 Old 01-25-2012, 09:28 PM   #1
paradigme's Avatar
Posts: 228   (View Stats)
paradigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the worldparadigme is the leader of the world
Default Time to finish what I started
My MS3 turned two last month. I've got about 16,000 miles on it and have done what most people do to it. SRI, TIP, and a test pipe. I've decided to take the leap and get the rest of what I want for the car. Looks like I'm going with an AP and CP-e components.
Catted DP
FMIC
HPFP
I live relatively close to CP-e and they've been awesome in the past when I swapped out my motor mount. Also thinking about installing the other two motor mounts from CP-e as well.
Besides the obvious (making sure the tune is right) is there anything I should consider? The car is a weekender at best and I really like taking it to the track. I'm looking forward to a little more mid range and top end.
Cobb SRI, Cobb TIP, TurboSmart Dual Port BPV, UR Test Pipe, J-Spec Tails, 6k 55W HID Low Beams, 6k 35W Fogs, CP-E RMM 75 duro, 18% Tint
Currently under (de)construction: Catted Downpipe, FMIC, HPFP, AP
paradigme is offline   Reply With Quote
 Old 01-25-2012, 09:33 PM   #2
HARPER306's Avatar
Posts: 444   (View Stats)
HARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the worldHARPER306 is the leader of the world
Neutral  -1 score
get the jbr mounts instead, cpe are a bunch of cock gobblers
'12 Evo X
HARPER306 is offline   Reply With Quote
The Following 2 Users Say Thank You to HARPER306 For This Useful Post:
Ckmazdaspeed3 (01-28-2012), dereeek (01-25-2012)
 Old 01-27-2012, 08:31 PM   #3
Si[xXx]er's Avatar
Posts: 43   (View Stats)
Si[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant future
I don't see a fuel pump mentioned anywhere in your post/sig, I think you will need one with that many mods. Also, you would probably benefit from a proper custom tune after all the mods are installed, to keep things safe and making and maximizing your gains.
When you have lost everything, what do you have left to fear?
Si[xXx]er is offline   Reply With Quote
 Old 01-27-2012, 08:32 PM   #4
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Hpfp s in his mod purchases.
I recently went from cpe to JBR for rmm. Much happier
The Following 3 Users Say Thank You to Raider For This Useful Post:
Ckmazdaspeed3 (01-28-2012), rghispanic88 (01-27-2012), silvapain (01-28-2012)
 Old 01-27-2012, 09:16 PM   #5
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
^^this
also jbr offers great customer service
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
Payne Racing 67 (01-28-2012)
 Old 01-28-2012, 07:58 AM   #6
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
A little off topic but daamn you must drive alot,
My pu is 3 months I just hit 1k miles a few days ago
Sent from my SGH-T959V using Tapatalk
2012 CWP Mazdaspeed3 Current Mods: Cobb Turbo Back|Cobb Sri/Tip|Cobb XLE|Cobb Ap|Jbr Heavy Shit Knob|AutoTech Internals|JBR Short Shifter Plate/Brushings|Corksport Tmic|
Noodlesincup is offline   Reply With Quote
 Old 01-28-2012, 08:14 AM   #7
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
how is 16k miles in 2 years a lot of driving?
Mods: stock
 Old 01-28-2012, 08:34 AM   #8
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you must not drive much at all...
I've had my speed for under 2 months and have put about 2500 miles on it. And I don't think that I drive much...some guys here go 100+ miles a day.
OP, path sounds good. The cp-e pump is a good safety measure vs internals, but it's super expensive. Also, IMO, there's no need for an fmic with a bolted k04 system...and upgraded tmic will be cheaper and should be just as effective (not in traffic, mind you, but you won't be boosting in heavy traffic anyway). That's just my preference though, and it really is dependent on budget (of which mine is minimal).
Blue Pu.
 Old 01-28-2012, 08:52 AM   #9
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
I do about 70 miles a day, racking the miles up.
The Following User Says Thank You to G26 For This Useful Post:
 Old 01-28-2012, 08:57 AM   #10
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
i just turned 36k other nator members with pu's have more miles than i do haha
 Old 01-28-2012, 08:57 AM   #11
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Jbr mounts ftw. I have had all three cpe mounts rip on me and none of them made it 20k.
Edit: 41k on 2010... Would have more but blown motor has taken 1.5 months so far. Hopefully back to putting on miles in another week or so.
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
Payne Racing 67 (01-28-2012), silvapain (01-28-2012)
 Old 01-28-2012, 07:56 PM   #12
paradigme's Avatar
I spoke with the guys at cp-e a lot about the intercooler. They basically said the same thing and said the tmic they have flows better than the fmic. I'm going to go with the fmic for two reasons: first I do plan on upgrading the turbo and internal down the road. Second I really enjoy autoX and track days. I have never seen an issue with heat soak during track days but have def seen it at autoX events.
I appreciate the input from everyone. Im looking forward to getting deep into my AP.
 Old 01-28-2012, 08:08 PM   #13
anavrinIV's Avatar
Groans: 63
sounds like you have good reasons then. the TMIC flows better because there are a lot less frictional losses due to length, but I can see heatsoak being an issue in auto-x. I never plan to track my car so I'm gonna go full stealth...and IF I ever go BT I'll set up an FMIC too.
Blue Pu.
Getting Started Swagerwagon03 Auto-X / Road Racing / Time Attack 13 12-13-2011 06:31 AM
Le Mans 2010: To finish first, first you must finish Haltech Automotive News 0 06-13-2010 08:00 AM
Car started with no oil Meder MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 05-04-2009 12:44 AM
Page generated in 0.34143 seconds with 30 queries
