![]() | | #1 | ![]() |
![]() Join Date: Aug 2011
Rep Power: 82 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 9 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score BTW, Conti gave me about a 50% break on a new set based on their tread wear warrantee. |
![]() Join Date: Feb 2011 Location: SW Washington
Rep Power: 160 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
You track it? Was the wear even?
__________________ 2012 CWP MS3 w/tech Mods: Cobb AP, Autotech HPFP Internals, Forge: V1 BPV, Corksport: TMIC, SRI/TIP, Racepipe, RMM, SSP, LED Fogs, Tow Plate, Mud Flaps, 20% tint, Resonator delete. Gunmetal PC'd RX8's with stock rubber. Winter Setup: Gold MZ3 17s w/ Blizzak WS70 205/50R17 |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,123
Groaned at 4 Times in 2 Posts
Look for a thread in suspension called OEM toe issue, IIRC. You probably need an alignment. I just rotated for the first time this weekend and the inside edge of my fronts are bald. The OEM specs for a good alignment on this car are nuts.
__________________ Old: 2011 Red Mica Speed 3 w/tech - stocked and traded New: 2013 Dodge Journey - Family CruiserFuture: Another race car, MS6 maybe? |
![]() | | #4 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 65 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
If you wear is uneven then you can tell your issues based on pattern. If you are worn on the outside edges you are under inflated and worn in the middle is over inflated. Then you also have the camber issues and toe in. Also maybe you need to change your driving style. Peeling out all the time is tempting but expensive.
![]() | | #5 | ![]() |
| The Following 4 Users Say Thank You to ASHMS3 For This Useful Post: |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2011 Location: Holland, Michigan, United States
Rep Power: 105 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
Yeah... everyone says OEM toe in issue, well my tires are bald on the inside too and my alignment is good. I know I've seen other people post that as well and you said you had an alignment as well. I'm not sure what to do at this point... this is the only thing I hate about the car... other than FWD.
__________________ 2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed... 13.5@106 |
![]() | | #7 | ![]() |
![]() Join Date: Mar 2012 Location: New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
If both inner and outter are worn, alignment and tire pressure good, you are driving it to hard...or perfectly hard IMO But for real that's what it is. Taking a corner hard causes excessive inner and outter wear, since the tires with slide a bit even if you can't hear it. Sent from my ADR6400L using Tapatalk 2
__________________ 2012 Black Mica MS3 w tech Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else |
| The Following User Says Thank You to Shadow For This Useful Post: | CWP_MS3 (10-05-2012) |
![]() | | #8 | ![]() |
![]() Join Date: Nov 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 333
__________________ 2012 Mazdaspeed 3 Liquid Silver | |
![]() | | #9 | ![]() |
| Approved MSF Vendor ![]() Join Date: Feb 2012 Location: Vancouver, WA
Rep Power: 64 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
__________________ ![]() CorkSport - http://www.corksport.com - (360) 260-CORK (2675) | |
![]() | | #10 | ![]() |
| Not Ranked : 0 score Not at all...well, the tires disagree, heh
![]() | | #11 | ![]() |
Wear is even, but the fronts (logically) are gone before the rears. I don't track the car, but most of my driving is on twisty mountain roads, and while I don't slide the car, I use it hard. I wonder if Conti will offer another 50% break if I go through the next set in 10k.
![]() | | #12 | ![]() |
![]() Join Date: Nov 2011 Location: San Bernardino, CA
Rep Power: 37 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
i went through my dunlops around 17k, seems like a normal thing for the mazdaspeed3 the inner wear has to do with the stock suspension & the guy at americas tire said this is common with all cars with sport tuned suspensions, get an alignment for better tire wear/ less performance
__________________ My name is Adrian ![]() 2010 Velocity Red MS3 watch out for those apple stickers |
![]() | | #13 | ![]() |
![]() Join Date: Apr 2012 Location: Laramie, Wyoming
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 559
Groans: 27
Groaned at 7 Times in 3 Posts
You just gotta stop drifting.
__________________ 2010 Mazdaspeed 3 Stocked out for sale, shit happens. |
![]() | | #14 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
Groaned at 21 Times in 10 Posts
I went through my stock ones in about 12000. Here in Chicago everything is pretty much straits, so not much cornering, whenever I can I do it though The next set was Goodyear F1 all season(super tires) lasted about 20000 miles. So i guess 15000 is not bad for your style of driving. |
![]() | | #15 | ![]() |
![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
I am just now at the wear bars all the way around at 19k miles. I don't think it has much to do with cornering. It does have alot to do with burnouts. These tires are just soft and are gonna wear in 20k -25k miles even if driven gently in a straight line. They get VERY noisy too once you get near the wear bars. My car sounds like a freaking helicopter inside nowadays if the windows are up. Cornering too hard, alignment problems, inflation pressure problems, would all manifest as *UNEVEN* wear. For example, the outer edge worn too much esp on the front tires (toe-in or just driving it too hard), cupping (where the front edge of each tread block is more worn than the trailing edge), chunking (driving it WAY too hard, if auto'xing get some real slicks and drive in SSx stock class), etc. Bottom line, these tires are what they are: Summer ultra high performance tires. They suck in any kind of snow or ice and they wear out quickly. What really is odd is how expensive they are. No way I'm gonna replace these at $250 a corner when I can get some high rated Kuhmo Ecsta 4X tires for a little over $100 a corner. Sure they will give up a tad bit of summer grip and feel, but they will be better in all other aspects including noise, wear, and treadlife. At least that's what I'm reading. If anyone has experience with the Kuhmo Ecsta 4X tires let me know please.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
![]() | | #16 | ![]() |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,832
Groans: 448
Got 17 k on oems. 38,000 on Goodyear eagle f1 gs d3's. at 20,000 on Nitto Neogens. Oems don't last. Known for 6 years now.
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
![]() | | #17 | ![]() |
My issue and I've seen others report the same thing... My alignment is good, but my tires are wearing on the inside... Can't do much other than get tires every year I guess. Sent from my DROID BIONIC using Tapatalk 2
![]() | | #18 | ![]() |
![]() Join Date: Aug 2011 Location: Charlotte, NC
Rep Power: 108 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
__________________ 2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs. wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass maybe list - BSD, top or front IC, cat back exhaust 2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though). | |
| The Following User Says Thank You to Pedal-Force For This Useful Post: | fortressofcomfort (10-07-2012) |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2011 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 13 Times in 3 Posts
yeah same here the inside wears fast, might as well go hellaflush with it |
| Holy Inner tire wear! | meciboy | MazdaSpeed 3/6 - Wheels & Tires | 51 | 03-08-2013 09:21 AM |
| Is this normal tire wear? | Bucker | 2010 MS3 - Wheels & Tires | 34 | 04-26-2012 07:39 PM |
| wtf insane tire wear!!! | superskaterxes | MazdaSpeed 3/6 - Wheels & Tires | 42 | 07-26-2010 09:33 PM |
| Bad Inner Tire Wear | MattJackson86 | MazdaSpeed 3/6 - Wheels & Tires | 3 | 03-09-2010 06:43 PM |
| Bad inner tire wear | cm-jp1 | MazdaSpeed 3/6 - Suspension & Brakes | 27 | 12-05-2009 07:19 PM |
