Like Tree2Likes
 Old 12-26-2011, 07:07 PM   #41
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
Originally Posted by gitarpik View Post
Thanks man
So what is that knocking that happens when I go heavy throttle and boost?
I can feel it more then I can hear it, it makes me get off the throttle
And does it really matter what RMM I get, or should I go with the JBR 88 I linked?
Could be what ckmazdaspeed was saying. I would suggest replacing it and see if that fixes the problem. JBR makes great mounts as well as all the other stuff I mentioned. Street Unit does too. I have the Street Unit stuff and I love it. You'll notice increased vibrations but once the bushing breaks in, it'll be fine. Honestly, I didn't notice crazy vibrations. There were some, mostly with AC on, but nothing annoying. Totally worth it. Cheap and easy to install. And you could easily stock it out if you brought it into Mazda for service and were worried.
Personally, I never had any issues like that, but I knew i wanted to replace it either way.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline   Reply With Quote
 Old 12-26-2011, 08:08 PM   #42
makjur's Avatar
Posts: 1,313   (View Stats)
So it should be RMM #1 then, fuck the stock one... I hope thers a recall on it before I get around to replacing it, design flaw if you ask me
Is there anything else that should get done while doing the RMM?
Shit that would be easy to access while doing the job I mean.
For other mods, from reading around, looks like fuel pump is #2, intake #3, and then access port tuning kajigger #4.
Eventually downpipe and intercooler upgrade, but I'm a while away from those 2 myself.
Actually, my #1 will be a radar detector, its probably something I should already have gotten years ago.
°(ಠೆಒಠಿ)°
 Old 12-26-2011, 08:47 PM   #43
Postulio4joo's Avatar
Posts: 284   (View Stats)
Postulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the world
Groaned at 14 Times in 6 Posts
1. Intake ( Best bang for buck and a audio orgasm.
2. RMM ( World of difference and cheap)
2. Fuel pump ( so your shit doesn't blow)
3. Removing Cats ( because fuck the enviroment and more power less money)
4. Upgraded IC ( Fuck yeah!!)
5. AP ( OTS maps don't really get you gains till the end. Bucker tunes for cheap ass rates )
Postulio4joo is offline   Reply With Quote
 Old 12-26-2011, 09:13 PM   #44
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I read about the firewall knock and figured thats it and stopped worrying.
car only has 6000 miles right now.
How can I be sure that this is all it is?
I get it to happen when I'm 3rd/4th gear and start heavy acceleration (above 3k rpm)
I'll have to open windows and turn radio down and give it a good listen, but its been fukn cold lately...
If it is the RMM, why is this being ignored by mazda, and people solve the problem by getting 3rd party parts.
that's not the turbo in the firewall issue. I only hit my turbo once (I had a new rmm installed within a week of getting the car), but it was a very loud, single thud after a very hard 1-2 shift. accelerating while in gear and at higher rpm isn't the firewall hitting.
Blue Pu.
Ckmazdaspeed3 (12-27-2011)
 Old 12-26-2011, 09:43 PM   #45
makjur's Avatar
...accelerating while in gear and at higher rpm isn't the firewall hitting.
Now I'm scared.. going to try to recreate it and give a more accurate description, and possibly take video, will post in a separate thread, fckn shitty
thanks for the info so far guys
°(ಠೆಒಠಿ)°
 Old 12-27-2011, 02:47 AM   #46
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Whether its a design flaw or not, its just better to spend the $90 and get the JBR dogbone, the stock shit is meant to make the car livible for grand mom to ride in with out her dentures falling out. Every car has a design flaw according to the driver, we all look at different things we like and dislike.
Scoobs likes this.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is offline   Reply With Quote
 Old 12-27-2011, 06:44 AM   #47
Groans: 116
Yeah it isn't a design flaw. They chose not to do a stiffer one to cut back on vibrations into the cabin. There is a thread on the RMM and how it works. There is also a few threads on order of mods.
I'd start with RMM, counterweight, short shift plate and shifter bushings. All cheap and will make the car feel stronger. Then you can do the intake, turbo inlet hose (pipe) and recirculating tube. Then, if you haven't already, get the Cobb AccessPORT. That way you can data log so you know exactly how your car is running. That way you won't blow up your shit by accident. Again though, do some searching as there are a ton of threads on the safest ways to mod.
 Old 01-02-2012, 07:11 PM   #48
makjur's Avatar
Tnx for motormount info, now another ?
TIP = necessary?
Eventually going toget SRI, HPFP, AP, BPV (in no specific order, after i do the mounts and shifter stuff)
Not planning on doing much past that
°(ಠೆಒಠಿ)°
 Old 01-02-2012, 07:17 PM   #49
anavrinIV's Avatar
Groans: 63
TIP isn't necessary. I have one because the corksport setup was the best bang for the buck I could find, and I just decided to do it while I was tearing into things anyway. If you only plan on doing an intake and tune then don't worry about the tip. If you're planning on going further than that (dp, upgraded ic, what have you) then go ahead and do a TIP.
Blue Pu.
 Old 01-03-2012, 08:32 AM   #50
Groans: 116
TIP = necessary?
not necessary but i would do it. after seeing the OEM piece, you can see why people like to replace it! i'd recommend just getting a SRI and TIP at the same time and installing them together.
 Old 01-03-2012, 07:02 PM   #51
Oscar's Avatar
Posts: 2   (View Stats)
Oscar can only hope to improve
Groaned at 3 Times in 1 Post
Originally Posted by Oscar View Post
Wat does "ap" mean
thanks!!!
Oscar is offline   Reply With Quote
 Old 01-03-2012, 07:36 PM   #52
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
1.blue 2 shims
2.more freon for intercooler
 Old 01-12-2012, 06:08 PM   #53
makjur's Avatar
Posting here again because I dont want to start a new thread and its still kinda related...
JBR vs. Sure ?
Same stuff from both places:
- shift plate
- shift counterwight
- shift bushings
- billet style RMM
JBR price = $215
Sure price = $268
Is this a case of preference, or get what you pay for?
The only thing I can see sure has going for it is prettier looking parts, that I wont get to actually look at after they are in place.
I would personally prefer to support Jamie since he "seems more real", just wanted to see if anyone has feedback on either product
°(ಠೆಒಠಿ)°
 Old 01-12-2012, 06:13 PM   #54
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
No jbr provides more then what you pay for plus hes a answome guy
Sent from my SGH-T959V using Tapatalk
2012 CWP Mazdaspeed3 Current Mods: Cobb Turbo Back|Cobb Sri/Tip|Cobb XLE|Cobb Ap|Jbr Heavy Shit Knob|AutoTech Internals|JBR Short Shifter Plate/Brushings|Corksport Tmic|
Noodlesincup is offline   Reply With Quote
 Old 01-12-2012, 06:35 PM   #55
uncorked11's Avatar
Groans: 165
Def.
New....Camaro SS/RS
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 01-12-2012, 06:35 PM   #56
mswierse's Avatar
Posts: 313   (View Stats)
mswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the world
If you want to check my car out some time, let me know... I have JBR 80 Duro RMM, MD OCC, and Cobb SF Intake. I like all the mods so far... want to get a tip, then AP and fuel internals in the spring.
2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed, Ksport Coilovers, SPC camber arms...
13.5@106
mswierse is offline   Reply With Quote
 Old 01-12-2012, 08:16 PM   #57
makjur's Avatar
JBR seems like win then...
Like I said, sure shit only looks nicer, but as long as it works I'll be happy
wont be looking at the shit after all
°(ಠೆಒಠಿ)°
 Old 01-12-2012, 08:18 PM   #58
Groans: 116
You'll be fine either way. I have SURE and love it. But JBR is very nice too. Go with JBR and save some $$$.
 Old 01-12-2012, 08:41 PM   #59
anavrinIV's Avatar
Groans: 63
I'll vouch for jbr stuff again and again. I have all of his parts in my sig. Will be adding the egr block off very soon. He ships fast, his parts are quality, and he supports this forum and makes parts that people need. And he does it cheaper than anyone else around. Support jbr.
Blue Pu.
 Old 01-12-2012, 08:45 PM   #60
uncorked11's Avatar
Groans: 165
If your referring to "pretty" its not much going to matter the rmm will not be seen. It is a solid addition to the car and I will be completing the mounts trifecta asap.
New....Camaro SS/RS
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 01-14-2012, 02:38 PM   #61
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
Jbr hands down and nothing else. You have yo support a guy like that who pores his time into help the Mazda community. Not to mention the quality is second to none.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
The Following User Says Thank You to vrspeed10 For This Useful Post:
anavrinIV (01-14-2012)
BMW in early stages of public-relations pitch Haltech Automotive News 0 11-15-2011 01:20 PM
Spy Shots: Roding Roadster stages massive improvement Haltech Automotive News 0 10-18-2011 12:50 PM
Mexico stages comeback as hub for light vehicle output Haltech Automotive News 0 08-12-2011 10:40 PM
Stages of modification thedude MazdaSpeed 6 - Engine, Transmission & Driveline 5 10-30-2009 10:03 PM
Page generated in 0.40724 seconds with 29 queries
