 Old 08-20-2013, 01:13 AM   #41
KGPrince's Avatar
Posts: 13   (View Stats)
KGPrince will become famous soon enoughKGPrince will become famous soon enough
Has anyone tried the plastidip smoke tint? It seems like a pretty good solution. No need to sand, there are no fitment issues, and you can change your mind as many times as you want at very little cost.
KGPrince is offline   Reply With Quote
 Old 08-20-2013, 01:28 AM   #42
theurgy's Avatar
Posts: 2,580   (View Stats)
It doesn't work well and comes out like this really matte finish.
I think even the dipyourcar guy doesn't even like it.
http://m.youtube.com/watch?v=iR0djNW...%3DiR0djNWecKo
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
 Old 08-20-2013, 09:18 PM   #43
xTRELLx's Avatar
Posts: 396   (View Stats)
xTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the world
Groaned at 27 Times in 14 Posts
Originally Posted by WetzMS3 View Post
Sorry to bring up a long dead post, but I was wondering if you ever got the vinyl wrap on the tail lights? I spent hours trying on my gen pu tail lights this weekend and couldn't get anything decent looking.
I'm hoping it's my lack of experience, or there is an angle to start the sheet at that I haven't thought of. I'd rather not paint them. I started with the corner tail light, knowing it'd be the toughest, just didn't think it'd prove to be damn near impossible.
So has anyone gotten vinyl to work on the outside tail lights in one solid piece?
Here's my car with VHT I just did it a few weeks ago. couldnt upload pic on phone so it took me a while to upload. Didn't want it so dark as u can tell.
xTRELLx is offline   Reply With Quote
 Old 08-21-2013, 04:46 PM   #44
xTRELLx's Avatar
Default p dip
Plasti dip doesn't look good on lights. Friends tried it b4 doing his wheels and it looked ugly.
 Old 08-23-2013, 06:48 PM   #45
Nano91's Avatar
Posts: 286   (View Stats)
Nano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the world
Thibk I might be a try the plasti dip smoke, but I would hit it with the glossifier..
Sent from my SGH-M919 using Tapatalk 4
Black Vue Dash Cam- Cobb AP V3 (Stratified tune 4 gal E85 mix) - M2 Downpipe - Swift Springs - HKS SSQV4 - Sure V2 SRI - JBR TIP - ACDelco Rear Camber Arms - West-End Custom Alignment - White Line Bump Steer - KMD Internals - Hankook Evo V12 245-40-17 -
Nano91 is offline   Reply With Quote
 Old 08-30-2013, 12:19 PM   #46
BBN
BBN's Avatar
Posts: 2   (View Stats)
BBN is an unknown quantity at this point
I used the plasti dip smoke, takes about 5 coats just to get a light smoked look. It is flat but you can use the glossifer to shine it up. I am a fan of the look, but the great thing about it is you can peel it off if you don't like it.
BBN is offline   Reply With Quote
 Old 08-30-2013, 12:43 PM   #47
theurgy's Avatar
Got any pics of it with the glossifier on?
 Old 08-30-2013, 12:59 PM   #48
BBN
BBN's Avatar
Nope I didn't use the glossifier on the taillights. I did on my wheels though and I will say it takes more than you think it would to get a good gloss.
 Old 10-05-2013, 10:58 PM   #49
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Here's with three coats of VHT with two coats of clear, no sanding prior. Light output is reduced by maybe 5% max. I can't really tell the difference with the spoiler brake light so it was well worth it imo.
speedaholic is offline   Reply With Quote
 Old 10-09-2013, 02:18 PM   #50
ibsir's Avatar
Posts: 108   (View Stats)
ibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant future
FYI, you can buy spray paint remover from Home Depot to remove VHT spray completely from the tail lights. Ask me how I know.
Str8 Tapping now Free
CS SRI~Autotech Internals~Res Delete~JBR RMM~AP V3
ibsir is offline   Reply With Quote
 Old 10-09-2013, 02:22 PM   #51
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Motsenbockers 22-oz. Spray Paint Graffiti Remover (Lift Off #4)-411-01 at The Home Depot
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 10-09-2013, 10:59 PM   #52
stayspeedy's Avatar
Posts: 23   (View Stats)
stayspeedy is on a distinguished road
I just ordered the rvinyl for my tail lights hopefully I can make it work but everyone is saying they are terrible
stayspeedy is offline   Reply With Quote
 Old 10-09-2013, 11:01 PM   #53
xTRELLx's Avatar
No dude... ugh just go pick up some vht, sand paper, clear coat, and paint thinner.
Sent from my SAMSUNG-SGH-I337 using Tapatalk now Free
 Old 10-09-2013, 11:02 PM   #54
stayspeedy's Avatar
I might as well at least try them, they are a hell of a lot easier to remove if I dont like it
 Old 10-09-2013, 11:03 PM   #55
xTRELLx's Avatar
True. Let me know when it doesnt work out for u. I'll tell u all the steps on how to get the vht to look good.
MS6 Painted Fog Lights and Tail lights rrussell50 MazdaSpeed 3/6 - Appearance 1 10-10-2012 05:55 PM
Smoked Lights Options Speed3eak Exterior 17 06-25-2010 12:27 PM
Smoked Front and rear tail lights mzdaspeed3 2010 MS3 - How-To's 14 05-14-2010 10:37 AM
Page generated in 0.33980 seconds with 29 queries
