Torque specs for Crows feet/Fuel rail. Going to be doing the seals/rv/tigs etc in a couple weeks, I have torque specs for the intake mani (from jbr's tig instructions), but I cannot find anything on the torque specs for the fuel injector crows feet (with ptp studs), fuel rail, hard line on fuel rail or relief valve. |
Could always call ptp and ask. |
we torqued @mazdafreak's to 16 lbs yesterday just like the IM. He said that was the spec for the rail and crows feet. If you are replacing with studs it could be different tho. |
Yeah I'm pretty sure its ~16-18 ft/lbs......I don't see it being anymore than 20ft/lbs of torque. I haven't ran my car hard yet, since I installed my PnP intake manifold, but so far, no leaks. |
I shot him an email. |
*You're The message you have entered is too short. Please lengthen your message to at least 10 characters. |
PTP Got back to me on the torque specs: 22 ft-lbs for the studs (crows feet) 18 ft-lbs for the rail valve 20 ft-lbs for the fuel rail bolts @dereeek |
I was around there...mine should hold up. |
| All times are GMT -7. The time now is 03:40 AM. |
