-   -   Sure tip help!! (http://www.mazdaspeedforums.org/forum/f544/sure-tip-help-92693/)
niko.v 09-25-2011 12:36 PM
Sure tip help!!
Okay so I installed the tip in the car it was smoth no problems but after when I drove the car when I would go into full boost and let off the gas like when shifting I hear a loud chirp idk what it is I have the forge v2 bpv with blue spring in it.
Is the chirp normal or is it something with the spring in the bpv should I put a shim? Any help would be greatly appreciated thanks.
BobbleHead 09-25-2011 01:06 PM
does it sound like that? Forge V2 was supposed to eliminate that sound I thought but that's what my forge V1 sounds like
m4tic 09-25-2011 01:08 PM
http://i.imgur.com/nph41.png
SWAY 09-25-2011 01:22 PM
^^^cmon lets use a lil bit smaller insults my m11x cant take that big shit
I had to scroll over to thank you wtf
niko.v 09-25-2011 03:39 PM
Can I get a reall answer it's a big chirp in high boost is it ok?
SWAY 09-25-2011 03:42 PM
if your question is, will you blow up?? then you are ok
Edit: On another serious note get an AP so you can monitor and know for sure whats going on, and my (your ok) will actually be backed up and not just me throwing that out there for your comfort.
niko.v 09-25-2011 05:53 PM
[php][/php]
No I'm asking If the noise is ok and the car runs fine and ap is coming in less then a month
R3L3NTL3S 09-25-2011 06:48 PM
The noise is fine. I wouldn't sweat it. If you are still paranoid about it just dont beat the shit out of your car until you get your AP
niko.v 09-25-2011 08:36 PM
Like is the noise normal? My boy used to have a 08 ms3 and knows them like the back of his hand and he said the Boise was normal he said it's just the boost going back into the system he said you here it now with the tip because of the material and how the stick one was so comstrictive
R3L3NTL3S 09-25-2011 08:43 PM
Yup. your buddy was right man. dont sweat it. and congrats on the install
aanguia1 09-25-2011 10:35 PM
I know this is out of topic but when I installed my Sri+tip(corksport) now I don't hear the pressured air recirculating at all when I let go to the gas....I ran both full recirc and 50/50 with no luck its super quite and all I hear is my exhuast what do you guys think it is???
bayarea_pat 09-25-2011 10:39 PM
I get the same chirp while letting off under partial boost. No problems here after 6+ months of having it installed.
BobbleHead 09-25-2011 10:46 PM
Genpus
http://i618.photobucket.com/albums/t...0/facepalm.jpg
lolz
ahskeetz 09-25-2011 11:24 PM
wait is this for real? lol. dude that's completely normal. your stock BPV should have made a similar sound with just an intake on too.
SWAY 09-25-2011 11:28 PM
no hes got the v2 forge no ninjas
Originally Posted by black07spd (Post 1059585)
cmon were not all bad its these noobz makin the good genwin guys look bad dammit
BobbleHead 09-26-2011 01:07 AM
^^^I'm messing. I know we need to be nice to genpus since that's what are future on MSF is!
niko.v 09-26-2011 07:57 AM
Ok so after driving for a while the chirp is only in 4,5,6 gear is that normal?
Page generated in 0.19436 seconds with 11 queries
