Somethings wrong.. Decided to go into work late and head to the local dragstrip to make a pass in my recently purchased genpu. I get there and first pass I have some issues with grinding in 2nd and 3rd, so I adjust the throw plate and hit it again. I was running 16-17 consistantly.... I know that I'm not the greatest driver period, hell I'm not even mediocre. But I'm not bad enough to barely hang with a fucking impala. It just didn't seem to run very strong and my tires wasn't even barking in 1st or going into second. Boost gauge(stock) was reading 15 psi. Idk, any ideas? rt-.687 60-2.561 330-7.065 1/8-10.642 mph-70.72 1000- 13.685 1/4- 16.207 mph-89.89 This was my best time of the night, I used to run low 14s in an srt4 here. I'm guessing elevation is around 1800 or so. Side note, met a local from the forum. Horrible with names so I dont remember, but he had a very nice pu. Good guy ask well. |
1. Donate, get a VIP, and stop being a fucking Brownie. :crucified: 2. Get an AP, and a tune sure that'll help a tad, plus who doesn't love FFS? 3. Did you run 14s on a stock SRT4? 4. These cars are mod hungry, mod the fuck up and get into 12's. 5. Did I mention VIP, AP and tune? Do that. 6. Miles on the Pu? 7. Is the Pu stock? There are tons of factors, driver mod being the best of them all. |
Mph seems way down... |
It's because you're driving a mazda 3 not a speed 3. :bigok: |
2. Will get the AP soon, getting internals this week. Figured safety first. Would grab the both but my boogers aren't made of Au. unfortunately. 3. The srt. was a stage 1 but I was rather comfortable with it. That was my last sports car and was 3-4 years ago? 4-7. Doing mods slowly but surely. I have a jbr88 and stp right now. Internals thenap,the intake/tip then dp(not double penetration) then fmic and somewhere a ricey fucking bov, because I like em. Car is 11 genpu with 36xxx on the ticker 8. <3 very little homo |
You could always do a compression check if you are really concerned. |
I know somewhat how you feel, the journalist were somehow getting like 14.1 quarter times with a stock car. My guess is you were winding the RPM's out, granny shifting and either bogging down in first when you launched or spinning like crazy. I don't have my slips with me, but I was hitting like 15.1 or so at 97 I think. |
remember stock tune limits boost in 1-3 gear for the people who complained about tq steer |
And is boost limited in 3rd? |
No, this is... Quote:
Trap at least should be higher and should be somewhere in the 15's if you suck at driving. |
@ThaKing; |
Well I'm going to check my plugs in the morning and see if I have a vacuum leak or something when I get time ( recommended by a local) I hope I can figure something out. If not hopefully in the next couple weeks I can buy an AP. |
Did you have DSC off? 36k miles your plugs could be wore out. Go by the zone and see if there are any stored codes. |
I've also got a clanky sound around driver side wheel when the clutch isn't pressed in, but only half the time. |
Its VA, how hot was it when you went? How long were you in the staging areas? How does the car feel now? I'm guessing you were heat soaked to hell that or maybe a shitty tank of gas. If you are hitting boost but not going anywhere you are probably pulling alot of timing. |
But yeah, your traps are on par with 185 whp. Something isn't right. Went to the 1/8th mile Friday night and an intake/internals/AP OTS Pu was running 9.4@77mph. A 2.5 60ft indicates you're rolling out of the box and not dropping the clutch from ~3k RPM. (or getting massive wheelspin/hop, but that doesn't sound like your problem) Can't afford an AP? Donate, get with Nator group. I would have no problems unmarrying from my car to troubleshoot for a friend in need, and I suspect someone else would do the same for you. Stage 0 logs will help. |
I'll check those for sure this evening, honestly didn't think of it. I knew something wasn't right the day at the strip, I was so sluggish all the way through the gears. I mean alot of my time was due to my rusty skills and never practicing launching the car but still yet it still didn't compensate for that bad of a time. I do need to donate and tbh the only reason I haven't yet is because I'm a cash only person right now (divorce) and I haven't set even a bank account up yet. I may ask a family member to do it for me and I can pay em back with a little interest haha. A nator group would be very beneficial and I'm looking forward to the awards of VIP, just have to wait a little to join ip. Now the good news. Today I replaced plugs, tightened and checked everything under the hood, cleaned the maf and replaced the air filter( which was disgusting seeing I just bought it from a dealer) But after all of that throttle response is 100% better along with the power. I dont know what fixed it but it did and made a world of difference! Thanks to everyone who gave an input and removed a huge weight off my shoulders! |
Finally a decent noob! LOL... It's already obvious something is way wrong. My suggestion, check your engine bay for any loose vac lines, boost tubes, intake. Clean your MAF. Also I'd go and plug it in to a scanner to see if anything comes up. You never know, old owner quite possibly could/may have unplugged lights that are supposed to be on. |
You NEED to rip the bay apart to inspect and clean it all. Plugs, TB, intake, FP...etc...etc |
| All times are GMT -7. The time now is 05:05 AM. |
