Notices
 Old 10-14-2012, 09:33 AM   #1
Mclovin80's Avatar
Posts: 232   (View Stats)
Mclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the world
Default Rough Start up After Autotech Install
Yesterday I installed Autotech internals in my stock fuel pump. I followed all of the directions closely and let the car idle for 20 minutes after the first start up.
I went out for a start up this morning and the car took about 10 seconds to crank over. The gas cap light came on and then went off and it finally started up. After start up everything was normal. Idle around 450 psi, still breaking it in so no WOT psi measurements yet. Went for a short 15 minute drive. No stalling or irregular rpms.
I got home and let it sit for an hour. I started it again with the same issue. It's almost like it's not getting enough fuel initially.
Any ideas what might be causing this?
Mclovin80 is offline   Reply With Quote
 Old 10-14-2012, 09:37 AM   #2
speed23's Avatar
Posts: 955   (View Stats)
Maybe the fuel line connections didn't go on properly?
You could feel around underthem for for leaking gas
The Following User Says Thank You to speed23 For This Useful Post:
Mclovin80 (10-14-2012)
 Old 10-14-2012, 09:59 AM   #3
Mclovin80's Avatar
I checked and heard a little gurgling. There was some fuel leak from the bottom nut. I am going to tighten it and hopefully that solves the problem.
Thanks speed23
 Old 10-14-2012, 10:07 AM   #4
MZRSPEED's Avatar
Posts: 165   (View Stats)
MZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the world
Just did mine as well, had a slight hesitation when it started but that was it. 200 miles in to mine and no issues. Did you turn the key in to the "on" position after the install and listen for the in tank pump to prime the system?
I had to do it twice, after the first "prime" i could still hear that there was air in the system, after the second time it sounded normal, like how it sounds every time you turn the key and hear the pump kick on.
'12 SPEED3 LSM--- / AUTOTECH HPFP / RACE PIPE / JBR SHIFTER BUSHINGS / SURE SHORTCUT /
14.195@101.47 (stock tune) Orlando Speedworld 3/27/13
MZRSPEED is offline   Reply With Quote
 Old 10-14-2012, 10:43 AM   #5
ThizSpeed3's Avatar
Posts: 242   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
Groaned at 13 Times in 3 Posts
i cringe hearing internal install problems, hope you get the problem resolved.
ThizSpeed3 is offline   Reply With Quote
 Old 10-14-2012, 11:06 AM   #6
ms3rick's Avatar
Posts: 2,359   (View Stats)
Take them out, clean repeat install, tighten the bolts evenly. Time > 6k engine.
2010 MS3 siLver.
Next: TMIC(WTB PM me); meow DP
Official 60-100mph Times
Official Youtube Channels
 Old 10-14-2012, 11:59 AM   #7
Mclovin80's Avatar
I can't get the damn nut all the way up on the bottom bolt of the fuel pump.
Sent from my HTC_Amaze_4G
 Old 10-14-2012, 12:10 PM   #8
pzr2874's Avatar
Posts: 3,911   (View Stats)
Groans: 89
Groaned at 103 Times in 69 Posts
the bolts are weak.... be careful. Do what Rawr said.
2007 CBM MS3
Originally Posted by Macncheese View Post
Sniff sniff... Bunch of vaginas in here.
R.I.P.
JVella22
MacnCheese
bmylez
The Following User Says Thank You to pzr2874 For This Useful Post:
ms3rick (10-17-2012)
 Old 10-14-2012, 12:15 PM   #9
08cosmic3's Avatar
Posts: 2,120   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groans: 35
Groaned at 45 Times in 37 Posts
The connection is probably not seated right. Take off and make sure it seats up into th connection properly re tighten.
Cobb AP // Stratified 20% E-85 // Cobb SRI Amsoil Dry // Cobb TIH // NGK 1 colder // Custom FMIC // Test Pipe // Forge BPV V1 (red) // Autotech // DCR VVTA // Koni FSD's // ACT 6 puck Prolite Fly // Cobb RSB // Chassis Braced // Sure SSP // JBR 88 RMM // JBR 70 PMM // CorkSport SS lines // Indy Fogs // DDM 6K HID // 6K LED fogs // FD's W/RE-11's // 13.196 @ 110.84
08cosmic3 is offline   Reply With Quote
 Old 10-14-2012, 12:41 PM   #10
Mclovin80's Avatar
Does anyone know if the nut threads all the way up the furl pump bolt. I can't get it over all of the threads!!!
 Old 10-14-2012, 12:43 PM   #11
pzr2874's Avatar
Groans: 89
u meaning the brass fitting under the pump? If you are, you don't need to get the nut ALL the way up the threads. Don't force it up the threads more than 3/4 of the way
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
speed23 (10-14-2012)
 Old 10-14-2012, 12:45 PM   #12
S.I. Reppin!
moomooz12's Avatar
Posts: 302   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
Groaned at 7 Times in 6 Posts
Yes, it should bolt right up.
Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR 88 RMM || JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs
moomooz12 is online now   Reply With Quote
 Old 10-14-2012, 01:05 PM   #13
agentgordon27's Avatar
Posts: 375   (View Stats)
agentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the world
Dayyaum, every time I see a thread about internals it's usually a probrem. I guess that goes back to people that don't have problems don't usually post about it.
Wish the CP-E option wasn't such a ball crusher money wise.
agentgordon27 is offline   Reply With Quote
 Old 10-14-2012, 01:30 PM   #14
blacknight87's Avatar
Posts: 58   (View Stats)
blacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant futureblacknight87 has a brilliant future
you might have air in your fuel system still which can casue the engine to run real bogged but it should eventually go away.
blacknight87 is offline   Reply With Quote
 Old 10-14-2012, 01:52 PM   #15
pzr2874's Avatar
Groans: 89
OP-take it all out and then reinstall. You clean the fuck out of everything?
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-14-2012, 01:57 PM   #16
Mclovin80's Avatar
Ok I took it all out again and cleaned everything up. Seems to not be leaking anymore. I feel like a pro now (at least for this install). Thanks for everyone's help.
 Old 10-14-2012, 02:02 PM   #17
pzr2874's Avatar
Groans: 89
And this isn't correct if it persists longer than ~2 mins (throwin #'s). The lines can ingest air connected....
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-14-2012, 02:05 PM   #18
actually it can go longer than 2 minutes seen it myself i work with engines everyday.
The Following User Says NO Thank You to blacknight87 For This Un-useful Post:
pzr2874 (10-14-2012)
 Old 10-14-2012, 02:07 PM   #19
pzr2874's Avatar
Groans: 89
Well good for you, but if it goes on longer than that you have more issues. blacknight87
How many of these pumps have you done?
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-15-2012, 07:45 AM   #20
robry's Avatar
Posts: 670   (View Stats)
robry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the world
Groaned at 6 Times in 6 Posts
if you followed the autotech instructions and didn't use oil when you put the o-rings back together, you probably cut an o-ring and the pump is losing pressure which is why you're having trouble starting to the car. (ask me how I know lol) But it looks like it works now so congrats.
2011 Mazdaspeed3 Celestial Blue Mica Vented block mod 12/28/12 | Built engine: First Start 2/11/13 1300mi on ODO | ATP GT3076R | PGv2 "Capt Hax" EWG mani | 44mm ebay wastegate | CP-E Big churbo TIP | "Capt Hax" 3.5" MAF/SRI | Cobb EBCS (interrupt) | ATP Turbo FMIC 600hp core | Autotech HPFP | JBR 88A RMM | Ebay DP | CNT GenPu cbe | Cobb AP | Blendmount Mirror Mount | Escort 8500 X50
robry is online now   Reply With Quote
 Old 10-16-2012, 02:40 PM   #21
Mclovin80's Avatar
Well unfortunately I still have a small leak coming from the nut attaching to the lower bolt on the fuel pump. I tried removing the pump four times, cleaning repeat all of the steps for swapping internals. I'm at a loss. Might be time to stock out and head to the stealership.
 Old 10-16-2012, 02:54 PM   #22
skeeter149's Avatar
Posts: 3,598   (View Stats)
Groans: 83
Groaned at 22 Times in 17 Posts
When you first removed that nut did you accidently loosen the part it bolts to? Mine was on so tight I actually loosened the part on the bottom of the fuel pump, try tightening that bolt or nut or whatever it is
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP, TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Autotech FP Internals. "Garaged Indefinately", (Got My Perm On)
1996 200sx SE-R- Injen CAI, GReddy SP2 CBE, Progress FSB, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "The Daily"
skeeter149 is online now   Reply With Quote
The Following 2 Users Say Thank You to skeeter149 For This Useful Post:
pzr2874 (10-16-2012), tddvrrn (10-18-2012)
 Old 10-16-2012, 03:58 PM   #23
Mclovin80's Avatar
Yeah I did check to make sure that bolt was tight into the pump. At this point I don't want to mess around with a fuel leak.
 Old 10-16-2012, 04:10 PM   #24
pzr2874's Avatar
Groans: 89
I bet it's not seated correctly on that nut. Get with NATOR there. They can dbl/triple chk w you
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-16-2012, 06:56 PM   #25
Mclovin80's Avatar
I'm almost 100% positive its not seated and I can't get it to seat correctly. Car is already back to stock this evening. Taking into the dealer in the morning. Need an oil change anyway. I'll see if they will give me synthetic if I ask for it since that is a hot topic.
 Old 10-17-2012, 07:34 PM   #26
fortressofcomfort's Avatar
Posts: 867   (View Stats)
Are the fuel pressures normal/good/back to where they were with the stock internals? I'm getting at wondering if any permanent damage was done to the cylinder part of the CDFP.
2012 Black Mica MazdaSpeed3
Street creds:
 Old 10-18-2012, 04:09 AM   #27
Mclovin80's Avatar
Fuel pressures were normal at idle to slightly above normal while driving. I have an AP now, so when I get it back I will tune it properly.
 Old 10-18-2012, 06:09 AM   #28
pzr2874's Avatar
Groans: 89
No, he's asking if your idea and pressure are back to normal since u put the stock internals in. Or did u leave the AT's in to take to the dealer?
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-18-2012, 06:44 AM   #29
Mclovin80's Avatar
I left the AT's in.
 Old 10-18-2012, 08:40 AM   #30
CtrlAlt1337's Avatar
Posts: 137   (View Stats)
CtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the world
Originally Posted by Mclovin80 View Post
I left the AT's in.
ruh roh. I'm installing my internals on the Air Force Base this afternoon in South Tampa.
CtrlAlt1337 is offline   Reply With Quote
 Old 10-18-2012, 09:59 AM   #31
Mclovin80's Avatar
Everything went fine with the install just make sure the bolt at the bottom of the fuel pump doesn't move when you tighten the nut. You should be able to hand thread the nut three quarters of the way up the bolt. And for the love of god don't cross-thread it!
 Old 10-18-2012, 10:13 AM   #32
Posts: 5,604   (View Stats)
Groans: 121
The line on the bottom of the pump is the high-pressure hardline to the fuel rail. The connection at the bottom of the pump is a check valve, and the line from it to the fuel rail has a compression connection. The nut is not supposed to thread all the way up. It should, however, be able to thread almost all the way by hand, and you just have to use a wrench to tighten it up. If it is leaking, pull the pump and look for damage on the check valve and the compression head of the fuel line.
 Old 10-18-2012, 06:56 PM   #33
Mclovin80's Avatar
Got it back from the dealer. They said nothing was leaking. I'm guessing I tightened it enough before I took it in. If it starts leaking again I probably need a new hardline. Has anyone installed a new hardline? If so, what's the part number and was it a bitch to do.
Rough start kgeier82 2010 MS3 - Troubleshoot/Diagnostics 1 09-20-2011 05:56 AM
Rough start & puff of smoke Speedsicks MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-03-2010 09:14 AM
Bogging/rough idle on start up with meth? Meder MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 05-16-2009 10:10 AM
HELP - Rough idle after dp install ccs70 MazdaSpeed 3/6 - Turbo Induction 25 10-14-2008 01:40 PM
Page generated in 0.48129 seconds with 34 queries
