Like Tree18Likes
 Old 01-16-2012, 07:17 PM   #41
xb2ms3's Avatar
Posts: 636   (View Stats)
You should monitor your fp very carefully, there were some people that were having issues including me with just an intake and tip.
On the stage 1 ots map I was overboosting to 20 psi causing my fp to drop dangerously low.
2011 Black Mica MS3
NJ NATOR NY
 Old 01-18-2012, 04:00 PM   #42
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
As promised:
2012 Mazdaspeed3 Dyno Stock vs Cobb Stage1 bolt-ons 273hp, 273lb/ft torque - YouTube
Car gained 23hp and 43lb/ft with the Stage 1 OTS map, SF SRI intake, and TIH/TIP.
@410ms3: When money comes in for the next round of mods I will probably seek out someone who specializes in the L3-VDT. For what I needed done (stage 1 mods and dyno runs) Agile did a fine job.
@xb2ms3: I plan to monitor the fuel pressure and boost moving forward. If I suspect anything I will move forward with the fuel system upgrades.
The Following 5 Users Say Thank You to fortressofcomfort For This Useful Post:
dankrdan (01-18-2012), Elusivellama (01-20-2012), Onelovesoccer (01-18-2012), rfinkle2 (01-18-2012), Stingray69 (01-18-2012)
 Old 01-18-2012, 09:46 PM   #43
UPDATE:
Well dammit you guys were right!
Car was breaking up around 4.5k - 5k in 2nd gear. Only in 2nd gear and only when I can get traction. Almost like it was pulling timing like when traction control kicks on.
Tried monitoring boost while driving.... a couple spikes to 18psi but they weren't accompanied by anything unusual.
Monitored knock retard... was able to recreate the 2nd gear "surging" which is hard to do without wheelspin now. No knock retard. Hmmm.
OK this trying to monitor and drive is fucking impossible.
Figured out how the AccessPort logging function works. Finally was able to capture a log with the "default" parameters while the surging was occuring. See below.
Bottom line... yes I am seeing (and feeling) the dreaded GenPu low fuel pressure problem grrrrr. Its weird that it only happens in 2nd gear and not all the time.
SO NOW WHAT? Who wants to put a better fuel pump on this for me? Who is up to the challenge? Also, does this mean I will be able to run Stage2 maps after I upgrade the pump?
Save the "I told you so bullshit" ok? Just help me out here.
Thank gawd for the internets and all you peoples. Big props to... YOU
Look at the sixth column in. FP starts to tank below 1500psi around 4400rpms with a low of 773psi @4873rpms. I get off the throttle about 9 rows from the bottom (5349rpms) and you see the FP start to recover about 1/5 of a second later.
How can the fuel pressure drop that low but still maintain a a/f ratio of 9.x ?? In physical terms, does that mean there is ENOUGH fuel in the combustion chamber but it isn't DISPERSED correctly in terms of a direct injection application and this is causing unusual flame fronts and/or combustion patterns inside the cylinder(s)? Is that the idea here?
Time Actual AFR (AFR) Boost (PSI) Boost Air Temp. (? F) Calculated Load (Load) HPFP Act. Press. (PSI) Intake Temp. (? F) Intake Valve Adv. (?) Knock Retard (?) Long Term FT (%) MAF Voltage (V) Mass Airflow (g/s) RPM (RPM) Short Term FT (%) Spark Adv. (?) Throttle Position (%) Vehicle Speed (mph) Wastegate Duty (%)
353.43 9.99 13.26 51.8 1.82 1657.72 37.4 0.12 0.85 0 4.06 199.8 4315 0 4.5 72.93 37.9 30.37
353.47 9.76 13.98 51.8 1.87 1553.3 37.4 0.25 0.85 0 4.08 202.82 4298 0 4 72.93 37.9 24.88
353.51 9.76 14.41 50 1.89 1582.31 37.4 0 0.85 0 4.09 204.36 4383 0 4 72.93 39.15 21.8
353.55 9.76 14.62 50 1.89 1493.84 37.4 0.12 0.85 0 4.1 205.9 4430 0 4 72.93 39.15 21.91
353.61 9.53 14.41 48.2 1.86 1344.45 37.4 0 0.85 0 4.12 208.98 4612 0 4.5 73.32 39.15 25.4
353.65 9.65 14.19 48.2 1.84 1300.94 37.4 0.38 0.85 0 4.14 211.34 4687 0 4.5 73.32 42.25 27.36
353.67 9.53 14.05 48.2 1.82 1295.14 37.4 0.31 0.85 0 4.16 214.5 4729 0 5 73.32 42.25 28.85
353.71 9.65 14.05 48.2 1.82 1228.43 37.4 0.38 0.85 0 4.16 215.29 4786 0 5 73.32 42.25 30.5
353.77 9.53 13.98 48.2 1.82 1158.81 37.4 0.38 0.15 0 4.17 216.9 4823 0 6 73.32 42.25 30.46
353.79 9.42 14.05 48.2 1.83 1081.94 37.4 0.12 0.15 0 4.17 216.9 4820 0 6 73.71 43.5 28.27
353.83 9.19 14.05 48.2 1.82 1047.14 37.4 0.25 0.15 0 4.19 220.13 4841 0 6 72.54 43.5 19.58
353.89 8.96 14.33 48.2 1.85 942.71 37.4 0 0.15 0 4.19 220.94 4777 0 5.5 67.86 43.5 7.39
353.93 9.07 14.84 48.2 1.88 861.49 37.4 0 0.15 0 4.19 220.94 4717 0 5.5 64.74 43.5 0
353.95 9.3 14.76 48.2 1.86 839.74 37.4 0 0.15 0 4.17 216.9 4762 0 5.5 62.01 42.87 0
353.99 9.53 14.62 48.2 1.85 822.34 37.4 0 0.15 0 4.17 216.9 4789 0 5.5 58.89 42.87 0
354.05 9.76 14.12 48.2 1.81 773.02 37.4 0 0.15 0 4.18 217.71 4873 0 6 55.38 42.87 0
354.09 9.99 13.83 48.2 1.78 780.28 37.4 0 0.15 0 4.15 213.71 4895 0 6.5 53.43 42.87 0
354.12 9.76 13.4 48.2 1.76 774.47 39.2 0 0.15 0 4.16 214.5 4921 0 6.5 53.04 44.12 0
354.14 9.65 13.26 48.2 1.76 777.37 39.2 0 0.15 0 4.18 217.71 4950 0 6.5 53.82 44.12 0
354.18 9.65 13.4 48.2 1.76 780.28 39.2 0 0.15 0 4.18 217.71 4990 0 6.5 53.43 44.12 0
354.22 9.76 13.26 48.2 1.74 802.03 39.2 0.06 0.15 0 4.17 216.09 5023 0 7 53.04 44.12 0
354.28 9.65 13.04 48.2 1.74 836.84 39.2 0 0.15 0 4.18 217.71 5033 0 7 52.65 44.74 0
354.32 9.88 12.9 46.4 1.72 826.69 39.2 0.06 0.15 0 4.16 214.5 5016 0 7 54.6 44.74 0
354.35 9.53 12.68 46.4 1.72 812.18 39.2 0.38 0.15 0 4.19 220.94 5105 0 7.5 53.82 44.74 0
354.39 9.42 12.4 46.4 1.71 844.09 39.2 0 0 0 4.18 219.32 5176 0 7.5 53.82 44.74 0
354.41 9.53 12.47 46.4 1.71 883.25 39.2 0.25 0 0 4.19 220.13 5204 0 7.5 53.43 45.98 0
354.45 9.99 12.54 46.4 1.72 833.94 39.2 0 0 0 4.18 217.71 5102 0 7.5 54.99 45.98 0
354.49 9.42 12.68 46.4 1.73 848.44 39.2 0.06 0 0 4.2 221.75 5102 0 7.5 56.55 45.98 0
354.53 9.42 12.61 46.4 1.71 883.25 39.2 0.06 0 0 4.2 222.57 5208 0 8 54.6 45.98 0
354.57 9.53 12.54 46.4 1.7 833.94 39.2 0 0 0 4.21 224.23 5361 0 8 51.48 46.6 0
354.61 9.53 12.54 46.4 1.69 864.39 39.2 0.12 0 0 4.23 226.72 5368 0 8 52.65 46.6 0
354.67 9.53 12.61 46.4 1.71 945.61 39.2 0 0 0 4.24 228.38 5334 0 8 53.43 46.6 0
354.69 9.53 12.68 46.4 1.71 846.99 39.2 0 0 0 4.23 227.55 5353 0 8 52.65 48.47 0
354.73 9.53 11.75 46.4 1.71 909.35 39.2 0.06 0 0 4.22 225.89 5349 0 8 31.98 48.47 0
354.77 9.76 9.17 46.4 1.56 868.75 39.2 0 0 0 3.56 141.48 5233 0 10.5 20.67 48.47 0
354.81 9.19 4.94 46.4 1.17 881.8 39.2 0.31 0 -1.56 2.94 77.55 5212 0 14.5 11.7 48.47 0
354.85 13.78 -4.96 46.4 0.5 1351.7 39.2 0.56 0 -1.56 1.76 11.58 5154 0 25.5 3.51 47.85 0
354.91 27.68 -9.91 46.4 0.17 1360.41 39.2 0.62 0 -1.56 1.4 5.24 5091 0 48.5 2.34 47.85 0
354.93 29.29 -11.85 46.4 0.07 1369.11 39.2 0.31 0 -1.56 1.36 4.37 5016 0 50.5 1.56 47.85 0
354.99 29.29 -12.28 46.4 0.05 1369.11 39.2 0.31 0 2.34 1.32 4.37 4993 0 50 1.56 47.85 0
355.01 29.29 -12.57 46.4 0.05 1374.91 39.2 0.12 0 2.34 1.43 5.46 4924 0 49.5 1.56 48.47 0
355.07 29.29 -12.57 46.4 0.04 1377.81 39.2 0 0 2.34 1.34 4.54 4889 0 48.5 1.56 48.47 0
Last edited by fortressofcomfort; 01-18-2012 at 10:06 PM. Reason: flame fronts bullshit
The Following User Says Thank You to fortressofcomfort For This Useful Post:
rfinkle2 (01-20-2012)
 Old 01-18-2012, 10:11 PM   #44
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
this is why we tell noobs to SEARCH...there are plenty of stickies that explain all this shit.
READ----> http://www.mazdaspeedforums.org/foru...st-read-99499/
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
 Old 01-18-2012, 10:14 PM   #45
Captain KR's Avatar
Posts: 2,320   (View Stats)
Groans: 391
plenty of peeps in baltimore are going to be willing to help. I can also assist and show you what to do.
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
fortressofcomfort (01-20-2012), rfinkle2 (02-01-2012)
 Old 01-18-2012, 11:50 PM   #46
bigriver's Avatar
Posts: 1,123   (View Stats)
Originally Posted by fortressofcomfort View Post
UPDATE:
All those numbers on my iphone screen...is this the fucking Matrix, hahah!
Excel is the preferred method.
The Following 2 Users Say Thank You to bigriver For This Useful Post:
rfinkle2 (02-01-2012), WhoIsJeremy (01-20-2012)
 Old 01-19-2012, 06:51 AM   #47
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Just in case you wanted something to read to scare you into a fuel pump upgrade:
http://www.mazdaspeedforums.org/foru...-my-car-99745/
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
 Old 01-20-2012, 11:05 AM   #48
@deadlandxtreme: I would love to see your blown engine but it is in the VIP section. I have not paid yet. Only VIPs can see blown Mazdas
@wdawson4: I might have to take you up on your offer as no one else has responded. I am kind of surprised that you are only one to offer help to a newb. When I had my 2004 Passat the forum folks at Passatworld were much more ready to help each other. I guess its a little different around here.
If anyone else still wants to help guide me through the fuel pump internals process let me know; I do have money and your efforts would not go unrewarded.
The Following 3 Users Say Thank You to fortressofcomfort For This Useful Post:
Captain KR (01-20-2012), qtrmile beast (01-20-2012), rfinkle2 (02-01-2012)
 Old 01-20-2012, 11:12 AM   #49
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
in before OP decides he needs a new BOV
 Old 01-20-2012, 11:25 AM   #50
bigriver's Avatar
Lol! But only if there are dynos to prove the gains (in VTA) are legit. Zoom zoom pssshhhhhht ftw!
 Old 01-20-2012, 01:34 PM   #51
Groans: 82
Just donate a few bucks. It's worth it to see Mazda's XXX hardcore style. Mine had a big hole, it took a rod and gushed all over the road!
The Following 2 Users Say Thank You to deadlandxtreme For This Useful Post:
rfinkle2 (01-20-2012), SofaKingAwesome (01-20-2012)
 Old 01-20-2012, 02:18 PM   #52
OK I just donated $100. It still doesn't say VIP under my name. Next step = avatar acquisition.
I am now able to see the blown motor thread. But it seems no one could absolutely figure out the cause of the bent rod? Maybe prior owner had a 300hp shot of NOS on there?
Regardless, next step is fuel pump upgrade. The RFP is still open if anyone is interested. I'm going to pull the trigger early next week and move forward.
Thanks people.
The Following 4 Users Say Thank You to fortressofcomfort For This Useful Post:
bigriver (01-20-2012), Captain KR (01-20-2012), rfinkle2 (01-20-2012), SofaKingAwesome (01-20-2012)
 Old 01-20-2012, 02:31 PM   #53
COCKSTRONG
Groans: 890
Welcome! Now that I don't want to kill you, look to your local members for install help and get a PERM/dizzy/etc e-tune. Or hit up CP-e. Please pick boobies for your avatar.
 Old 01-20-2012, 02:40 PM   #54
bigriver's Avatar
Thanks people.
I think if you used Paypal e-check, it will show VIP when the payment clears. Thanks for donating man. Shit, if I lived on the East Coast I would help you with the fuel pump and bring all my tools and shit.
 Old 01-20-2012, 03:40 PM   #55
Captain KR's Avatar
Groans: 391
waiting for that pm
Killah Built
 Old 01-20-2012, 04:47 PM   #56
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I see the column of interest in your post. The gen2 cars dump excess fuel when the pump fails, and it just snowballs from that point.
For reference, your pump pressure should always remain > 1600 psi to avoid any issue with the ecu logic, and I see about 1/2 that pressure in your log (sometimes even less).
Thanks for donating and it looks as if you are on your way to getting plenty of help from the guys.
 Old 01-20-2012, 05:41 PM   #57
zedekias's Avatar
Posts: 197   (View Stats)
zedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond repute
Groaned at 5 Times in 2 Posts
Please excuse my noob question.
But is the low fuel pressure from the stage 1 map you're running? Or the SRI and TIH/TIP?
I thought that 9 times out of 10 you wouldn't run into low pressure problems with those mods?
zedekias is offline   Reply With Quote
 Old 01-20-2012, 05:56 PM   #58
I think it's just the combination of things overwhelms the fuel pump. Look at the dyno charts... I picked up a solid 10% increase in power and that is enough to put excessive demands on the fuel system. The logic in the gen2 ECU does not help either; it dumps excessive fuel when it detect knock or overboost and this exaggerates the issue.
Some of the posts lead you to believe that most people are ok and that running into low fuel pressure is the exception to the rule. I would challenge this and say that having the fueling issue is more the rule than the exception.
The veterans will probably have a better explanation.
2012 Black Mica MazdaSpeed3
Street creds:
 Old 01-20-2012, 06:02 PM   #59
So you don't see the code, you just see blonde, brunette, etc. I apologize to the others...I am a computer programmer by trade and it is 2nd nature for me to read data like that.
rfinkle2 and Smurfzilla like this.
Street creds:
 Old 01-20-2012, 06:06 PM   #60
WhoIsJeremy's Avatar
Posts: 2,196   (View Stats)
WhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the world
Hey dude. I live in white marsh and am pretty involved with the car scene in the area. Agile is great at some points but not in the other. They don't know much about the platform and they get you to spend way too much money. You'll walk in expecting to get A, but they tell you that you need x, y, and z before you can get to a. I didn't read all the post, but the money you give them really can be better spent.
Edit: just saw post where he said he's tuned hundreds of speeds. Not trying to be a dick, but I honestly feel like that number is maybeeeee ten or fifteen. There arent that many in the area and most of them are stock or on here. I've been to a couple of their open houses and have only seen two speeds total. If I was tuned by them, I'd be at their open houses.
Sent from my ADR6300 using Tapatalk
2007 MS3 GT -- > World's first flying Mazdaspeed3.
2006 MS6 GT -- > World's first n2o Mazdaspeed6.
1990 LS1 RX7-- > Probably broke somewhere
#DIX, for all the single ladies
WhoIsJeremy is offline   Reply With Quote
The Following User Says Thank You to WhoIsJeremy For This Useful Post:
 Old 01-20-2012, 06:55 PM   #61
Edit again: now that I had a nice poop that gave me time to read the whole thread. I've done plenty of fuel pump installs if you'd like me to do it or help you out with this. Not to be a dick, but please listen to what people on here have to say. It took me proving to @wdawson4 three times before he believed I knew what I was talking about jk
But seriously, hit me up if you need help dude. Me and Dawson are soon gonna be able to take the whole car apart and back together in an hour after working on these fucks this much.
 Old 01-20-2012, 07:12 PM   #62
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
LULZ
thanks for donating
hate to say we told you so, but we told you so.
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
 Old 01-20-2012, 07:13 PM   #63
I keep trying to pm you but it's saying you aren't found? Wtf? I just sent wdawson some messages with no issues. Hmmm. Can you pm me so I can just reply?
Street creds:
 Old 01-20-2012, 07:19 PM   #64
I'm a brownie cuz my VIP expired and I'm too broke at the moment to donate again. You can call or text me at 410-382-****.
I'll let you speak through will lol
My pms are full and I can't do anything unless I delete the thousand+ that I have. I'll be back up soon enough.
 Old 01-20-2012, 07:48 PM   #65
E.rod's Avatar
Posts: 5   (View Stats)
E.rod is an unknown quantity at this point
So, if I installed an SRI and TIP do I need to upgrade the FP. Sorry to hack into your post but I have no clue how to start my own thread. Lol I'm also new with this type of car and have no clue where to start with mods. Looks like a fuel pump should be the first one. Lol
Also what do I need to make 300whp? The guys at Cobb in Plano TX told menor would take a turbo upgrade. Let me know. Thanks!
E.rod is offline   Reply With Quote
 Old 01-20-2012, 07:51 PM   #66
You can get there with Sri, tip, turbo back exhaust, fuel pump upgrade, and accessport. An upgraded intercooler would help too. I'm not 100% sure the ots map will get you there, but it should? If not, you can get a custom tune and that will def get you there.
 Old 01-20-2012, 07:52 PM   #67
It's ok man, they'll kill you if you start your own thread anyway. It is hard to say if you will run into this issue without the more aggressive maps i.e. Cobb AccessPort. However, you will need to upgrade anyway if you want to make 300whp. I think with what I have plus a fuel pump, downpipe, and stage2 maps, it should make 300whp. Have fun learning with me :-)
Street creds:
The Following 2 Users Say Thank You to fortressofcomfort For This Useful Post:
Captain KR (01-20-2012), rfinkle2 (02-01-2012)
 Old 01-20-2012, 08:04 PM   #68
Groans: 263
an exhaust barely does anything, maybe a 5hp increase, if that. you would need a, SRI, TIP, Fuel pump, AP, tune and a test pipe or Downpipe. an upgraded intercooler would be good.
and going with e85 would get you there with less mods
2010 Black Mica
 Old 01-20-2012, 08:05 PM   #69
Not to be an ass, but I said turboback. Do you know what that means? Means downpipe, test pipe, and cat back. Let's read better next time.
 Old 01-20-2012, 08:14 PM   #70
Groans: 263
yeah, but not many noobs know what that means. just trying to break it down.
any person would just read "exhaust" and then go buy a UR exhaust expecting 30hp gain. just saying
2010 Black Mica
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 01-20-2012, 08:24 PM   #71
E.rod's Avatar
Cool, thanks for the info! I think I will do the FP first. E-85 is hard to come by in the middle of no where TX. But thanks for the heads up. Fort I'll keep checking on this thread so we will be learning together for sure. Ive been a licensed aircraft mechanic for the past 12 years so doing the work on my own shouldn't be a problem but I too have a family and work some long ass hours so I'll probably pay for some of it. Any tuners in here from the Dallas area willing o offer advise and support it will be greatly appreciated.
 Old 01-20-2012, 08:44 PM   #72
Groans: 263
get an etune here, very easy and great results
no need for anyone to be present
2010 Black Mica
 Old 01-20-2012, 08:54 PM   #73
bigriver's Avatar
Jet fuel FTW
Read the sticky in the General section on doing mods in the right progression.
 Old 01-20-2012, 09:11 PM   #74
Anyone on here should know what turbo back exhaust is. You misread or didn't know the difference, its okay.
 Old 01-20-2012, 09:17 PM   #75
E.rod's Avatar
Cool, how do you go about getting an etune? Bigriver, I'll check it out.
Thanks!
 Old 01-20-2012, 11:05 PM   #76
Thanks!
From one noob to another: search! Etune is basically an iterative process where you use something like an AccessPort. You start with a given map, could be stock, could be an off-the-shelf map from Cobb, etc. You drive your car around and log the engine data as yo go. You then send that log electronically to a tuner who makes adjustments to the map using computer software. The tuner then sends you back a new map electronically which you upload to your car's ECU.. Then you go drive and log again and the iterations continue until the car runs strong and all the logs look good.
Street creds:
Captain KR (01-20-2012), rfinkle2 (01-21-2012)
 Old 01-20-2012, 11:17 PM   #77
Groans: 263
^^ what he said, you tranfer this data via email and he tunes your car according to the data or logs you send him
2010 Black Mica
 Old 01-20-2012, 11:28 PM   #78
Just ordered the Autotech upgraded internals for the CDFP from EdgeAutoSport woohoo! And I've got a couple people, to remain nameless for now, who are willing to help me through the process.
It's like as soon as I donated everyone stopped being a dick to me :-P
Street creds:
 Old 01-20-2012, 11:46 PM   #79
makjur's Avatar
Posts: 1,313   (View Stats)
At least nothing has broken completely, right?
Even before you tested this hearsay about HPFP's, i realized from reading around that i shouldnt do anything until i can get a one along with SRI and AP (1,500$ investment)
(and until warranty expires)
thanks for making it even more obvious for me
and grats on the donate love
°(ಠೆಒಠಿ)°
 Old 01-20-2012, 11:49 PM   #80
Elusivellama's Avatar
Posts: 351   (View Stats)
Elusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the world
Autotechs are what I'm going after, in about a month's time or so. Seem like a very good choice.
Elusivellama is offline   Reply With Quote
GenPu Big Turbo Videos (Flybys, Dyno Runs, Exhaust Sound, 1/4 Miles, etc..) falconexe 2010 MS3 - Big Turbo Builds 180 03-22-2012 12:30 AM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Custom AP tune Dyno runs Snyeed MazdaSpeed 3/6 - Dyno Sheets/Discussions 13 07-28-2010 04:48 PM
Cheap Dyno Time!!!! $60=6 runs HighSun_Murder MazdaSpeed 3/6 - ECU Computer Tuning 12 09-27-2009 01:49 PM
Hello, our name is Modern Automotive Performance. We're new here ;) maperformance Modern Automotive Performance 20 12-22-2008 11:26 AM
Page generated in 0.62965 seconds with 33 queries
