Like Tree7Likes
  • 7 Post By helmetface
 Old 03-18-2014, 09:48 AM   #1
SternRitteR's Avatar
Posts: 64   (View Stats)
SternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to behold
Groaned at 7 Times in 5 Posts
Default Rod Job
Before anyone moans , the search didnt bring up much with search terms "rod job ,rod change"
There is a little bit of confusion probably on my part what is needed for a rod job , since i have a gen2 and not the salarys of half the UK guys a hybrid is about as far as i would go.
So what would i need just for a rod job , links to edge would be nice .
Im thinking:
rods
oil pan gasket
rod shells
Who has done just a rod job .
BNRS3 CORKSPORT STAGE 2 INTAKE AUTOTECH HPFP FORGE INTERCOOLER TOTAL MPS DOWNPIPE MIJ CATBACK COBB 3PORT EBS DICE DUST CAPS TB COOLANT DELETE FORGE V2 BPV
SternRitteR is offline   Reply With Quote
The Following User Says NO Thank You to SternRitteR For This Un-useful Post:
Easter Bunny (03-19-2014)
 Old 03-18-2014, 09:54 AM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
The Following 12 Users Say Thank You to helmetface For This Useful Post:
Agent_Orange (03-19-2014), bwagers (03-19-2014), Cevaes_64 (03-19-2014), chaser27 (03-19-2014), Easter Bunny (03-18-2014), Erick13Speed3 (03-18-2014), JeffroMS3 (03-20-2014), Kyle Undefined (03-18-2014), mrshoulders (03-18-2014), mxlplx71 (03-18-2014), SLOWHATCH (03-19-2014), trancehead (03-19-2014)
 Old 03-18-2014, 06:30 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
you must pull the head, and balance shafts
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 03-18-2014, 06:38 PM   #4
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world
you wanna give me a rod job?
1996 Miata
SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs.
SOLD: 2009 Mazda 6i GT. 6-Speed MT.
6Y MAZDA is offline   Reply With Quote
 Old 03-18-2014, 07:15 PM   #5
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Just need to search other terms......
Drop-in forged internals
But I'll take a rod job when you're done.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
6Y MAZDA (03-19-2014)
 Old 03-19-2014, 04:02 AM   #6
Seems a can of worms , thanks anyway .
 Old 03-19-2014, 06:28 AM   #7
ibcrusn's Avatar
If you plan it out ahead of time and have your ducks in a row it really doesn't look too bad. If you have a damage free reasonably low mileage engine it's an option. If the car is new to you there's a lot of potential in the car before you need forged bits.
'10 VRM MS3
Sir Henry Royce
 Old 03-19-2014, 06:44 AM   #8
The car is new to me ,now on 55k .
I just need to fit my downpipe after 2 failed attempts to be fully bolted .
I wouldn't personally do the job ,I just wanted a parts list then I'd send it to the shop ,however if my bores are screwed I'd be better honing then needing pistons .
Remember I'm in the UK so it would be extra downtime waiting for added parts .
Sent from my Nexus 4 using Tapatalk 2
 Old 03-19-2014, 06:56 AM   #9
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
I hope you have a tune and high pressure fuel pump (HPFP) internals to go with that downpipe. If not, you're looking at a blown motor that'll need a lot more than just a "rod job."
 Old 03-19-2014, 07:13 AM   #10
Don't worry like I said just the downpipe to go ,the tune is already on the cobb ready and waiting .
Car has all the supporting mods and fuel pressure is at a nice 1850psi when the current tune was finished .
End goal is hybrid that is all ,hence the rod job questions .
 Old 03-19-2014, 07:18 AM   #11
6Y MAZDA's Avatar
wtf do you mean "hybrid"? you tryna make it a prius?
1996 Miata
The Following User Says Thank You to 6Y MAZDA For This Useful Post:
SpeedRebirth (03-19-2014)
 Old 03-19-2014, 07:18 AM   #12
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
All the engine building info on this site and you couldn't find anything?
Kill yourself.
Agent_Orange is offline   Reply With Quote
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
6Y MAZDA (03-19-2014), Easter Bunny (03-19-2014)
 Old 03-19-2014, 07:29 AM   #13
Vansquish's Avatar
Groans: 1,911
Also...how can you say, "don't worry" when you say things like this: "the tune is already on the cobb ready and waiting" ?
To me, that implies you've put a bunch of mods on the car and are just assuming that things will hold together until you finally have all the parts on the car and then tune it. That's not a wise course of action (obviously). You need to tune for each of the flow mods that you put on the car to avoid damaging the motor.
By "hybrid," I assume you mean a K04 hybrid of some sort, like the BNR series, correct?
 Old 03-19-2014, 07:49 AM   #14
Some people don't read ,I said originally I searched a couple of search terms hence starting the thread .
Read again I said the downpipe tune is ready and waiting for when I fit it ,you guys should no that boost needs to be controlled .
My other mods are safely tuned via cobb ,this isn't the issue .
 Old 03-19-2014, 08:18 AM   #15
torquemaniac's Avatar
Posts: 733   (View Stats)
Ill send you a part list and some link when I get home tonight...
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
 Old 03-19-2014, 08:30 AM   #16
mxlplx71's Avatar
Groans: 128
you said your getting 1850psi when the tune is finished.
which set of internals do you have?
i swapped rods and pistons with the block in the car, took about 40 hours over 3 days.
it can be done.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
 Old 03-19-2014, 08:36 AM   #17
Vansquish's Avatar
Groans: 1,911
I'm not sure if that's directed at me, but how can you have a tune ready for parts that aren't even on the car? To properly tune the DISI, you have to incrementally tune for parts as they're added. By your statement, you're planning on simply using a canned tune of some sort.
 Old 03-19-2014, 08:45 AM   #18
Sorry you right ,yes its a base tune derived from my current one .Obviously it will take a few revisions to get right I aint a noob .
I Don't know how to double quote on tapatalk ,but my current tune is done it took about 5 revisions and its well ... Amazing .
Thanks for the incoming parts list .:thumbup:
The Following User Says Thank You to SternRitteR For This Useful Post:
Vansquish (03-19-2014)
 Old 03-19-2014, 10:23 AM   #19
lnumbp's Avatar
Posts: 178   (View Stats)
lnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the world
Have you upgraded the factory high pressure fuel pump?
lnumbp is offline   Reply With Quote
The Following User Says NO Thank You to lnumbp For This Un-useful Post:
 Old 03-19-2014, 10:36 AM   #20
it can be done.
Did you replace the timing chain cover seal (gasket), when you did the swap?
As per Mazda manual, this seal should be replaced (R) like the valve cover seal, but I did not replace the valve cover seal when I did work on the valve cover, and everything is OK...
I did a lot research and planing to do the swap this summer, but nowhere did I see someone replace this seal!?!?
 Old 03-19-2014, 10:42 AM   #21
mxlplx71's Avatar
Groans: 128
i did, and the vvt, chain, ect.
http://www.mazdaspeedforums.org/foru...forged-142776/
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
torquemaniac (03-19-2014)
 Old 03-19-2014, 10:52 AM   #22
Tried and tested Autotech ,the gen2 really does hit the stock limits pretty fast .
In my case it took a cobb stage 1 ,corksport stage 2 intake and custom downpipe back for it to shit itself .
Then I got the hpfp and tmic ,then a proper tune targeting 19psi
 Old 03-19-2014, 10:56 AM   #23
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
19 psi. Pshhhhh. Sissy.
Lol
On a side note, is there a reason you think you need rods? Planning a bt?
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
 Old 03-19-2014, 11:20 AM   #24
Lol
Well we all know that these turbos don't last forever so I'll be going ko6 hybrid ,then I'll want to run it to the Max boost wise .
I have the most powerful mps in my city with my 19psi hah ,can't say any other cars have to come close to me so far either .Although more boost is better of course .
 Old 03-19-2014, 11:31 AM   #25
6Y MAZDA's Avatar
And what city would that be?
1996 Miata
 Old 03-19-2014, 11:42 AM   #26
I'm in England so its not difficult tbh ,all the others I know off are standard ish .
I do have a few tasty European cars to play with over here though ,england is the land of the hot hatch .
 Old 03-19-2014, 06:05 PM   #27
Here is my part list for the rod swap :
- Head gasket (X1)
- Head stud/bolts (X10)
- Crankshaft friction washer (X3)
- Crankshaft bolt (X1)
- Timing chain cover gasket (X1)
- Exhaust cam friction washer (X1)
- Timing chain cover oil seal (X1)
- Coolant pump gasket (X1)
- Connecting rod journal bearing (as needed)
- DTC timing bolt
- Cams timing tool
- Balance shaft delete kit
Here is a nice thread about a drop-in rod swap :
My Pop 'n drop build
I also joined the engine work shop manual
As a side note, If you keep the OEM pistons, you will need to machine/grind the head of the rods to make it fit with the piston...look at the link below for more details :
K1 Rods with Stock Pistons
 Old 03-19-2014, 06:25 PM   #28
Another link about the rod end :
Rods for OEM pistons - No Machining Required
 Old 03-20-2014, 04:35 AM   #29
- Head gasket (X1)
- DTC timing bolt
- Cams timing tool
thanks for that i will have a read now im bored at work .
I am supposed to be helping the mrs buy a impreza wrx ,but i think id rather put the money to this .
 Old 03-24-2014, 04:17 AM   #30
right guys i blew the turbo seals yesterday ,so this will be on hold until i can fit the bnr3 .
Once shes running il re-evaluate if i want to carry on throwing ££ at the car.
Before anyone says il need a list aslong as my arm to get the turbo running ,my plan is to run 20psi to redline so all il need is ,downpipe ,3port ,coolant turbo braided hose ,2.25" > 2" silicone reducer for my corksport stage 2 .
I have had a downpipe for a few months just not fitted and stratified seem to be out of stock for the 3 port
Page generated in 0.49384 seconds with 29 queries
