Some insight here on air filter Guys like I mentioned on another post, soon i'll be getting AP and a tune but I'm still debating whether I should go back to sri before tuning. I had installed a jbr sri but took it of because I noticed that I lost pull in the lower band. Then I installed the corksport thermal air box to mitigate problem, probably due to heat and not being tuned. I installed back the K&N drop in. I was researching and came across this video and wanted to know what you guys think of it, I mean after all there are a lot of you who have had more experience with many aftermarket sri and could tell me how accurate is this video. The reason why it caught my attention is because they are doing it with actual dyno proof. https://www.youtube.com/watch?v=PAIxeQUSg-Q |
According to your signature you have an ets too mount and upgraded bpv. Is that bpv in 50/50 or full recirc...if it's 50/50 plug the vent and use it in full recirc. That might be where your "lack of power" is coming from. Getting rid of metered air. Yes, I would definitely put the Sri back on. As well as get a tip. |
The problem was experienced way before buying the gfb BPV. Then decided to install CS Thermal box gaining some of the pull. Then went back to drop in.My bypass valve is 35% vta and 65% recirc. When I installed the K&N drop in, I was able to gain back pull. Just thinking if this a heat soak issue and/or lack of tune.:dunno: |
Make it 100% recirc...you're not tuned to run any vta. Heat soak would be on the intercooler itself. Put the Sri back on and make it 100% recirc. |
Video is irrelevant. Filter won't add HP/TQ; everybody knows that. However it does allow for more HP/TQ with a tune, because greater airflow. You need a tune to take advantage of the added airflow. |
So you're running it VTA for the sound only? Gotcha |
Yeah, you really need to run 100%recirc until you tune for it. |
Ok guys! As soon as I get my AP, I'll be switching back to SRI and a tune inmediately. Although I have a problem, I screwed up my sri elbow because I cutted a little bit to reduce it and make it fit with the corksport thermal box so now my elbow is more of like a 45 degree angle and the jbr filter won't fit so I've been searching for a small size cone filter to fit in the corksport thermal box application but the only one I found was this: 8162 - Spectre , Air Filter 2.625 in Tall Another question would be, would I need a maf calibration also? Yes I wanted the best of both worlds, some sound but not to loud while being recirc the most percentage, because I know the car benefits the most being recirc. This is why I setup the valve to 35% vta and 65% recirc. |
no, stay away from that filter.... they sell that shit at Pep Boys = stand clear. Figure out a way to get it ALL to the way it was supposed to be. Plain and simple. |
The tuner will do a maf cal during the tuning process. Ask your tuner questions as you tune so you will have an understanding for how everything works together. |
My valve is not 50/50, it is 35% vta and 65% recirc. I'll be tuning as soon as a purchase my AP. JaybeeL you are right if I had the AP I would be able to monitor many parameters but its in my plans. I just need to gather some money. When you are married and have a child going to jr. high, you need to put priorities in its place. I can't deny, I can't wait to get the AP to get the most out of my mods, definitely running a few goodies without tuning. Running my car all this time, I have learned that definitely you need to tune even with a simple air filter. pzr2874 what is wrong with the spectre air filter? I read good reviews about it but then again its an option for those who don't want to spend much money. The only reason why I thought of them was because the good brands don't make a air filter that small.I found this article. Spectre vs. K&N Cold Air Intake Differences: Which Air Intake Performs & Sounds the Best |
I'm saying if you trimmed shit up to fit something and replacing that filter could potentially lead to other misfortune. SRI's, CAI's that were specifically designed to be run a specific way does not mean throw something else at it to "make it fit".... I don't know how else to explain it. Quote:
What don't you understand about 100% recirc? Don't even try to tune for it. Get a proper tune and be happy. |
That spectre air filter is not meant for turbo cars. It can not handle the air flow and will eventually scrunch up and smash itself. Those things are meant for single cam Hondas. Believe me a friend of mine tried it on his speed 6 injen cai and shit was toast after a month. |
It might affect response between shifts from spool but it will not affect PEAK power ever unless the afore mentioned issues occur. Unless its releasing metered air under boost it cannot affect a power loss. This coming from almost 20 years of BOV/bpv experience Just fyi |
I specifically mentioned that the problem was way before installing the valve. I know that I have to tune for the mods I have and I just can't wait! |
Definitely felt stronger when accelerating. Now getting ready for a tune! Boy can't wait, the car is definitely going to pull me back onto the seat!:cool: |
| All times are GMT -7. The time now is 05:10 AM. |
