Notices
Like Tree3Likes
  • 1 Post By Captain KR
  • 1 Post By Sid3wayS
  • 1 Post By manilaMS12
 Old 03-08-2012, 11:38 AM   #1
desertmike680's Avatar
Posts: 64   (View Stats)
desertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to behold
Groaned at 44 Times in 12 Posts
Default Test Pipe and noises
Hey guys,
I'm thinking that my next mod will be the Test Pipe, but my questions regarding are: Whats the difficulty of installation on a 2012 and does it really make a big difference with sound and performance as it is?
Second question: Is there a TSB for defective transmission mounts? These "doink" and "thunk" noises from shifting, along with the "squeaking" and "creaking" while giving the car gas are starting to get annoying. I asked the dealership to check out the "Sub frame bushing" and stated that there is a TSB regarding, but of course they could not verify. So next time I go in, I'm going to dupicate the issue with the tech in the car and ask them to check out the transmission mounts.
Anyone else experiencing it?
Thanks
2012 Velocity Red with Tech/Sure SRI/Sure TIP/Forge BPV/(Not sure what the hell I'm moding next, might spend money on hookers instead)
desertmike680 is offline   Reply With Quote
The Following User Says NO Thank You to desertmike680 For This Un-useful Post:
jack_hammer (03-08-2012)
 Old 03-08-2012, 11:45 AM   #2
dhsieh911018's Avatar
Posts: 544   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
you're next mod should be AP and fuel pump internal instead of test pipe
dhsieh911018 is offline   Reply With Quote
The Following 7 Users Say Thank You to dhsieh911018 For This Useful Post:
CtrlAlt1337 (09-19-2012), DYLANSLOVER (09-19-2012), fortressofcomfort (09-19-2012), jtt (03-08-2012), Juyoung (09-19-2012), J_Logik (03-09-2012), uncorked11 (03-08-2012)
 Old 03-08-2012, 11:45 AM   #3
Pseud0logik's Avatar
Posts: 2,013   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groans: 76
Groaned at 31 Times in 28 Posts
To answer your first question, the installation difficulty is low, especially on a 2012 since your bolts probably won't be seized yet. If you're going to take it to the dealer for them to check the mounts I would wait until that's over with to install it.
Pseud0logik is offline   Reply With Quote
 Old 03-08-2012, 11:45 AM   #4
Garage Queen
Sid3wayS's Avatar
Posts: 4,313   (View Stats)
Groans: 53
Installation is easy: jack up car, remove mid chasi brace, 4 bolts for the stock cat, replace with new rp in reverse order.
You should also look into the donation mod.... Best bang for your buck hands down.
2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail
Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP
ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs
Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5
Meth/E85/Nitrous TUNING BY LEX
Sid3wayS is online now   Reply With Quote
The Following 4 Users Say Thank You to Sid3wayS For This Useful Post:
DYLANSLOVER (09-19-2012), fortressofcomfort (09-19-2012), Juyoung (09-19-2012), uncorked11 (03-08-2012)
 Old 03-08-2012, 11:50 AM   #5
Macedawg's Avatar
Posts: 1,156   (View Stats)
Macedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the world
yep, definitely an easy install
desertmike680 i didnt notice much more sound out of the test pipe..maybe just a bit deeper with a little gurgle..my next mod will be yanking the resonator out
the "doink" and "thunk" you mention is similar on mine i'm hoping to get a RMM soon and see if that helps out
Ferg: ive been inside so many deep dark loose holes even ron jeremy would be impressed.
Macedawg is offline   Reply With Quote
 Old 03-08-2012, 11:57 AM   #6
Jake_MS3's Avatar
Posts: 836   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
Its about as easy to install as clicking the SEARCH button at the top
You may want to look into the VIP mod, thats where the real hp numbers come out!
2009 Mazdaspeed 3
/// COBB AccessPORT Stage2 /// COBB Tuning SF Intake /// Ultimate Racing Test Pipe /// Autotech HPFP Internals /// Turbosmart Dual-Port BPV /// Denso ITV22's /// Corksport Boost Tubes /// Corksport BPV Return Hose /// CP-e RMM 75D /// Redline 75w90 /// DDM Tuning 6K Lows, 3K Fogs /// Prosport Boost Gauge /// RPM Vent Pod ///
Jake_MS3 is online now   Reply With Quote
The Following User Says Thank You to Jake_MS3 For This Useful Post:
 Old 03-08-2012, 12:09 PM   #7
anavrinIV's Avatar
Posts: 2,084   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
my test pipe took me forever and a half to do, but I also had the difficulty of having missing parts, incorrect information, and a cracked pipe. In all reality you should be able to do it in an hour if all goes well. I broke all my exhaust bolts loose with relative ease, without needing pb blaster. my main problem was with a gasket...and taking 2+ hours to find a couple bolts that I needed half way through the install.
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
 Old 03-08-2012, 12:31 PM   #8
Onelovesoccer's Avatar
Posts: 1,259   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 105
Groaned at 14 Times in 8 Posts
it should be an easy install, but when Captain KR did my install, it turned out to be a bitch. but you car is two years younger, so i'm sure it'll be easier to get those bolts off.
also, don't do it until you get an AP and internals. sounds like some motor mounts would do you some good too.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS Stage 2 SRI | RMM | Shifter Bushings | JBR SSP/Counterweight | UR TP | Resonator Delete | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs
Future Mods: MD OCC (to install), UR CBE, Cobb FMIC, Cobb BPV, JBR TMM & PMM, cp-e S2 RMM (ordered), UR v.2 catted DP (to install), JBR Coolant Bypass Kit (to install), cp-e SAFEseals (to install), JBR TIG (to install), SD/JMF IM, EM, BNR S3, PTP Injector Seal Studs (to install), TWM Full Replacement, Grimmspeed EBCS
Future Aesthetics: gun-metal black TSW Nurburgring wheels, red PC calipers w/ Mazdaspeed emblem
Onelovesoccer is offline   Reply With Quote
 Old 03-08-2012, 12:55 PM   #9
uncorked11's Avatar
Posts: 1,124   (View Stats)
Groans: 156
Start with atleast the rear motor mount, JBR's 88 duro makes a huge difference. Then do AP and internals just to be safe, this is the last car to try to re-invent the wheel.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is online now   Reply With Quote
The Following User Says Thank You to uncorked11 For This Useful Post:
Pseud0logik (03-08-2012)
 Old 03-08-2012, 03:41 PM   #10
Neutral  -1 score
Ok so I should wait in the Test pipe until I consider other mods first? These noises are so annoying. Its definitely the rear MM or transmission mount. As the car is starting, you can hear this creak/squeak noice and the motor is turning on, as well as hearing it when the clutch is engaged while moving. I thought the noise was coming from inside the cabin, but I can hear it even more when the windows are down.
I just might get the TP anyway. I really dont want to mess with the AP or internals honestly.
The Following 5 Users Say NO Thank You to desertmike680 For This Un-useful Post:
ASHMS3 (03-08-2012), Captain KR (03-08-2012), kabobulate (03-08-2012), Onelovesoccer (03-08-2012), Pseud0logik (03-08-2012)
 Old 03-08-2012, 03:48 PM   #11
Garage Queen
Sid3wayS's Avatar
Groans: 53
So you would rather mess with the likelyhood of a blown motor... Honestly. Its been shown with as little as an intake the fuel pump on a genpu shyts the bed. It's your car at the end of the day do what you feel is right, but I suggest reading up on cause and effect of different mods. Good luck n happy modding.
Dr. Speed (09-19-2012), Juyoung (09-19-2012), Onelovesoccer (03-09-2012), Pseud0logik (03-08-2012)
 Old 03-08-2012, 03:53 PM   #12
darth_speeder's Avatar
Posts: 430   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
Groaned at 7 Times in 6 Posts
i noticed a deeper growl after the TP install. not too drastic, but it's there, maybe cause it is catless.
but you should listen to these guys and go with AP and internals first. they know what they're talking about. prevent a zoom zoom boom.
Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
The Following 2 Users Say Thank You to darth_speeder For This Useful Post:
DYLANSLOVER (09-19-2012), Juyoung (09-19-2012)
 Old 03-08-2012, 03:57 PM   #13
Groans: 76
^This.
If you are seriously against getting internals, then just get an AP and run a Stage1 safe mode tune. But it's not wise to start bolting things on to a pu without more fuel, sorry.
 Old 03-08-2012, 03:58 PM   #14
Groans: 105
Fine, fuck internals and an AP and get a TP. blow up your engine. Jesus fucking christ...
The Following 4 Users Say Thank You to Onelovesoccer For This Useful Post:
anavrinIV (03-08-2012), Captain KR (03-08-2012), Juyoung (09-19-2012), Sid3wayS (03-08-2012)
 Old 03-08-2012, 04:38 PM   #15
anavrinIV's Avatar
Groans: 35
I'm so glad to have a gen1...stage 1 tune, test pipe, no internals, and still holding strong. Although they're next on the list because they're a whole lot cheaper than a new block, rods, pistons, and labor.
2007 Black Mica MS3
 Old 03-08-2012, 04:43 PM   #16
Groans: 76
That's where I was a week ago. My boost started spiking when I added the TP to the stage1 tune, but pressure was fine. The gen1 ECU just handles fuel completely differently than the genpus.
The Following User Says Thank You to Pseud0logik For This Useful Post:
 Old 03-08-2012, 04:43 PM   #17
Captain KR's Avatar
Posts: 2,103   (View Stats)
Groans: 368
Groaned at 62 Times in 36 Posts
LOL DONT YOU HATE IT WHEN BROWNIES/NEWBS DONT LISTEN TO YOU! THIS IS EXACTLY WHY I TROLL SO HARD!
Onelovesoccer likes this.
Mason Dixon Raceway 11.289 @125 1.845 60"
Killah Built
Powered By Purple Drank
Captain KR is online now   Reply With Quote
The Following 5 Users Say Thank You to Captain KR For This Useful Post:
ASHMS3 (03-08-2012), DYLANSLOVER (09-19-2012), Easter Bunny (09-19-2012), Onelovesoccer (03-08-2012), Pointless (09-19-2012)
 Old 03-08-2012, 04:51 PM   #18
Groans: 105
Yeah, absolutely man.
And OP, you can get all the motor mounts and not do a TP and you'll be fine. If you want the TP for sound but don't want internals or an AP, then delete the resonator instead. $50, cheapest thing you can do for sound, and it works really well.
Yeah man, I can see why people rage about it. This shit is literally beat to death.
Last edited by Onelovesoccer; 03-08-2012 at 04:51 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Onelovesoccer For This Useful Post:
Captain KR (03-08-2012), Pseud0logik (03-08-2012), uncorked11 (03-08-2012)
 Old 03-08-2012, 04:58 PM   #19
Captain KR's Avatar
Groans: 368
THIS IS WHAT OP SOUNDS LIKE "WAHHHHHH FP INTERNALS DONT GIVE ME HP WAHHHHHHHH" "WAHHHH I WILL NEVER MAKE HP CAUSE I DONT KNOW HOW TO LISTEN WAHHHH". PREVENTATIVE MAINTENENCE IS THE KEY TO BEING RELIABLE, WOULD YOU LET A DEALERSHIP CHANGE YOUR VVT WITHOUT DOING THE CHAIN AND THE TENSIONER ? HELL NO YOU WOULD WANT THEM TO DO THE ENTIRE TIMING SIDE! WHY? BECAUSE IT MAKES SENSE, OP IS A FUCKING FAG.
Killah Built
The Following User Says Thank You to Captain KR For This Useful Post:
 Old 03-08-2012, 05:23 PM   #20
Neutral  -2 score
Where is the resonator? And does Street Unit have the resonator delete?
The Following User Says Thank You to desertmike680 For This Useful Post:
The Following 3 Users Say NO Thank You to desertmike680 For This Un-useful Post:
ASHMS3 (03-08-2012), Captain KR (03-08-2012), Onelovesoccer (03-08-2012)
 Old 03-08-2012, 05:50 PM   #21
Garage Queen
Sid3wayS's Avatar
Groans: 53
Go to a muffler shop tell them to cut out the resonator....
And everything else after it... hella loud dawg.
uncorked11 likes this.
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
ASHMS3 (03-08-2012), Onelovesoccer (03-08-2012), uncorked11 (03-08-2012)
 Old 03-08-2012, 06:04 PM   #22
jack_hammer's Avatar
Posts: 4,173   (View Stats)
Groans: 413
Groaned at 105 Times in 61 Posts
Are you fucking kidding me? You're an idiot and deserve the fail that awaits you...
Sent from my LG-MS690 using Tapatalk
it's fun to do bad things
The Following 3 Users Say Thank You to jack_hammer For This Useful Post:
ASHMS3 (03-08-2012), Juyoung (09-19-2012), uncorked11 (03-08-2012)
 Old 03-08-2012, 06:06 PM   #23
lol at "does su have a res. Delete.."
Google.com... use it..
Corn Fed//Richtuned
 Old 03-08-2012, 06:20 PM   #24
Captain KR's Avatar
Groans: 368
Why aren't Yall groaning his posts lol he has said the dumbest shit possible and is obviously looking to be spoon fed.
Killah Built
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
The Following User Says NO Thank You to Captain KR For This Un-useful Post:
 Old 03-08-2012, 06:35 PM   #25
Proshop's Avatar
Posts: 139   (View Stats)
Proshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond reputeProshop has a reputation beyond repute
Wow!! Another 5 mins of my life wasted.. Good for a laugh thou.. Can some one make a Smiley that says "Zoom Zoom Boom" please!!
Actually even better:
I haz no Pu no mo!!
Careful what you type, there a grammar Nazi's around.
Proshop is offline   Reply With Quote
 Old 03-08-2012, 07:47 PM   #26
Groans: 413
calls for groans beget groans
 Old 03-08-2012, 07:55 PM   #27
anavrinIV's Avatar
Groans: 35
This shit was so epic I had to thank it and use it in my signature. I've never laughed so hard at a post in my life
2007 Black Mica MS3
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
ASHMS3 (03-08-2012), DYLANSLOVER (09-19-2012), Onelovesoccer (03-09-2012)
 Old 03-08-2012, 08:00 PM   #28
harryclay's Avatar
Posts: 667   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
In before zoomzoom BOOM!
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Pirelli PZero Asimetrico 225 40 r18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline   Reply With Quote
 Old 03-08-2012, 08:17 PM   #29
DownSideFX's Avatar
Posts: 215   (View Stats)
DownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the world
Groaned at 19 Times in 7 Posts
I had a Corksport race pipe with SRI and TIP for over a year w/o internals or AP.
My car didn't boom, but maybe I was lucky (I also don't drive like an asshole generally).
It sounds a little better, definitely what the other guy said about slight gurgle, maybe a deeper exhaust note. Get a CBE if you just care about sound.
My car will probably die tomorrow for all the hubris I have displayed.
2010 Mazdaspeed3
CS SRI/TIP, Race Pipe, Axleback CP-E TMIC Forge V2
Autotech Internals NGK Step Colder Tuned locally!
Enkei Tuning Raijin 18x8 - Bridgestone Potenza RE-11s CS springs
DownSideFX is offline   Reply With Quote
 Old 09-19-2012, 12:19 AM   #30
Speed3Mtl's Avatar
Posts: 1   (View Stats)
Speed3Mtl can only hope to improve
Groaned at 7 Times in 1 Post
Default Light mods....so no internals.
I'm not gonna say ap and fp are not worth it..after reading many posts i'll absolutely agree it's vital for heavy modding. But for light mods - Let's say ... Intake, tip, and test pipe has anyone seen the fuel pump die with these mods?
One post said the fuel pump has trouble even with the intake....really??? Is this 1 case...or very likely?
I just bought a 2012 MSP3. Before that I owned a 2007 Mazdaspeed 6 with air intake and never had any issues.
I'm gonna stick with light mods ---- intake+tip, and rmm
checked the corksport dyno of the test pipe they claim up to 12hp more. I also like the deeper sound it gives. (But still not sure on the test pipe...?)
Speed3Mtl is offline   Reply With Quote
The Following 7 Users Say NO Thank You to Speed3Mtl For This Un-useful Post:
ASHMS3 (09-19-2012), Easter Bunny (09-19-2012), jack_hammer (09-19-2012), Onelovesoccer (09-19-2012), Pointless (09-19-2012), Sid3wayS (09-19-2012), smoogs12 (09-19-2012)
 Old 09-19-2012, 12:48 AM   #31
Littlescroll's Avatar
Posts: 311   (View Stats)
Littlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the worldLittlescroll is the leader of the world
The last post in this thread was more than 6 months ago...
And just in case you have trouble reading the thread and and the warnings in it and ALL OVER this website: Go ahead and install the testpipe. If you can handle going WOT daily knowing that you might blow your motor at any time then by all means, do it.
I have an intake on the stock tune and I will not be doing anything else until I get my AP and internals(at the same time.)
Edit: Getting groaned on your first post is a pretty bad start. Stop posting and start reading.
2012 CWP MS3 w/tech
Mods: Cobb AP, Autotech HPFP Internals, Forge: V1 BPV,
Corksport: TMIC, SRI/TIP, Racepipe, RMM, SSP, LED Fogs, Tow Plate, Mud Flaps,
20% tint, Resonator delete.
Gunmetal PC'd RX8's with stock rubber.
Winter Setup: Gold MZ3 17s w/ Blizzak WS70 205/50R17
Littlescroll is offline   Reply With Quote
 Old 09-19-2012, 05:54 AM   #32
Groans: 105
Captain KR
 Old 09-19-2012, 06:46 AM   #33
manilaMS12's Avatar
Posts: 1,006   (View Stats)
manilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the world
Groaned at 17 Times in 11 Posts
In before (OP desertmike680) is actually Speed3Mtl trying to recover his own thread
fortressofcomfort likes this.
'12 MS3 Black Mica w/ Tech
Power: COBB AP > HTP 3.5" > ATP DP (CATLESS) > AUTOTECH INTERNALS > GFB RESPONS > NGK PLUGS
OTHER: JBR 88DURO RMM > SSP >BUSHINGS > KNOB > RSB
VOODOO TOON in progress (Thanks to fortressofcomfort)
manilaMS12 is online now   Reply With Quote
 Old 09-19-2012, 08:40 AM   #34
Mazda Super Tech
motherfnmonsta's Avatar
Posts: 951   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
go back to mazda24/7 they seem to be more on your level what you goals for the car are.
injen cai,cobb tip,jbr tig,jbr egr delete,jbr heavy shift knob,internals,ur dp,ur tp,maganaflow cbe
jrb rsb,cs lowering springs.
motherfnmonsta is online now   Reply With Quote
 Old 09-19-2012, 09:00 AM   #35
Garage Queen
Sid3wayS's Avatar
Groans: 53
When you troll someone make sure their post is not 6 months old.
The Following User Says Thank You to Sid3wayS For This Useful Post:
Raider (09-19-2012)
 Old 09-19-2012, 09:23 AM   #36
Mazda Super Tech
Ehh it was brought back up my bad and fail on my part
Sent from my Android using Forum Runner
 Old 09-19-2012, 12:48 PM   #37
fortressofcomfort's Avatar
Posts: 867   (View Stats)
I'm just glad Captain KR turned off his CAPS LOCK, shit was hurting my eyes.
Anyway if OP is dumb enough to do a test pipe now be sure to remove the "mid chassis brace" first otherwise you'll be pissing and moaning that you don't have another 1/2 inch of space to work with and yes that's what she said. Oh and for OP, be sure to put said "mid chassis brace" back on when completing installation.
Anyway a test pipe will make your car about 10% louder, doesn't change the sound quality at all, and adds about 5-7 hp.
Not sure about OPs transmission/mount woes. I'm still rocking all the stock mounts and having no issues, bucking the trend yknow?
2012 Black Mica MazdaSpeed3
Street creds:
The Following User Says Thank You to fortressofcomfort For This Useful Post:
Ultimate racing test pipe and down pipe install w pics 2010 MS3 2010 MS3 - Engine, Transmission & Driveline 28 03-17-2010 09:38 AM
Brand name test pipe vs. custom muffle shop test pipe Huligan MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-05-2009 06:52 AM
SU test pipe vs. turboxs test pipe ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 22 08-06-2009 02:09 AM
Page generated in 0.69710 seconds with 39 queries
