![]() | | #81 | ![]() |
![]() Join Date: Mar 2010 Location: SOJO
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score
You mounted to the floor or on sliders? Have any more detailed pigs of your install? Seems like most pics are with the door open from a distance. | |
![]() | | #82 | ![]() |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
Groaned at 78 Times in 45 Posts
| Not Ranked : 0 score I got Brey Krause steel side mounts that bolted onto the sides of the seat and welded onto the stock slider. I'll try to get a pic and post it up. |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
Groaned at 55 Times in 26 Posts
(Thread Starter) | Not Ranked : 0 score I think the Evo3 "could" fit, your just probably won't be centered with the steering wheel and you may be stuck having the seat closer to the wheel then you'd like. If you can find a local shop to test it out for you that would be best. I'm 5'7" and 230lbs, I fit in the Evo2 US seat. Depends on your body fit as well, I tried a bunch of seats before I bought one. If you are coming to the MNM you can try mine. |
![]() | | #84 | ![]() |
Thanks for the offer on fitting, but I won't be making it to MNM. Thanks for the info and looking forward to the pic. Can you comment at all on how much lower it sits than stock? Last edited by Tweaek; 03-02-2013 at 10:27 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score You may be able to fit it with removing the seatbelt cover or just cutting a section out of where the shoulder area hits. You want to check out he OMP WRC XL seat, and the Sabelt Titian seat those might suit you better. I'm not 100% on fitment though. I think the Sabelt is a better fit though. The ass part of the seat is just as wide as mine plus the shoulder harness slots are taller allowing for proper belt angles with taller drivers. Edit: links provided http://www.racerpartswholesale.com/p...lassSeat/Seats http://www.racerpartswholesale.com/p...gWRCSeat/Seats Dimensions are listed under additional information. |
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | Tweaek (03-07-2013) |
![]() | | #86 | ![]() |
Groans: 320
| Not Ranked : 0 score The seat sits much lower than stock at the lowest setting. I had to raise it up because I had trouble seeing past the hood on autox courses. Plenty of headroom, even with a helmet. |
| The Following User Says Thank You to Manny For This Useful Post: | bertrand_CX_7 (03-03-2013) |
![]() | | #87 | ![]() |
(Thread Starter) | Not Ranked : 0 score Which seat bracket are you using? My wedge bracket is about the same height as stock at its lowest setting? |
![]() | | #88 | ![]() |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
| Not Ranked : 0 score you damn fatties
__________________ |
![]() | | #89 | ![]() |
Groans: 320
| Not Ranked : 0 score Stock seat bracket, stock slider assembly. Side mounts bolted onto the stock slider assembly. Modified the slider assembly a bit so the steel side mounts could be welded onto the slider assembly as an extra measure. I'll have to take a pic, sounds complicated, but it works. I did not have to buy a seat bracket or slider assembly, just side mounts and hardware for it...and the seat of course. |
| The Following 2 Users Say Thank You to Manny For This Useful Post: | breakfasteatre (03-03-2013), Celestspeed3 (03-03-2013) |
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ah, I didn't even look at that as an option. I have the power seat bracket and I don't think it would have even worked. Good to know for everyone else they can save some cash. |
![]() | | #91 | ![]() |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
Jason
__________________ JRL Tuning 510-459-7229 www.full-race.com | |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's one of the best things you will ever do to your car. Second only to tires. |
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | Manny (03-04-2013) |
![]() | | #93 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score I wish I could afford a seat and at least a 4 points harness. :-/ |
![]() | | #94 | ![]() |
Jason
![]() | | #95 | ![]() |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
Also someone who has an evo seat.. Can you measure the clearance from the floor to the top of the seat/ bracket? I'm trying to get an idea how they will fit since I have an amp below my seat.
__________________ 2010 ms3-sold ww evo x -385/360 Last edited by Zbrit00x; 03-08-2013 at 12:11 PM. | |
![]() | | #96 | ![]() |
![]() Join Date: Jan 2013 Location: Union City, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
Groans: 128
| Not Ranked : 0 score Where can I see pictures of your seat setup? |
![]() | | #97 | ![]() |
| Not Ranked : 0 score And from the bottom of the bracket to the bottom of the seat. I'd like to know how much lower the seat actually sits. |
![]() | | #98 | ![]() |
Jason
| The Following User Says Thank You to SFWD 1934 For This Useful Post: | Yousuf (10-02-2015) |
![]() | | #99 | ![]() |
| Not Ranked : 0 score ive just been trying to find any decently priced ones.lol. Im going to be looking at a sparco milano tomorrow, hopefully that goes well
__________________ 2010 ms3-sold ww evo x -385/360 |
![]() | | #100 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
Groans: 52
Groaned at 145 Times in 38 Posts
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
| The Following User Says Thank You to bertrand_CX_7 For This Useful Post: | Yousuf (10-02-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/sparco-evo2-review-117136/ | ||||
| SEATS - Page 3 | This thread | Refback | 06-23-2012 09:25 AM | |
| Sparco Prista 18x8 | eliminator | MazdaSpeed 3/6 - Wheels & Tires | 13 | 01-28-2011 05:12 PM |
