-   -   Selling car, need advice (http://www.mazdaspeedforums.org/forum/f544/selling-car-need-advice-115272/)
JustanotherMS3 06-01-2012 04:37 PM
Hello. I'm selling the speed and I'm stocking everything out except the fuel pump. Anyone know what map would be best to leave the car set to when I uninstall the Cobb from it? Or should I just set it to factory settings?
helmetface 06-01-2012 04:39 PM
Factory...
Black Metal 06-01-2012 04:39 PM
if you uninstall the ap it won't let you leave anything but stock map on it I believe.
curlyface 06-01-2012 04:40 PM
I thought you could only unmarry to factory settings? Regardless, just do factory settings.
TiGraySpeed6 06-01-2012 04:48 PM
It will return the stock map which was copied when first installed.
Would be no sense to having it leave a 'good' map after removal- that would easily allow sharing the AP. Something Cobb rather frowns upon...
JustanotherMS3 06-01-2012 05:09 PM
So would the car be ok with theinternals on a stock map
The internals**
Black Metal 06-01-2012 05:13 PM
Yes it will hit higher than requested fp but its not gonna hurt anything.
Bubba Ho-Tep 06-01-2012 05:13 PM
Yes.
memin 06-01-2012 05:18 PM
you have to re install factory map that is the only way you will be able to di vorce the ap from the car otherwise if you are planning on selling the ap or re use in other speed you wont be able because the ap is married to your speed3 in other words will be useless.
Page generated in 0.16802 seconds with 11 queries
