-   -   TIP Question (http://www.mazdaspeedforums.org/forum/f544/tip-question-129816/)
Mclovin80 11-09-2012 08:14 AM
TIP Question
Should the vent hose from an aftermarket TIP be the same length as stock. The hose my CP-E TIP came with is about 50% longer than stock. Or does it even matter?
Sent from Cloud 9
speedy308 11-09-2012 08:19 AM
doesn't matter, you can trim it if there is a ridiculous amount of slack.
MADDOG 20/20 11-09-2012 08:21 AM
Cs tip had a longer hose too. Just make sure there are no kinks in it, cut it down a bit if you have to.
I'd imagine the companIes thought process is would you rather have too much or too little?
btstarcher 11-09-2012 08:43 AM
My stock hose wasn't long enough.
3Gee Tee 11-09-2012 08:47 AM
That's what she said.
rwelsh 11-09-2012 08:47 AM
It's so if you get a fmic it reaches the new locations of the bpv. I cut my Corksport one before I installed me fmic as the. It was too short. So cut it if you don't plan on gettig a fmic
Edit: I think I read that wrong and I'm thinking of another hose
Page generated in 0.16329 seconds with 11 queries
