 Old 04-28-2014, 07:31 AM   #1
valkyr's Avatar
Posts: 34   (View Stats)
valkyr is a jewel in the roughvalkyr is a jewel in the roughvalkyr is a jewel in the rough
Default Spark Plug Gap GENERAL questions
The 2010 Mazdaspeed3 manual states that the preferred gap is 0.024 -> 0.027:
2010 Mazda Speed3 Manual on page 10-4.
Question 1:
I'm curious what the history of coming up with 0.026 -> 0.028 was if anyone remembers?
I'm running mostly stock parts except for an air intake and a [apparently] a short shift plate.
Question 2:
Why do spark plug replacements come gapped so large at 0.044 when you buy replacements? Are the autoparts stores selling us the same plug that goes in the Stock Mazda 3 (non-speed 3)?
valkyr is offline   Reply With Quote
 Old 04-28-2014, 07:42 AM   #2
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
CosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the world
If you're going into the store and asking the counterman to look something up, you're taking your chances.
Know what you want and ask for it by number. Last set I got were gapped .028.
"I only do what the voices in my wife’s head tell her to tell me to do"
CosmicArkie is offline   Reply With Quote
The Following User Says Thank You to CosmicArkie For This Useful Post:
trancehead (04-28-2014)
 Old 04-28-2014, 07:46 AM   #3
valkyr's Avatar
I think most of us know that
Did you get the NGKs? They were out of the NGKs but I see on Napa those are gapped at 0.027 (damn it). I regapped mine to 0.030.
Anyone know why the Densos and autolites come gapped so large then?
 Old 04-28-2014, 07:53 AM   #4
SternRitteR's Avatar
Posts: 64   (View Stats)
SternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to behold
Groaned at 7 Times in 5 Posts
You americans with your imperial decimal places . So much easier and more accurate to say 0.7mm if your mods allow it .
BNRS3 CORKSPORT STAGE 2 INTAKE AUTOTECH HPFP FORGE INTERCOOLER TOTAL MPS DOWNPIPE MIJ CATBACK COBB 3PORT EBS DICE DUST CAPS TB COOLANT DELETE FORGE V2 BPV
SternRitteR is offline   Reply With Quote
 Old 04-28-2014, 06:53 PM   #5
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
Murcia!
If you buy stock heat range plugs gap them to stock. There's a reason they are that way. I'm no expert in the history of spark plug gap but I've never had a problem gaping them to stock specs.
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
 Old 04-29-2014, 06:31 AM   #6
hitmeagaintubesock's Avatar
Posts: 257   (View Stats)
hitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the world
I figured out the hard way in my gen one that every thing the parts places sells is gapped wrong. I replaced plugs and I was told to gap at.051 then I had spark blow out like crazy. Done a little reading and saw that was way off. I work for a part store and sent an email to our programmers to fix the incorrect gap info. They didn't.
2014 Ford mustang gt: k&n drop in filter, heart throb muffler deletes, sr performance front and rear sway bars, bmr lower control arms, h&r springs, bmr adjustable pan hard bar, bmr upper control arm, barton short shifter and two post bracket.
2012 speed3: gone but not forgotten
86 Porsche 944 turbo. Sold will be missed
88 dodge ram: 4 inch rough country lift, 35 1250 bfg mud terrain km2, ex fuel injected 318, edelbrock intake, edelbrock carb, mopar performance headers, 340 mopar petformance purple shaft cam, flowmaster single chamber mufflers with true duals
2011 ford fusion awd v6 kid hauler
hitmeagaintubesock is offline   Reply With Quote
 Old 04-29-2014, 06:39 AM   #7
DVM17's Avatar
Posts: 1,283   (View Stats)
DVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the world
Groaned at 25 Times in 6 Posts
They come gapped so large as they aren't just to cater to mazdaspeed's needs.
and .026 is the preferred gap seeing as when you go larger, boost tends to blow the spark out. hell, I'm gapped to .024 right now on stock heat range plugs and I have full bolt-ons (except for mani) and it runs great.
Now if I were getting knock, I would definitely switch out for the colder plugs I have sitting in my garage. But I saw spark blowout last time I used them.
This has been covered many times. I don't see the need for another thread about just wondering why the gap is like that. You want the gap as wide as possible to make the most power (optimized amount of spark), but there's a finite line between widest gap allowed and spark blowout. It takes a while to find the sweet spot. (at least for me)
2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
DVM17 is offline   Reply With Quote
Spark Plug Questions RedLegSoldier81 MazdaSpeed 3 - Engine, Transmission & Driveline 11 12-29-2011 10:47 AM
spark plug questions dannyboy1234 MazdaSpeed 3 - Engine, Transmission & Driveline 13 08-14-2011 12:44 AM
spark plug blackwidow Custom Performance Engineering (cp-e.com) 12 03-07-2011 04:08 PM
Spark Plug Gap khaydin
Cobb Access Port/Maps
5 12-01-2008 10:17 PM
Page generated in 0.28261 seconds with 25 queries
