 Old 03-12-2019, 04:44 PM   #1
thatguyinms's Avatar
Posts: 31   (View Stats)
thatguyinms will become famous soon enoughthatguyinms will become famous soon enough
Default Saywh3n_'s not-a-build thread
Long time lurker and I've read quite a bit but its always helpful to have other's input on my build.
So its tax return time and since I'm approaching 100k miles, I know my k04 will let go any time. I'm looking at ensuring I have the appropriate pieces on-hand to go meth/BT and I wanted to see what else could be missing.
::Flamesuit on::
Current mods:
HTP 3.5" intake
3BAR MAP sensor with pigtail
ETS TMIC
Damond EGR delete
CS HPFP internals
UR Catless dp
UR Testpipe
Corksport axleback
Damond mounts (all 3)
catchcan
Parts list to buy:
EBCS
BPV/BOV
BNR S4
Meth kit
...what else
realized I posted in GD not Builds... fml.
2013 Mazdaspeed 3
91k miles and counting
Freektuned since 17k at 21psi
Power:
HTP 3.5" intake - TR8 - CX piping - Snow Stage 2 @ 100% meth at 625mL/min- UR catless DP - UR testpipe - Corksport axleback - Turbosmart Dual port on recirc
Supporting:
Corksport HPFP - fresh blasted valves- 3Bar MAP+pigtail - Damond EGR full delete - Damond Trio - TB Coolant bypass - 51r battery w/box - Corksport shift bushings -
Known Fails:
Florida Heat - stock k04 - OEM Midpipe - shitty ebay catchcan
Last edited by thatguyinms; 03-12-2019 at 05:46 PM. Reason: MSF Database - Automerged Doublepost
thatguyinms is offline   Reply With Quote
The Following User Says Thank You to thatguyinms For This Useful Post:
Db09ms3 (03-12-2019)
 Old 03-12-2019, 05:24 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm confused. Your parts list says COBB HPFP, but your sig says Corksport HPFP.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-12-2019, 05:30 PM   #3
It’s CorkSport. Reading is hard.
2013 Mazdaspeed 3
Power:
Supporting:
Known Fails:
 Old 03-12-2019, 07:51 PM   #4
Mr.Wizard's Avatar
Posts: 1   (View Stats)
Mr.Wizard is an unknown quantity at this point
I'm in the same situation, only with fewer mods....
should get a fat tax return this year and am very near 100,000 miles and planning on getting a larger turbo
Mr.Wizard is offline   Reply With Quote
 Old 03-13-2019, 10:33 AM   #5
Jayzon's Avatar
Posts: 103   (View Stats)
Jayzon has disabled reputation
Back to Stock
Jayzon is offline   Reply With Quote
 Old 03-13-2019, 12:19 PM   #6
Fstrnyou's Avatar
Apparently writing is hard. I'll let it slide though if you blame autocorrect.
Other rides:
History:
 Old 03-13-2019, 12:22 PM   #7
I blame public education and failing memory.
2013 Mazdaspeed 3
Power:
Supporting:
Known Fails:
 Old 03-13-2019, 12:51 PM   #8
Jeff23spl's Avatar
Posts: 2,238   (View Stats)
Maybe missing a FMIC to handle the BT flow ?
If you want to add fuel with your meth kit (not just rising octane) either get a sophisticated one or something solid with less chances of problems with filters and anl fitting...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 03-13-2019, 02:14 PM   #9
based on my research, the ETC TMIC will flow plenty for stock block power. I dont' want to cut/replace the crashbar to fit a TR8 or larger FMIC and I don't want the radiator inhibited due to Florida heat/humidity.
As for heatsoaking the TMIC, I just put on the CS scoop and looking for meth kits.
I anticipate riding this til it A) vents the block, B) >250k miles, or C) life demands I need different daily. If it vents, then I'll get a built block, swap parts over, up the boost, and take some people to Gapplebees for dinner.
2013 Mazdaspeed 3
Power:
Supporting:
Known Fails:
 Old 03-13-2019, 03:02 PM   #10
Jeff23spl's Avatar
That was the reason i used...''maybe'' in front of it. In case one would like to max out the bt setup, that part could be a limit.
W/M help for not venting the bloc, even if you heat soak the tmic in traffic, you will cool the charge and raise octane if you floor it out....
The big problem is to have easy room to grow, it is like dating a sex addict girl and looking to wait untill being married....
There is some speed with high mileage on stock engine that still run fine but I don't think there is much BT setup installed at 90k miles that lasted until 250k....i could be wrong.....
Wife drive 2010 CX7
thatguyinms (03-14-2019)
AIC's build thread aroundincircles
MAZDASPEED Protegé
24 11-07-2017 07:47 PM
Page generated in 0.29222 seconds with 24 queries
