  • 1 Post By Db09ms3
 Old 06-12-2019, 02:13 PM   #1
Clintb3astwood's Avatar
Posts: 14   (View Stats)
Clintb3astwood will become famous soon enough
Default Speed 3 Gen 2 tech package light mods
Hello Guys!
I'm new to the forums and a new mazdaspeed 3 enthusiast. I hope this post is in the right section.
I haven't picked up a speed 3 yet but im looking to grab one by end of summer, beginning of fall.
In the mean time ive been working a project, i used to do custom headlights on the side and ive always waned to do a custom job on Speed 3 tech package headlights. So right now i have opened a set of speed 3 technology package lights and have modded the stock projector with sharpen the cut off, as well laser etched a custom design and did a passive demon eye mod, as well as led demon eyes. To my surprise i discovered behind the triangle section of the lights cover the DRL section, there might be space to add a second projector. I shall post pics for your viewing and progress here shortly.
Clintb3astwood is offline   Reply With Quote
 Old 06-13-2019, 06:51 AM   #2
Opened the light and discovered some space there for possibly a second projector.
received_2178948442172722 by stephen martindale, on Flickr
received_436615110474349 by stephen martindale, on Flickr
I went on the retrofiitsource.com and got STI-R clear lenses and had this design laser etched
20190513_182039 by stephen martindale, on Flickr
20190513_182018 by stephen martindale, on Flickr
Testing led demon dye mod
20190513_214835 by stephen martindale, on Flickr
20190513_214746 by stephen martindale, on Flickr
20190513_214801 by stephen martindale, on Flickr
20190513_214332 by stephen martindale, on Flickr
Last edited by Clintb3astwood; 06-21-2019 at 11:34 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-14-2019, 07:03 AM   #3
Is there a moderator that could assist with resizing these photos? i have more to post but i have no idea why they are coming up so damn big!
The Following User Says Thank You to Clintb3astwood For This Useful Post:
Db09ms3 (06-14-2019)
 Old 06-14-2019, 09:32 AM   #4
Db09ms3's Avatar
Posts: 396   (View Stats)
Groans: 81
Don't change it! That's like making your peepee smaller
danb likes this.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
Clintb3astwood (06-21-2019)
 Old 06-14-2019, 09:34 AM   #5
Bertospeed3's Avatar
Posts: 113   (View Stats)
Bertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud ofBertospeed3 has much to be proud of
Try not using photofucket and upload the images thru the forums with the "insert image" button.
They look really good tho. I have plans myself using the majin M but not in the headlights. I wanna see these mounted
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
 Old 06-19-2019, 08:13 AM   #6
LOLOLOLOL
Yeah man idk, i used photobucket years ago and never had issues, i come back and its charging you now for storage and all sorts of shit smh, ill reupload these in a bit using the insert image feature. so just copy the URL from the pic and thats it?
The Majin M is so dope, i cant wait til i finish them, havent had much time, 7 day work weeks between 2 jobs suck!
20190513_194744 by stephen martindale, on Flickr
20190513_194114 by stephen martindale, on Flickr
Screenshot_20190517-092550_Messenger by stephen martindale, on Flickr
So the above photo shows the projector cut off stock and unmodified. as you can see its a bit blurry with not much color, In the back of the projector, the reflector bowl where the hid light reflects, is dull and burned.
After opening the projector and swapping the reflector bowl with a fresh one, and a bit more tuning, i was able to get a better cut off.
Screenshot_20190517-092554_Messenger by stephen martindale, on Flickr
20190517_010507 by stephen martindale, on Flickr
A much better cutoff
20190517_010508 by stephen martindale, on Flickr.
Last edited by Clintb3astwood; 06-21-2019 at 11:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-21-2019, 11:48 AM   #7
I finally found a better image hosting site that allows me to adjust the picture sizes.
On to more pictures! So i opened the projector again and performed what is called the Passive Demon eye mod. basically you spray a specific portion of the inside of a projector with a color paint of your choosing, and in the day time at the right angle, it gives off the reflective property of that color through the lens!! i chose yellow!!
20190605_151551 by stephen martindale, on Flickr
20190605_151555 by stephen martindale, on Flickr
20190605_151520 by stephen martindale, on Flickr
20190605_151523 by stephen martindale, on Flickr
20190605_151514 by stephen martindale, on Flickr
20190605_151557 by stephen martindale, on Flickr
And i did a little bit more tweaking to the projector lens for a sharper cut off, still needs a bit more work.
20190605_233417 by stephen martindale, on Flickr
Using Flickr now, Photobucket is garbage.
Last edited by Clintb3astwood; 06-21-2019 at 11:48 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-21-2019, 12:37 PM   #8
Yeah man, fuck photobucket.
So I gotta ask, will you be providing this service to msf members?
CP-e TMIC
JBR 88 Duro RMM
 Old 06-21-2019, 01:07 PM   #9
Its hard to say, typically a job like this could take me a couple days to maybe even 2 weekends or so. But as i said before i work 7 days a week and 2 jobs so my time is so limited, its insane!!! like i wanna work on the lights tonight but something else came up. Either tomorrow or sunday im going to attempt to cut and fit the other projector in the DRL.
If the lights come out the way i want and all goes well, i MIGHT provide the service.
Heres my lights on my old car i did, these took me a month to do, between working 6 days a week at my full time job lol but a buddy of mine helped out.
In reference to how the lights look unmodified:
IMAG4811 by stephen martindale, on Flickr
After:
FB_IMG_1428373102935 by stephen martindale, on Flickr
IMAG0262_1 by stephen martindale, on Flickr
IMAG0264 by stephen martindale, on Flickr
IMAG6383 by stephen martindale, on Flickr
received_10207115304184817 by stephen martindale, on Flickr
received_10207115301904760 by stephen martindale, on Flickr
received_bWVzc2FnZV9ibG9iX2F0dGFjaG1lbnQ6MTA3OTY4O Tk1NTM5MTE3NQ_1 by stephen martindale, on Flickr
MY phone crashed earlier in the year, or i would have posted more of my work.
This is the first time ive done mazda lights so im making my way around them, opening them was a total pain cause i really didnt know where all the hidden screws were but after i found them all opening was easy, so idk ill see. If these come out great, and my time frees up i might offer a limited round of services.
 Old 06-21-2019, 02:36 PM   #10
Dark_Signal's Avatar
Posts: 245   (View Stats)
Dark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the world
Dude that's pretty sweet. Good work man.
Dark_Signal is offline   Reply With Quote
 Old 06-23-2019, 03:51 PM   #11
Thanks man, been wanting to start dremeling so i can fit the other projector in but i have no time =/. Hopefully i can start again soon.
 Old 06-24-2019, 09:05 AM   #12
yeah those lights really dressed up that sentra. looks clean as hell. custom headlights are absolutely on my list just not sure when i'll ever get to them
CP-e TMIC
JBR 88 Duro RMM
 Old 06-24-2019, 09:23 AM   #13
Police - Grammarhead
Vansquish's Avatar
Groans: 1,867
Given that it's a Maxima, those lights really did a number on the car....
The Following 2 Users Say Thank You to Vansquish For This Useful Post:
Clintb3astwood (06-24-2019), Db09ms3 (06-25-2019)
 Old 06-24-2019, 09:47 AM   #14
ahhhh i was too focused on those lights to tell the difference lol
CP-e TMIC
JBR 88 Duro RMM
The Following User Says Thank You to Bertospeed3 For This Useful Post:
 Old 06-24-2019, 10:42 AM   #15
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
Yeah, definably did a number on that automotive
 Old 06-24-2019, 11:14 AM   #16
Ha thanks man, that was my old baby, that car was no slouch.
It had high compression pistons, 11.1 Wiseco, BC stage 2 cams, ported and polished heads, valves and springs done, 4" intake, 3 exhaust, 3 inch custom y pipe, 560cc GTR injectors, 320 aem pump, 350z haltech with custom PNP harness, the list was endless. that car was like 340+whp 333Ft lbs Tq. that thing was a monster. Low beam projectors were Lexus non AFS projectors, custom tuned, high beams were mini H1 projectors.
Haha thanks man, i really want to start cutting to add that second projector in the tech package lights, im 90% confident they will fit too!
Last edited by Clintb3astwood; 06-24-2019 at 11:14 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-08-2019, 09:04 AM   #17
Hello Fellas, back again with a few more updates.
Got a weekend off out of my 7 day work week, and spent a few hours in the garage.
Basically what i did this weekend, is cut up the DRL section to mock fit the mini H1 projector. I also removed the oem stock projector and swapped in the Modded stock projector with trimmed cutoff shield and clear lens for more light, but ill let all the pictures do the talking.
 Old 07-08-2019, 09:12 AM   #18
20190707_193537 by stephen martindale, on Flickr
20190707_193541 by stephen martindale, on Flickr
Getting an idea of fitment
20190707_193820 by stephen martindale, on Flickr
cutting begins
20190707_201104 by stephen martindale, on Flickr
20190707_201107 by stephen martindale, on Flickr
HOusing must be trimmed as well,
20190707_233610 by stephen martindale, on Flickr
Swapped modded projector in and test fitted G37-R shroud.
20190708_004755 by stephen martindale, on Flickr
20190708_004813_resized by stephen martindale, on Flickr
20190708_004816_resized by stephen martindale, on Flickr
20190708_005027_resized by stephen martindale, on Flickr
20190708_005032_resized by stephen martindale, on Flickr
20190708_005126_resized by stephen martindale, on Flickr
These are just rough drafts for now of how it should look.
At some point ill start on the driver side light and send updates, next step is to paint inside the H1 projectors yellow, mod the driver side projector, then aim and mount the H1 projectors to make sure they are aligned with the oem projector beam..
End goal is to run all four projectors as low beams, stay tuned!
 Old 07-08-2019, 09:22 AM   #19
i want this so bad
CP-e TMIC
JBR 88 Duro RMM
 Old 07-08-2019, 09:43 AM   #20
i want this so bad
Its a bit of work, honestly the part im gonna be stuck on is cutting the shrouds to fit over the projectors, mainly the one in the DRL section of the light. the low beam oem projector, that shouldnt be tooo hard, once the projectors are mounted in, shrouds will be cut to fit, then i can paint everything and mount halos.
Page generated in 0.51899 seconds with 25 queries
