SURE Intake question Do I need anything special to use this intake? From what I believe its got a stock MAF size but it says to use it with a 4" TIP? Or does the 4" TIP come with it? Idk im kinda lost. Full3 Aeros SI GT | SURE Motorsports Or should I get this one... Full3 Aeros SI | SURE Motorsports What about this one.... Fuck. Full3 Aeros ID300 | SURE Motorsports I thought they would offer a 3" TIP, do they or am I just fucking all this up... I had a corksport sri intake and tip on my old speed. How is that any different than any of these? |
The first one is an OEM size MAF housing with a 4" GT turbo inlet. Don't get this one. The second one is the stock sized TIP and OEM size MAF for the OEM turbo. The third one is the full 3" intake from MAF to OEM turbo inlet. The third one will give you the best performance out of the ones you listed for the OEM turbo but you need an AP to scale the MAF. |
Option B for stock MAF size, so no tuning required and connects to stock turbo. Edit: What he ^^^^ said |
And im also highly considering going the stratified route once all my parts are on, ive heard good things about ya. |
If you want to just tweak a map to work with it, just use the 3" MAF calibration posted here, save the map using ATR and flash it on your car: http://www.mazdaspeedforums.org/foru...ntakes-124734/ |
Man, I sure wish someone could help me with my MAF cal.....(sigh) |
BAM! you have been helped sir:veryhappy: |
| All times are GMT -7. The time now is 05:24 AM. |
