-   -   Top o2 sensor will not come off DP install (http://www.mazdaspeedforums.org/forum/f544/top-o2-sensor-will-not-come-off-112612/)
duthsman 05-02-2012 06:23 PM
I'm am about to throw something
We have used half a can of PB blaster and used two different o2 sockets. The o2 will NOT budge. The socket keeps stretching and stripping the corners off the bolt.
We have tried everything and my coworker is a master Toyota mechanic and he's never had this much trouble.
Any ideas or something to help a brotha out???????
spiffy9999 05-02-2012 06:26 PM
Vice grips + torch + welders glove(for safety).....heat up the bung...not the sensor....bung will expand allowing you to turn the sensor with the vice grips already applied
Broxer 05-02-2012 06:28 PM
You might try heating it with a torch or worst case cut the wires and put a wrench on it. I'd only do this if you can solder them back afterwards.
If you're having that much trouble though, the threads are probably going to strip. Make sure you work it back and forth when taking it out.
Sent from my ADR6425LVW using Tapatalk 2
uncorked11 05-02-2012 06:32 PM
Like they said heat it up, I used a full socket and a long breaker bar. First applied torque to tighten it a little, then loosened it sprayed more on blaster and repeated. Came out easy. GL
I am here: http://tapatalk.com/map.php?2yjydk
kritz 05-02-2012 06:33 PM
An old machinists trick that I was taught was to heat it up and melt parifin on the threads, it will penetrate deep in the threads and then apply torque.
Sid3wayS 05-02-2012 06:43 PM
DO NOT CUT THE WIRES TO SODER THEM LATER!!!!!!!! These are not your typical copper wires. Heat that bung up and apply hulk amount of torque.
SSinstaller 05-02-2012 07:02 PM
At this point it sounds like your sensor will be fubar when it comes out. I'd just leave it in a buy a new sensor for your DP..
Blackrider 05-02-2012 07:25 PM
I had the same problem with my downpipe install. I ended up having to cut the wires so I could get a normal socket on it, heat the hell out of the bung and use a half inch impact. The sensor was completely cross threaded into the downpipe. The sensors are very expensive from the dealer, but if you look online you'll find them for a reasonable price!
duthsman 05-02-2012 07:58 PM
yea i guess i can buy an aftermarket bosch o2 and depin the connector and wire it back up. i work for a wiring company so thats kind of my thing.
i also thought about cutting the wires at a reasonable length and then putting a 4pin deutsch disconnect but someone said the wires are not normal wires..? are they double shielded wires with a shield in each wire?
usually almost o2's i deal with are 4 wire, a heater signal, ground, power, and o2 signal.
we gave up for the night but I'm gonna drive the shit out of it on the way to the shop and when i get there I'm gonna blast it again with PB and try when its hot... if that doesn't work, were gonna heat the bung up and try the vice grip way.
this is inSANE:smashfreakB:
@Blackrider
which o2 did you buy to replace yours?
dastpe 05-02-2012 08:12 PM
one thing i did to help mine that worked is actually tightened it a little bit, that seemed to loosen the threads enough to get it to the point of loosening.
Blackrider 05-02-2012 10:57 PM
@Blackrider
I ended up going with the OEM replacement from SU because they offered the best shipping method, it was 199 - a 3% discount code. I'm pretty sure you can find them cheaper than that. I was originally going to cut the wires and have them soldered by a friend who has soldered O2's for me before however, when I got it off the threads in both the stock downpipe bung, and the 02 were completely and utterly fuck.
backward_0 05-02-2012 11:03 PM
this might sound stupid, and i have never tried it, but i am sure someone has, but tried putting a hose clamp tightened around the socket head... to keep it from slipping?
Postulio4joo 05-02-2012 11:04 PM
Why does our downpipe like to weld our O2 sensors on?
breakfstincluded 05-02-2012 11:06 PM
geeeze expensive... thinking about 02 sensors when I do downpipe later...
= nightmares
Sid3wayS 05-02-2012 11:16 PM
Cheapest place for all oem parts: Online Mazda Parts call the number and ask for jason. Will give you the best price period. And they have everything in stock.
Reason I said not to cut them is because ive read here in other threads that although the power and ground are typical copper core wire, the o2 is something else, cant remember the name, but a hollow tube that you can't put back together. It's the center white one. But im by far no expert and if you dealt with these before then please inform us/me.
duthsman 05-03-2012 10:06 AM
Haha! Dude... We used TWO hose clamps to keep the barrel shut on the socket. Fml
EdgeAutosport.com 05-03-2012 10:12 AM
Impact gun. :)
m4tic 05-03-2012 10:19 AM
my o2 came out with some thread material from my stock dp. I just ran a die around it a slapped it in my new dp. Works fine and no leaks.
skeurton 05-03-2012 10:40 AM
I've done three downpipe installs and all O2 sensors came out without any problems. It seems like whenever someone does have a problem, though, it's because the damn thing was cross-threaded from the factory.
When I did mine, I actually ponied up the money to buy an extra sensor, just in case shit did happen. Just an FYI, there's a thread that shows a slight difference between the gen1 and gen2 wideband sensor.
http://www.mazdaspeedforums.org/foru...-sensor-84333/
AFAIK, there is no aftermarket solution for that sensor, only the secondary O2. OEM looks like the only way to go. For reference, the correct part # for gen2 is L3CE-18-8G1. It costs a little more than $300 if you buy it online.
G26 05-03-2012 10:45 AM
Same thing happened when I was doing my downpipe. We had to heat up the bung, and even then the sensor came out with no threads.
p057 05-03-2012 10:52 AM
:smashfreakB:
You cannot cut these wires, you will not be able to solder them back on, it'll be ruined.
Broxer 05-03-2012 01:03 PM
Originally Posted by p057 (Post 1395939)
:smashfreakB:
Ok I did a little reading, they are stainless steel wires, they actually sell special crimps that are gold/silver plated to use. Some people say that it won't have the same resistance if you do this, others say that have done it and it works. I dunno. I'd probably try it before I spent the bones on a new sensor.
SSinstaller 05-03-2012 06:50 PM
A new engine due to shitty afr readings from a crimped together O2 sensor harness is going to be much more expensive than a new O2 sensor...
Broxer 05-03-2012 06:52 PM
True dat
easy 05-03-2012 07:05 PM
i've heard people doing it after a drive when everything is nice and hot ...
duthsman 05-03-2012 08:42 PM
update:
first of all... fuck.
second of all... we used a mini butane torch to heat up the bunghole area. huh huh...
then we got some FreezeOff and blasted the shit out of it then it moved. went back and forth for a little bit, then we hit it with the torch again and it came out like butter.
so I'm happy now! haha but god dammit.
we even went to mazda right by our shop and talked to a tech and i asked him about the o2, and he said "have you beat the shit out of it yet?" which i knew was a bad sign.. so we talked it over and left with no dice.
finally, the DP install is done. Thanks for all the info guys! much appreciated!
spiffy9999 05-03-2012 08:51 PM
So what was finally used to grip it to get it out? Tell me it was vice grips...vice grips ftw.....lol
duthsman 05-04-2012 08:54 AM
We used the o2 socket, im sure vice grips would have worked, but we didn't need them. Just had to get the bung red hot
p057 05-07-2012 05:57 AM
i'd be worried that you messed up the sensor. take it veeeery easy on the car for a while after install and keep a very close eye on AFRs
MSFer87 05-07-2012 06:05 AM
I bought the rent a tool from Vatozone, and stripped the threads from then on out we tried and tried and ended up calling it quits and just cut the wires and removed the dp with the 02 still attached. Got the hook up with a new one from advanced.
duthsman 05-07-2012 11:22 AM
Been checking it a lot. On cold starts and after a 2 hour drive. Solid 14.7 at idle. She's running good.
But loud as fuck... Now I have only the ultimate racing mufflers and no other silencers. I think I'm gonna weld a reso in my mid pipe.
Page generated in 0.19283 seconds with 11 queries
