Like Tree3Likes
  • 2 Post By Snowflake801
  • 1 Post By The Nut
 Old 07-23-2013, 02:09 AM   #1
CornBread's Avatar
Posts: 170   (View Stats)
CornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond repute
Groaned at 24 Times in 11 Posts
Default Stage 2 ots cobb maps
I was looking at the stage 2 stock map. I have some confusion as to what is different than stage 1 stock map.
I do have autotech internals so should I be running the stage 2 stock instead of stage 1 stock?
any help to clear this up for would be great. called cobb and they just said "try it and see what it does"
I would like to know instead of just try. so thanks again guys
car only has the fuel pump upgrade nothing else. just plain ol stock everything else
Stage2 Maps
Map Name Fuel Intake TIH IC CDFP Rev. Map
Stage2 93 93 Stock Stock Stock Upgrade 2.31 [map]
Stage2 91 91 Stock Stock Stock Upgrade 2.31 [map]
CornBread is offline   Reply With Quote
 Old 07-23-2013, 03:30 AM   #2
Snowflake801's Avatar
Posts: 59   (View Stats)
Snowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud ofSnowflake801 has much to be proud of
read the requirements of the tune.... it says it right on the tune you try to select... im a browneye too and even i know that
tbcota25 and DoMiNic like this.
Snowflake801 is offline   Reply With Quote
The Following 3 Users Say Thank You to Snowflake801 For This Useful Post:
DoMiNic (07-23-2013), El_Diablo (07-24-2013), gigliotti175 (07-23-2013)
 Old 07-23-2013, 04:04 AM   #3
Benis's Avatar
Posts: 413   (View Stats)
Benis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the world
They said just try it and see what it does? Seems like a strange answer. Did you go on their site? It says for each different map what mods you should have (intake, TIH, etc). I believe it says stage 2 maps suggest an upgraded downpipe or test pipe. With the internals obviously
Just run the lower map until you get more mods. Then go get a custom tune
Benis is offline   Reply With Quote
 Old 07-23-2013, 09:32 AM   #4
JDM83's Avatar
Posts: 39   (View Stats)
JDM83 will become famous soon enoughJDM83 will become famous soon enough
Groaned at 25 Times in 14 Posts
I am pretty sure stage 2 requires a down pipe and internals.
What downpipes are people running? I saw one for $550+ which is expensive. I am pretty sure I can have one made from a friend for cheaper but he is 900 miles away lol
JDM83 is offline   Reply With Quote
The Following User Says NO Thank You to JDM83 For This Un-useful Post:
 Old 07-23-2013, 09:51 AM   #5
gigliotti175's Avatar
Posts: 750   (View Stats)
gigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the world
Groans: 24
Groaned at 25 Times in 15 Posts
I thought there were OTS maps for just DP, internals, and TMIC/FMIC separately. I will have to look at my AP.
As for the DP. They can be expensive, few people have good luck with eBay DP's though.
gigliotti175 is offline   Reply With Quote
 Old 07-23-2013, 01:54 PM   #6
hamfisted's Avatar
Posts: 92   (View Stats)
hamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant future
If you look at what you posted, you'll see "stock" is referring to the intake/TIH/IC. The tuning notes specify upgraded exhaust & CDFP for stage2.
hamfisted is offline   Reply With Quote
 Old 07-23-2013, 01:55 PM   #7
CornBread's Avatar
it says they suggest not required that is why I called dumb ass cant get any more searching than calling the people who made it. and I am far from a noob or brownie. I asked here due to the wealth of knowledge and possibly someone trying it and being able to say what experience they had.
thanks to the others with real information and to you snowflake, time to go jump off a bridge
 Old 07-23-2013, 02:31 PM   #8
veezyweezy's Avatar
Posts: 902   (View Stats)
veezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the worldveezyweezy is the leader of the world
nb4 anal rape
veezyweezy is offline   Reply With Quote
 Old 07-23-2013, 02:38 PM   #9
The Nut's Avatar
Posts: 1,571   (View Stats)
The Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the world
Groaned at 38 Times in 20 Posts
I'll lay this out for you only because you've been getting crossed info, but you'll get a lot more positive responses once you've donated.
Stage requirements:
1. Donate
2. Stage 1 - Internals (at least) (yes I know it says their stage 1 maps are meant to run within the parameters of the stock HPFP, that doesn't make it a good idea)
- other selectable maps for stage 1 as you'll see on Cobb's d.l. page are for varying mods of intake, TIP, & I.C.
3. Stage 2: this becomes posible when you at least get a TP exhaust mod, other exhaust mods aren't required, but will open you up for greater power gains when e-tuning
4. E-Tune to make the most of you mods
Good Luck, now donate
DoMiNic likes this.
2012 BLACK MICA w/TECH
Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches
Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18
Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob
Stereo: Full Custom Mobile Audio/Video Entertainment System
91 & Corn diagnostics by:
The Nut is offline   Reply With Quote
The Following 2 Users Say Thank You to The Nut For This Useful Post:
El_Diablo (07-24-2013), ms3rick (07-23-2013)
 Old 07-23-2013, 02:56 PM   #10
CornBread's Avatar
I was a vip member and have chose not to go vip again due to the few people who say donate or search in every damn post. I did search and all I found was to donate or search. little help there so I asked. and yes when the manufacture says to try it it leads to confusion
anal rape don't think so. that would mean everyone who anal rapes is a fag.... so are you saying your a fag... if so cool by me I know where you stand.. on your knees
lmao you guys kill me.
it is a pitty that a few people can ruin this board for a lot of people. it is hard to search because every person thinks the answer to a question is donate or search, well news flash the search only reveals posts that say to search or donate. no answers. why spend 8 hours reading post that say the same thing. easier just to ask.
want to stop all the same post, actually answer one so it can be searched
The Following 2 Users Say Thank You to CornBread For This Useful Post:
Herb (11-07-2013), TaagMan (07-23-2013)
 Old 07-23-2013, 03:03 PM   #11
CornBread's Avatar
e-tune it is a road I might try due to cost but I feel this was a good question to ask since I could not find a answer when searching
 Old 07-23-2013, 03:06 PM   #12
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
i have 07 ms3 and was running stage 2 ots for cai/tip dp and upgraded fuel pump... stage 2 demands more fuel pressure than the stock relief valve can handle. first time wot with my stage 2 map my relief valve failed. could have been shit luck but youre probably better off just running the stage 1 either way.
brandonnicholson is offline   Reply With Quote
 Old 07-23-2013, 03:13 PM   #13
CornBread's Avatar
awesome. what I was looking for. I will stay stage 1 then. I will get a tune when I get more mods. new baby has put a end to buying so I wanted more for less. I have done the fuel pump so I just need to hold off till I get a sri and tip for a e-tune
 Old 07-23-2013, 03:16 PM   #14
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
Why do you want to run st stage 2 maps? Do you think you should because you have internals? Do you want more power? I would run the stage one 91oct map to get a little power... If you want to run the ots stage 2 map without supporting mods, then don't. What is the point of this?
related topics....
Stage 2 AP Map without DP?
Stage 2 tune without dp
btw: If you are old enough for kids you are old enough to use caps.
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
The Following 2 Users Say Thank You to DoMiNic For This Useful Post:
El_Diablo (07-24-2013), Flipboi89 (07-23-2013)
 Old 07-23-2013, 04:11 PM   #15
CornBread's Avatar
well it is from my phone so caps can be too much when you have a 8 year old helping lol.
I was just wondering if I left anything else on the table. it is the curious side of me wanting to know
thanks for the links I will be reading tonight
 Old 07-23-2013, 09:23 PM   #16
Stingray69's Avatar
Posts: 1,197   (View Stats)
Groans: 48
Can I get the last 5 minutes of my life back?
Stingray69 is offline   Reply With Quote
The Following 3 Users Say Thank You to Stingray69 For This Useful Post:
El_Diablo (07-24-2013), GAspeed3 (07-24-2013), ms3rick (07-23-2013)
 Old 07-24-2013, 12:02 AM   #17
CornBread's Avatar
you sure can, donate again and search for it. I bet your 5 mins is here somewhere .
GTISPEED3 (07-24-2013), Playaj (07-24-2013)
 Old 07-24-2013, 08:26 AM   #18
GTISPEED3's Avatar
Posts: 775   (View Stats)
GTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the world
Groaned at 8 Times in 5 Posts
^Bazinga lol
GTISPEED3 is offline   Reply With Quote
 Old 07-24-2013, 09:01 AM   #19
JgamB's Avatar
Posts: 2,566   (View Stats)
You want cheap stage 2 power?
1. donate. yep, that word again - but not just so your name turns green - it's so you can see the for sale section. Buy someone's intake. You don't need a TIH/TIP, just an intake. Probably ~$100.
2. Test pipe. You don't need a $550 DP, the OBX (ebay) test pipe is $90 to your door. If you really want to go ghetto, drop the midpipe and smash the catalyst out of it with a piece of rebar and a sledge. Voila, less back pressure.
Poof, you're "stage 2" ready. Get an e-tune for $200. You'll pick up ~30HP over OTS stg2 maps, closer to 60HP if you run 25% corn.
The Following 2 Users Say Thank You to JgamB For This Useful Post:
DoMiNic (07-24-2013), El_Diablo (07-24-2013)
First dyno pulls on Stage 1 and Stage 2 Cobb Maps PSmurf78 2010 MS3 - ECU Computer Tuning 11 05-14-2013 05:44 PM
can BNR stage 1 use cobb OTS maps? numbnuts22715 MazdaSpeed 3/6 - ECU Computer Tuning 7 01-02-2012 01:17 PM
bnr stage 2 maps bynumsboosted
Cobb ATR Support
0 07-23-2011 11:15 PM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.38838 seconds with 32 queries
