 Old 09-09-2012, 01:35 PM   #41
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Originally Posted by dbrier View Post
How do you guys think sunroofs are installed? They add new braces for the sunroof that connect the side rails. It isn't just hanging on the sheet metal roof.
If I cut out one small cross brace and add a a box frame (2 cross braces) did you really weaken the car?
The only real issue is weight.
I doubt that there is much structural engineering analysis put into most aftermarket sunroof/moonroof kits to confirm that they are at least retaining the OEM rigidity values with their (likely bolted-in) bracing, but I am pretty sure the Mazdaspeed engineers used actual data to determine that the car would benefit from additional roof bracing over the regular 3. Yes, it's merely conjecture and I don't have any hard evidence to back it up, but I think it's pretty solidly grounded conjecture at that.
Regardless, if you're adding weight to the roof, you're detrimentally affecting the car's chassis dynamics.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
Chimmike (09-19-2012), Dash08 (09-09-2012), mswierse (09-15-2012), woodfloor (09-09-2012)
 Old 09-09-2012, 02:44 PM   #42
woodfloor's Avatar
Posts: 199   (View Stats)
woodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the worldwoodfloor is the leader of the world
Groans: 34
Check out page 12/13 of this PDF.
http://www.mazdausa.com/MusaWeb/down...3_brochure.pdf
The Mazda engineers just add shit to say they added it right?? Right?!
2012 CWP MS3
Corksport Stage II SRI + TIP / JBR 80a RMM / JBR SSP + Bushings / Corksport OCC / Forge BPV / Cobb AP v3 / Autotech HPFP Internals / Stoptech Slotted Rotors / Stoptech Street Pads / Stoptech SS Brake Lines
woodfloor is offline   Reply With Quote
The Following User Says Thank You to woodfloor For This Useful Post:
jack_hammer (09-10-2012)
 Old 09-10-2012, 09:14 AM   #43
killer-ms3's Avatar
Posts: 1,187   (View Stats)
killer-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the world
Groans: 32
Id install one and put a roof scoop to cool off my scalp, but that's just me
killer-ms3 is offline   Reply With Quote
The Following 2 Users Say Thank You to killer-ms3 For This Useful Post:
jack_hammer (09-10-2012), mazdaspeeding (09-19-2012)
 Old 09-13-2012, 06:31 AM   #44
JT.Tuckerman's Avatar
Posts: 108   (View Stats)
JT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to beholdJT.Tuckerman is a splendid one to behold
I have one, it was installed as soon as I got the car. Had no choice, at the time it was between a used BMW 1 series with a factory sunroof and a brand new MS3. I wanted the MS3, my other half wanted the BMW with a sunroof. We compromised, I got the MS3, and a sunroof went in. It's a Webasto power moon roof and works well. Webasto makes some of the best after market power moon roofs. It works well, does not leak, etc. Although with all of that said, I DON'T recommend one. It does creak and groan a little when I go slowly over irregular surfaces at an angle- rain drainage easements, angled driveways, etc. And with the sunroof being just overhead, the sound is right near my ear and it's annoying. So my advice is to not get one on this car.
JT.Tuckerman is offline   Reply With Quote
The Following 5 Users Say Thank You to JT.Tuckerman For This Useful Post:
Dash08 (09-18-2012), Easter Bunny (09-19-2012), mazdaspeeding (09-19-2012), Nliiitend1 (09-13-2012), woodfloor (09-14-2012)
 Old 09-15-2012, 08:57 AM   #45
PL ENDO's Avatar
Posts: 883   (View Stats)
PL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the world
Groaned at 31 Times in 12 Posts
well i didnt think that me posting this thread will start a argument. i honestly dont give a F*** about the added weight, taking my speed to the track or anything else someone will say about it. i enjoy having a sun roof and i use mine all the time. this one i got has a lifetime warranty for parts and leaks so let it leak. it opens and closes at a touch of a button, when i turn the car off it will close by its self. if in the end it destroys my roof then its on me and im going to have to deal with that when and if it comes. total cost for install and warranty was 999 out the door. made my wife happy and like the speed more then a sti so another win.
PL ENDO is offline   Reply With Quote
The Following 5 Users Say Thank You to PL ENDO For This Useful Post:
dbrier (09-17-2012), dMuze (09-19-2012), mazdaspeeding (09-19-2012), ruthless013 (09-17-2012), SLOWHATCH (09-15-2012)
 Old 09-15-2012, 09:11 AM   #46
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Added weight, reduced headroom, even hotter in the summer with our shitty a/c, flat so it ruins the lines of my roof, ruined infrastructure compromising both the integrity and spirit within the car (while likely making you less likely to survive a roll-over, let alone how it will react in a collision now) ...
Sign me up.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Chimmike (09-19-2012), StayBroke (09-20-2012)
 Old 09-15-2012, 09:23 AM   #47
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Sign me up.
my a/c is a beast.
Blue Pu.
Dash08 (09-18-2012)
 Old 09-15-2012, 09:29 AM   #48
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
get some pics from inside tooo
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 09-15-2012, 09:46 AM   #49
anavrinIV's Avatar
Groans: 63
does it have a cover? if it's just open glass then it's pure fail in my book
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
Easter Bunny (09-19-2012), SLOWHATCH (09-15-2012)
 Old 09-15-2012, 11:57 AM   #50
ThizSpeed3's Avatar
Posts: 253   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
Groaned at 13 Times in 3 Posts
i really wonder what the metal looks like under the rubber gaskets, did they treat the metal? since if it starts to leak out of warranty wouldn't it rust?
^does it matter its not visible.
anyway is this how they did yours?
"How To" Sunroof Install - Scionlife.com
ThizSpeed3 is offline   Reply With Quote
 Old 09-15-2012, 12:29 PM   #51
Mizzle's Avatar
Groans: 324
LOL are you fucking retarded?
It definitely matters if they didn't treat the metal beneath.
 Old 09-15-2012, 02:50 PM   #52
PL ENDO's Avatar
i do not know how they did it, i dropped it off and two days later it was done.
 Old 09-15-2012, 03:15 PM   #53
PL ENDO's Avatar
that is the link to a video i made of the sunroof.
The Following 2 Users Say Thank You to PL ENDO For This Useful Post:
ASHMS3 (09-18-2012), dMuze (09-19-2012)
 Old 09-15-2012, 04:15 PM   #54
desertmike680's Avatar
Posts: 64   (View Stats)
desertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to behold
Groaned at 44 Times in 12 Posts
Very nice. What was the cost around to install?
2012 Velocity Red with Tech/Sure SRI/Sure TIP/Forge BPV/(Not sure what the hell I'm moding next, might spend money on hookers instead)
desertmike680 is offline   Reply With Quote
 Old 09-15-2012, 05:27 PM   #55
zmarko's Avatar
Posts: 147   (View Stats)
zmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond repute
Reading comprehension FTW.
-Marko 2012 Speed 3
zmarko is offline   Reply With Quote
The Following 3 Users Say Thank You to zmarko For This Useful Post:
Easter Bunny (09-19-2012), J'sSpeed3 (09-18-2012), Mizzle (09-16-2012)
 Old 09-15-2012, 05:56 PM   #56
anavrinIV's Avatar
Groans: 63
it actually looks pretty well done.
still not my thing, but honestly if I didn't know it was aftermarket I wouldn't think twice.
Blue Pu.
 Old 09-18-2012, 01:46 PM   #57
pacheco_ms3's Avatar
Posts: 90   (View Stats)
pacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond reputepacheco_ms3 has a reputation beyond repute
i like it, i wouldnt mind getting one myself after my warranty expires among other things. How is the noise level? any creaks/ groans from the roof during spirited driving?
My name is Adrian
2013 MUSTANG GT 5.0
!STOCK!
2010 Velocity Red MS3 -SOLD
K&N SRI
CS TIP
Forge BPV V1
TWM heavy type R
CS Recirc & Boost tubes
pacheco_ms3 is offline   Reply With Quote
 Old 09-18-2012, 02:08 PM   #58
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
i bought an MS6 sport over an available GT because i hate sunroofs that much.
that being said, yours does not look bad after install. For 1000, i'd hope it looked decent.
How's that noise at 80mph?
 Old 09-18-2012, 02:32 PM   #59
865ms3's Avatar
Posts: 2,602   (View Stats)
865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world
mehh..i thought the only ms3 option for a sunroof was in the block??
Brent
Mazda Dragon Camp - Event Coordinator
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
865ms3 is offline   Reply With Quote
The Following User Says Thank You to 865ms3 For This Useful Post:
snOhio (09-19-2012)
 Old 09-18-2012, 02:35 PM   #60
jimmy's Avatar
Posts: 234   (View Stats)
jimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond repute
Just checked out a VW Jetta TDI Sportwagon with a monster sunroof in it. Wonder if you can get this in the speed...
2010 LSM MS3 w/ Tech: Cobb AP, CorkSport SRI/TIP, JBR 80d RMM, JBR SSP, JBR SSB, JBR heavy knob, RallyArmor mudflaps, DDM 5k HIDs, Lamin-X fogs.
jimmy is offline   Reply With Quote
 Old 09-18-2012, 02:45 PM   #61
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
What's that old phrase? Proof is in the pudding. ^^^There's the fucking pudding.
The biggest concern is safety, fellas.
I'd hate to see one of these after a hard side impact collision or roll over. Nasty stuff.
this forum serves 2 purposes
 Old 09-18-2012, 09:12 PM   #62
PL ENDO's Avatar
last saturday i took it out on some twisting road at 100}+mph and the roof held up no wave affect like some said might happen, there is no creaks or groans from it moving just hear the motor when its moving other then that nothing.
if i dont have the windows cracked there is a little over pressure noise like if you only have the rear windows down but not as bad in fact like 1/10th of it. i just did a 550 mile drive with it open and in vent postion for the rain no water got inside the car.
if you can find the manufacture or a aftermarket one and someone is willing to install it and you pay for it its all can be done. shit i was thinking of a carbon fiber roof for mine, far down the road
 Old 09-19-2012, 05:38 AM   #63
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
and now we have new pudding...
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
The Following User Says Thank You to dbrier For This Useful Post:
Darth_Nuruodo (09-19-2012)
 Old 09-19-2012, 12:39 PM   #64
I <3 your mom
Dash08's Avatar
Groans: 293
Which pudding are you referring to?
I hope you're not talking about the guy who thinks everything is fine. Because that's not pudding, it's an opinion. And, not an educated one at that.
Regardless, I made my point. Whether people choose to heed it or not is entirely up to them.
 Old 09-19-2012, 01:01 PM   #65
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Maybe he was referring to this line?
Bone stock so far
 Old 09-19-2012, 07:31 PM   #66
Wide tire man
dbrier's Avatar
You were taking one persons negative review as "proof in the pudding" that it will ruin a car. Now we have a couple positive reviews. One review is not proof either way, but you seemed to take it that way.
You have your opinion on what a sunroof will do to a car, but Mazda disagrees and puts them in their other models. I hate to tell you that most OEM sunroofs are purchased from the same companies that make aftermarket ones.
 Old 09-20-2012, 06:33 AM   #67
Mine only creaks from the body flexing when going over over very irregular surfaces. And the creaking did not start until about a year after it was installed. On straightaways and faster driving, it's perfectly fine. It looks good, was professionally installed by a Webasto dealer. It also has a retractable shade so you can have the shade open and the sunroof closed just to let the light in. It cost me 1K. No issues other than the creaking. I suppose I could bring it back to a Webasto dealer although the closest dealer is 75 miles away and I work 11 hours a day so I just live with the creaking.
Roof Rack monkeySPEED MazdaSpeed 3/6 - Appearance 92 03-24-2016 03:59 PM
MGM MS3 with RX-8's and a roof rack luckylad82 Appearance - METRO GREY 7 07-17-2012 05:46 PM
How to replace your roof rails (for roof rack use.) ncpaladin MazdaSpeed 3 - How-To's 7 11-30-2010 12:36 PM
Page generated in 0.47075 seconds with 38 queries
