 Old 03-17-2019, 08:12 PM   #1
eddie7978's Avatar
Posts: 6   (View Stats)
eddie7978 is an unknown quantity at this point
Default tech package headlights and taillights in non tech package car?
is it possible to swap the tech package headlights or taillights to non tech package speed 3?
eddie7978 is offline   Reply With Quote
 Old 03-18-2019, 08:35 AM   #2
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Tech package headlights are HID and have Adaptive Front-lighting System (AFS). I doubt it will be plug-n-play. Cars with AFS have a button to disable.
I think LED tails will work.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 03-18-2019, 12:19 PM   #3
Adamxx6's Avatar
Posts: 43   (View Stats)
Adamxx6 will become famous soon enoughAdamxx6 will become famous soon enough
Tail lights for sure work. i did it, just plug them in.
Adamxx6 is offline   Reply With Quote
 Old 03-18-2019, 02:53 PM   #4
eddie7978's Avatar
where did u get them?? is it just the outters and inners or just outers?
 Old 03-18-2019, 07:22 PM   #5
Adamxx6's Avatar
i just came across them on ebay. its just the outers. inners are all the same
 Old 03-18-2019, 07:24 PM   #6
Adamxx6's Avatar
heres a pic with one of each on there for reference
 Old 03-18-2019, 07:56 PM   #7
eddie7978's Avatar
cool thanks for the help.. do u know if anyone that put tech headlights on non tech car?
 Old 03-18-2019, 09:04 PM   #8
Adamxx6's Avatar
not sure if its possible. i looked into it and couldnt find anything. its definitely not just a straight swap anyway
 Old 03-19-2019, 06:47 AM   #9
eddie7978's Avatar
yea i’ve been searching but having found anything .. surprised no one has tried to figure it out..
 Old 03-19-2019, 08:09 AM   #10
thatguyinms's Avatar
Posts: 31   (View Stats)
thatguyinms will become famous soon enoughthatguyinms will become famous soon enough
My understanding is that they will bolt up but the wiring into the harness uses a different style plug so it’s not PnP.
You may be able to use the assembly for a Tech and a HID ballast for non-tech with the appropriate bulb and make it work.
OEM ballast won’t work unless you want to figure out the wiring. I wouldn’t suggest trying to make the AFS work. Looks like a pain, even if possible to bolt up.
2013 Mazdaspeed 3
91k miles and counting
Freektuned since 17k at 21psi
Power:
HTP 3.5" intake - TR8 - CX piping - Snow Stage 2 @ 100% meth at 625mL/min- UR catless DP - UR testpipe - Corksport axleback - Turbosmart Dual port on recirc
Supporting:
Corksport HPFP - fresh blasted valves- 3Bar MAP+pigtail - Damond EGR full delete - Damond Trio - TB Coolant bypass - 51r battery w/box - Corksport shift bushings -
Known Fails:
Florida Heat - stock k04 - OEM Midpipe - shitty ebay catchcan
thatguyinms is offline   Reply With Quote
 Old 03-19-2019, 08:41 AM   #11
eddie7978's Avatar
yea i’m not going to attempt doing anything
was just hoping someone made a diy for doing it or trying to figure out a way to make it work
but i guess they rather get aftermarket or modify the stock ones
it’s a shame cuz i like the techs better
Why do tech package headlights have two adjustments? LowFlyin Gen2 MS3 General Discussion 8 01-20-2017 11:23 AM
Tech package / Non tech headlight size RileyMS3 Exterior 1 03-12-2016 04:38 PM
Painting inside of tech package headlights? k_young24 Exterior 6 12-22-2015 08:53 PM
Tech Package? Dungmaggot Mazdaspeed3/6 General Discussion 10 05-29-2012 10:46 AM
Tech Package/MID jellowood 2010 MS3 - Car Audio & Electronics 5 02-03-2010 08:03 AM
Page generated in 0.30781 seconds with 24 queries
