  • 1 Post By Teethkikr
 Old 03-02-2012, 02:12 PM   #1
Shwine617's Avatar
Posts: 5   (View Stats)
Shwine617 is on a distinguished road
Groaned at 6 Times in 2 Posts
Default Stock just doesn't cut it for me! need some ideas...
Hello Everyone, My name is Cory and I have a 2010 MS3. I am new to the site, but I'm not some newb when it comes to performance as I have an MX6 race car.
I have searched through the stickies and found some great info. Most of them just list the different brand/parts and not specifically which ones work best or together.
I drive the car every day, so I'm not trying to go too crazy, but I can feel the poor car is under a lot of restriction.
Basically I don't want to buy a specific brand part and replace it soon after because it wasn't the best choice.
I am a certified mechanic, so doing the work is not a problem, I just want to get the right stuff the first time.
I was looking into a BPV, intake, and exhaust. Feel free to comment or share suggestions.
I know there has probably been similar threads, so I really appreciate your time and input. Hopefully I don't get thrashed too bad.. lol
2010 MS3 - Stock for now
1990 Mazda MX-6 - FE-DOHC swap 470 WHP @ 35psi
Shwine617 is offline
The Following 4 Users Say NO Thank You to Shwine617 For This Un-useful Post:
Chimmike (03-05-2012), Macncheese (03-03-2012), Mazda Lover (03-04-2012), rghispanic88 (03-04-2012)
 Old 03-02-2012, 02:16 PM   #2
MS_Driver's Avatar
Posts: 142   (View Stats)
MS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond reputeMS_Driver has a reputation beyond repute
Groaned at 26 Times in 5 Posts
Read this:
Intro to your mazdaspeed
You'll get a lot of input on what brands work best together..
I personally like the Corksport SRI/TIP combo - well priced too. You can hold off on the bpv as it doesn't do much unless you're pushing more boost.
FP internals and AP are good to get early on.
2010 Black Mazdaspeed3 | DDM 6K HID lows and 3K fogs | 15% Tint | CP-E Tow plate | Corksport SRI + TIP | Corksport race pipe | Corksport RMM inserts | JBR SSP | JBR shift knob | Progress RSB | H&R springs | Enkei MM2 18x7.5 +38 | Katzkins full leather interior (done by me)
MS_Driver is offline
The Following 2 Users Say Thank You to MS_Driver For This Useful Post:
SofaKingAwesome (03-02-2012), WAHBAM (03-02-2012)
 Old 03-02-2012, 02:18 PM   #3
IHIERBal's Avatar
Posts: 144   (View Stats)
IHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond repute
I'm a newb on these forums myself, but you're probably gonna want to start with the intake and possibly turbo inlet pipe (corksport sells a kit) as far as restrictions go. Changing the exhaust doesn't do much on these cars, and our stock BPV is good till about 19 psi IIRC. After you replace turbo inlet/intake you will hear the BPV enough if that's what you're looking for. Also, a RMM is a must on these cars, even if it's just an insert.
2010 MS3 purchased 02/11/12 (11,9xx miles) II Headlight Armor yellow fogs II CS RMM insert II CS SRI/TIP II DDM HID Kit low beams 4300k II Plasti-dipped rear valence II Eibach prokit II OEM Rear bumper guard II OEM roof rack II Thule 44" fairing II Privat Akzent 18x8.5+40 II 235/40 Falken Ziex II UltraGauge II Cobb AccessPort II OBX test pipe II AT Fuel Pump Internals II HKS bov VTA II CP-E TMIC II ATP Long Downpipe II CS Shift Plate II Koni Yellows II
Re-tune in progress!
Engine oil : Rotella T6
Oil filter : Motorcraft
IHIERBal is offline
The Following User Says NO Thank You to IHIERBal For This Un-useful Post:
emag remrofni (03-04-2012)
 Old 03-02-2012, 02:27 PM   #4
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
You don't need a BPV until you start getting up there in HP. The stocker holds pretty well, so unless you're looking for that ricer-ass PSSHH sound, you can spend your money elsewhere. And TIPs don't really do too much for this platform. I'd go SRI, RMM, and Short Shifter. Personally, I'd recommend the SURE versions of all those. They have a No CEL guarantee on their SRIs, and their shifter plate is easier to install than the competition, IMHO. Plus, if you order it all from them, it'll all arrive together and you can have a nice install day.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline
 Old 03-02-2012, 02:31 PM   #5
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
@eric@edgeautosport
Edgeautosports is running an intake/tip & RMM package.
I suggest that to start with for sure. Hold off on the BPV and exhaust work.
Thereafter, an AP for sure.
helmetface is offline
The Following 2 Users Say Thank You to helmetface For This Useful Post:
EdgeAutosport.com (03-02-2012), WAHBAM (03-02-2012)
 Old 03-02-2012, 03:07 PM   #6
outshined's Avatar
Posts: 423   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
What's your budget?
For ~$1200 you can do a CorkSport SRI/TIP, race pipe, HPFP internals, and AP.
That will yield nice gains, good drivability, and a solid foundation for future mods.
There's a plethora of non-power mods that can improve the DD experience but based on your post those don't appear to be your top priority.
outshined is offline
The Following User Says Thank You to outshined For This Useful Post:
Teethkikr (03-02-2012)
 Old 03-02-2012, 03:22 PM   #7
Teethkikr's Avatar
Posts: 677   (View Stats)
Teethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the world
Groans: 50
I think guys need to start being told that the CDFP should be FIRST.. It tends to slip down the list and forgotten.. Once they forget, they come here asking for advice on the next cool exhaust system and valve stem led's...
shanman1886 likes this.
2012 CWP Tech Package:
Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems//
Teethkikr is offline
 Old 03-02-2012, 03:27 PM   #8
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
FP internal should be your first mod.
dhsieh911018 is offline
 Old 03-02-2012, 03:40 PM   #9
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
@helmetfail Thanks for the mention.
OP we over here at Edge will get you hooked up.
EdgeAutosport.com is offline
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
helmetface (03-02-2012)
 Old 03-02-2012, 03:40 PM   #10
evilgrin's Avatar
Posts: 77   (View Stats)
evilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant future
This has been discussed at least a thousand times. Seems like the logical order is as follows:
Very first: prolific use of the search engine, then:
1) AP
2) fuel pump
3) SRI or CAI
(RMM in here at some point)
4) downpipe or test pipe
5) quality tuning
6) and on and on..........
evilgrin is offline
 Old 03-02-2012, 03:43 PM   #11
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
first couple posts are pure win, brownies helping brownies.
SofaKingAwesome is offline
The Following User Says Thank You to SofaKingAwesome For This Useful Post:
Teethkikr (03-03-2012)
 Old 03-03-2012, 02:07 PM   #12
Shwine617's Avatar
Wow, hats off to this forum!..
I didn't expect a huge positive response so fast, so thanks to all.
Ok, I can figure most of this out but some of the abbreviations are throwing me off.
I am not trying to make a drag car out of this or anything, just want to free up some of that hidden power that I feel is being restricted.
I don't plan on upping the boost just yet, so I think I can wait for the BPV.
Here's a small list I'll put together of the info everyone shared:
Short Ram Intake/ Turbo Inlet Pipe - I was looking into these, but there are many different companies and styles.
FP internals - I see this is an internal fuel pump upgrade. same as CDFP I assume?
AP - Cobb Access Port ? Seems like a good tuner.
Downpipe/test pipe - any brand in particular?
I'm not trying to spend a million dollars, but I don't mind spending the money where I need to. I do have some corksport parts on my mx-6 and they always seem to have quality products.
Someone I know is selling a CP-E Stage 1 60a rear mount and Forge V1 BPV for $125. thoughts?
Thanks again guys!
The Following 2 Users Say NO Thank You to Shwine617 For This Un-useful Post:
Macncheese (03-03-2012), rghispanic88 (03-04-2012)
 Old 03-04-2012, 08:21 AM   #13
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
Groaned at 4 Times in 2 Posts
Thanks again guys!
Ok so your going down the right path....
Short Ram Intake/ Turbo Inlet Pipe -all companies are good but it seems most use Corksport, then Cobb, then Cp-e, then Sure then everything else.
FP Internals...yes your assumption is correct.
AP = Cobb Access Port: Very good and vital. There is much to read at Cobb's site regarding this tuning device but you can also learn a lot from Abilor's guide here (it's a sticky), look for it.
Downpipe/test pipe - You don't necessarily need both at the outset....test pipe is more than adequate to get some noticable gains...BUT should basically only be done after everything else above, as far as brands see SRI-TIP manufacturers again.
You should have the RMM (Rear Motor Mount) as a higher priority than the exhaust changes. It's cheap, stops engine movement and enhances traction for all the power you are hoping to add!!! Brands - James Barone, Cp-e, Sure...
Ok enough basics .....you're going to have to put in some hours searching......and reading!!
Have fun and welcome!!!
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline
 Old 03-04-2012, 05:23 PM   #14
blue 2011's Avatar
Posts: 17   (View Stats)
blue 2011 will become famous soon enough
Went to the edgeautosport site but could not find the sri tip rmm package i was looking for the price
blue 2011 is offline
 Old 03-04-2012, 09:48 PM   #15
Acedelgado's Avatar
Posts: 39   (View Stats)
Acedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud of
Check Edge's forum in the sponsors section, there's a thread about it in there.
2012 LSM Non-tech
Kensun 6000k HID / SURE 70a RMM \Cobb AP/ Autotech Internals\ Corksport SRI + TIP/ Synchronic BOV
Interior:
AppRadio 2 + ARLiberator + ScanTool Bluetooth OBDII Reader + Torque Pro = Win.
Acedelgado is offline
 Old 03-04-2012, 10:03 PM   #16
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
InB4 TROLL
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline
 Old 03-04-2012, 10:06 PM   #17
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
Your first mod should be (and I kid you not), donate the this forum so that you can gain access to the VIP section with its wealth of knowledge, the For Sale section, and various other odds and ends.
So...here's what I would suggest for your daily driver-MS3:
1. Donate
2. AccessPort
3. Autotech HPFP internals (yes, CDFP)
4. SRI (Short Ram Intake) - brand doesn't really matter as long as there's a MAF straightener and you calibrate your tune accordingly.
5. Downpipe - Again, it doesn't matter too much which brand you go with. There are a number of people on here with good gains on cheap M2 Ebay downpipes.
With those mods and a decent tune, you'll feel some VERY noticeable gains performance- and fuel economy-wise (if you can stay out of boost hehe).
Vansquish is offline
 Old 03-04-2012, 10:07 PM   #18
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
You can have a lot of fun with an intake and AP. Throw on a RMM and romp on it. FP internals won't be a necessity until you start opening up the exhaust stream but it wouldn't be a bad idea to invest in them to be safe.
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
Originally Posted by Monotonous ONE View Post
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline
 Old 03-05-2012, 08:27 AM   #19
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
All I read was "I read the stickies and they didn't tell me what I wanted, which is someone to hold my hand and tell me which part to buy"
Fucking decide for yourself. Another useless fucking repetitive thread from a genpoo.
07 MS3
The original Genpoo Hater
Chimmike is offline
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Bucker (03-05-2012), Paul (03-05-2012), Royer366 (02-05-2014)
Stock just doesn't cut it for me! need some ideas... Shwine617 Mazdaspeed3/6 General Discussion 0 03-02-2012 01:57 PM
Need Some Ideas..... Novej MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-21-2011 10:55 AM
color ideas for stock ms6 rims Reaperms6 Appearance - BLACK 10 05-09-2010 06:12 PM
Need some ideas 7mileshome MazdaSpeed 3/6 - Big Turbo Builds 80 04-19-2010 04:46 PM
Page generated in 0.43358 seconds with 37 queries
