
JBR 88 Durometer RMM, Autotech HPFP Internals, COBB Accessport V3, CS Hood Strut Kit, CS Underhood LED Kit, CS Eyelids (painted), BFG CS2s with JBR 5mm spacers, Password JDM Gurney Flap, FREEKTUNE e-Tune, Full Race FMIC, RÄZO RA138 Shift Knob, RÄZO 270mm Convex Rear View Mirror, Rally Armor Limited Ed. Flaps, JBR Stage 2 Short Shifter, NGK One Step Colder Plugs, Ultimate Racing: V3 Down Pipe (w/ Metal Substrate Core), Straight Test Pipe, and CBE, Go Fast Bits Respons TMS Blowoff Valve, CS Injector Seals, DM Stage 1 OCC + VTA, DM EGR Delete Kit, DM PMM, HTP 3.5" Intake, BNR S4, Grimmspeed EBCS, CS 3.5 Bar MAP, Prosport 52"mm Premium Evo Boost Gauge, RÄZO RP81 and RP85 Sports Competition Pedals, AEM Water/Meth Injection Kit, DM TB Spacer, Koyorad Racing Radiator V-Series Core
PapaBruno is offline   Reply With Quote
The Following 2 Users Say Thank You to PapaBruno For This Useful Post:
Agent_Orange (05-27-2014), bryancregger (05-27-2014)
 Old 05-27-2014, 06:10 PM   #44
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
You're getting a tune before you put the down pipe on or do you just need to update your signature?
I just threw a test pipe on my whip a couple weeks ago. Will be getting a pro tune soon. I think I might go with a Stratified tune since Justin is just way too busy.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 05-27-2014, 06:11 PM   #45
Ottousmc0341's Avatar
Posts: 84   (View Stats)
Ottousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant futureOttousmc0341 has a brilliant future
on tires, my pu has kuhmo spt's that were put on by the dealer prior to my buying the car. those things are great in dry and wet. do not recommend for the winter. the g/f's genwon has kuhmo s4's on it, and those did great this past winter, and have been decent so far this year
2012 Liquid Silver Metallic
AT,APv2, CS TIP/SRI, M2 catless dp, CS test pipe, JBR boost tubes, HKS SSQV, JBR 88 RMM/80 TMM
Ottousmc0341 is offline   Reply With Quote
 Old 05-27-2014, 06:29 PM   #46
PapaBruno's Avatar
Yes. I can always pay a few extra clams and get the tune adjusted. I don't want to ride this temp. map on the 3" intake much longer - it was just to hold things over until I can get something that is better, and more personally suited to my driving.
Everything in my sig I've done to my car this year, so after the tune I think I may play it low for a while in terms of modding, and start learning more of the ins and outs of the genpu. I'll still be posting and all and buying stuff for the car, but it'll be smaller mods and items like the CS ECU relocation/battery box, and maybe the black anodized TMIC from cp-e. That thing is damn sexy.
 Old 05-27-2014, 06:52 PM   #47
ABOSWORTH's Avatar
Right on. I've done all of my mods (Other than the CS SRI/TIP that was already on the car) within the year as well. I haven't even had the car for a year yet. I'm so tempted to just throw a custom tune on my credit card ASAP but I just paid the fucker off (AP/internals) so I don't really want to jack it up again. LOL. I should have the money to do this in like September or October but I don't know if I can wait that long.
That CP-E TMIC is money. I've got my eye on the ETS TMIC. I do love the black but I'm not sure I want to spend the extra 100 bucks just for the color.
I was an inch away from buying a JBR shift knob today though. LOL. I'm like a little kid at a toy store. I'm always looking on the CS website and JBR making lists of things I "need."
Current Mods
 Old 05-27-2014, 07:49 PM   #48
^this. So many mods I "need" so little money....
 Old 05-27-2014, 08:43 PM   #49
You won't be disappointed.
Not to mention Rob is involved with Justin now, so there is a huge added bonus. The dynamic duo
The Following User Says Thank You to bryancregger For This Useful Post:
PapaBruno (05-28-2014)
 Old 05-28-2014, 01:53 AM   #50
JayBeeL's Avatar
Posts: 34   (View Stats)
JayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to beholdJayBeeL is a splendid one to behold
So you can still buy from him on his site but he's also on Edgeauto?
Last time I checked it said SOLD OUT on his site!
Either way it's the same price, I was just curious
JayBeeL is offline   Reply With Quote
 Old 05-28-2014, 07:36 AM   #51
Yes you can still buy them from his site. Last I heard they were still working out the logistics with edge as far as how orders placed on edge were delivered to Justin. They are in stock on his site right now though.
Change your avatar for gods sake.
 Old 05-28-2014, 08:11 AM   #52
ABOSWORTH's Avatar
Not anymore. LOL. Sold out again.
Yeah seriously. Change that god damn avatar. That's the first thing I did when I joined this site. What's the deal with that Meshugga tee shirt wearing ginger anyway? Was his he a member here that got his shit pushed in or something?
Current Mods
APv3 and Boost cut baylor0u812 MazdaSpeed 3/6 - ECU Computer Tuning 8 03-03-2014 05:50 PM
APv3 Mounting Badinfluence
Cobb Access Port/Maps
2 12-07-2013 09:52 PM
Fisker CEO Tony Posawatz steps down, Bernhard Koehler steps in Haltech Automotive News 0 08-26-2013 10:30 AM
Laurens van der Acker steps down as Mazda design chief, Ikuo Maeda steps up Haltech Automotive News 0 04-01-2009 09:30 AM
Page generated in 0.35028 seconds with 26 queries
